Question about Iomega (33600) 160 GB USB 2.0 Hard Drive
My 500gig iomega USB 2.0 external hard drive dropped off my chair and fell about a foot and a half now it is making a beeping sound and won't be recognized by mine or my roommates laptop. any chance of saving it or is the over 350 gig of data on it toast? would really like to save it.
  • 6,487 Answers
Base from the description of your problem a bi chance here is that drive is bad already , and since this is a external drive what you can do here first is to take it out from its USB enclosure and connect it directly to a computer and then check if it will be detected or not.
Because if this drive got detected when connected directly yo a computer you can still recover all the data inside it but if not and you still wont to recover and revive the drive you need to sen it to IOMEGA for repair.
Posted on Sep 06, 2010
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though...
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though the drive is beeping
Aug 09, 2010 | Iomega Silver Series 320GB 3.5 External -...
Disk spins ...then I hear a beep...icon does not show up
The hard disk or the adapter case maybe faulty.
To test the hard disk, remove it form the Iomega case and connect it to an USB hard disk adapter and plug it into a computer's USB port.
If this computer see it as an external hard drive and you can open the folders and files then the hard disk is OK, then the Iomega adapter case is faulty.
Then you need a new hard drive adapter case, it doesn't need to be an Iomega brand.
Nov 26, 2009 | Iomega (33654) Limited Edition 500 GB USB...
Dropped an Iomega 500gig external hard drive...
From what I can deduce here, it seems that you the hard drive probably has a bad sector on it.
That clicking sound that you are hearing from the Hard Drive is coming from the read/write head inside the hard drive.
In this case, what I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Nov 20, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
I dropped my external hard drive, not even a foot, now when i plug it, it just keeps on loading or beeping every 5 seconds.
The power connection to the drive is damaged. The drive is not getting enough power to spin the drive properly so it is beeping. Check the power cord and/or the USB cable for damage as well.
Aug 14, 2009 | Iomega Computers & Internet
Iomega external not visible
Unfortunately, Windows isn't the most efficient operating system when it comes to it's "Plug 'n Play" abilities. In my experience, external hard drives can be particularly sensitive when it comes to unplugging the data cable while navigating the drive. I've had two external drives lose all data because of that flaw in the NTFS file system. The MFT exists on every drive with NTFS storage method. If that becomes corrupt, it can render the drive useless.
The drive may have power, but that quiet beeping you hear is an indication that the reader head is stuck to the platter and may be grinding into it. There is a myth (may or may not be true) that says if you put the drive in your freezer for a few minutes, take it out, drop it from 6 inches onto a hard surface, it may knock the head loose and make the drive work again.
I tried that method, and it made the situation worse for me, but it may work for you. I would resort to that option only if nothing else fixes it.
Aug 08, 2009 | Iomega CORP EGO PRTBL HD 160GB-HS USB 2.0...
Iomega (33600) 160 GB USB 2.0 Hard Drive Logo
376 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
