Question about Roper REX5635E Dryer
No. Heat. Is it easy for me to change the heating element myself? If not what should it cost to have repaired
  • Roper Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 10, 2010
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
Whirlpool akz161 top oven. The lower heat element is not working how do l access this as l need to fix it myself
open door if you can see screws at element ends remove them and change or you will have to do it from the rear
Nov 16, 2013 | Ovens
The lower heating elements on my GRV660 do not heat up. Is this an easy repair or should I scrap it?
first you need to find out if its the elements or /broken wire feed /or cut out....Get a parts price 1st elements vary in cost average perhaps £30....plus labour, depending on age may not be worth it...cheers
Apr 21, 2011 | George Foreman GRV660 Toaster Oven with...
My dryer won't heat anymore, could it be the heat element?
It could be the heating element, but it could also be the thermal switch, a round button that can sense the heat. One of the wires that go to the heating element go through the thermal switch. It's held on by two screw and is an easy repair.
Feb 18, 2011 | LG DLE2532W Electric Dryer
Model LEQ9508PW1. It has stopped getting hot. Just stopped putting out any heat. I assume that it is probably the heating element that has gone out. Is there anything else I should check first before...
Check first the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect the power then start the dryer. The problem is in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
Also bypass the cycling thermostat if the dryer still doesn't heat up with the thermal cut-off (cut-out) and the high-limit thermostat both bypassed. If the dryer still doesn't heat up, take the heating element out and inspect it for damage. Replace the heating element if damaged.
Jan 18, 2011 | Whirlpool Dryers
Oven does not heat up
this is a pretty common problem. I had it myself. Chances are that the heating element is bad. They are easy to replace. Most hardware stores sell replacement elements. Lowes, Home Depot, etc. Just tell them the make and model number. They will give you the correct one. However if you don't have the make and model number you may be able to identify it by simply looking at it. Make sure the electricity to the range is off before attempting to repair it. You remove the old element and replace it following the directions given with the element. Usually only 2 screws hold in place. Hope this helps
Aug 25, 2010 | GE Kitchen Ranges
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
Fan works on "on", shuts itselfoff on "auto",no heat either way,
Sounds like the themostat isnt properly set up check the back and make sure the gas/electric switch is properly set
Jan 21, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Oven stopped working.
Hi.
Yes, it does sound like the element has gone.
They can cost anywher from £13 to £50.00 depending on the make of oven.
Generally speaking, it is a fairly straightr forward repair.
Nov 21, 2008 | Ovens
Tumble dryer not giving off heat
It could be the heat limiter switch which is either one or two run in series little button looking things near the element on the back, usually under a bowed out cover. Also check the resistance on the heating element after you have pulled the wires that go to the terminals so you don't get a false reading. Other than that it gets into checking contacts on the timer itself and that gets a little lengthy in discussing. Hope that helps.
Jan 28, 2008 | Dryers
Dryers Logo
42 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
