Where is virtual memory located in windows vista?
  • 398 Answers
Click start button>control panel>system and maintenance> system>advanced system settings (on the left sidepanel)
Hit continue if UAC asks and then hit the settings button in the performance section of the window. Hit the advanced tab and you'll see the virtual memory section and you can hit the change button to open it.
Posted on Sep 06, 2010
Memory is used up by excel
I don't think you can. It's a real resource hog especially if youre using 2010/13. See below.
Excel 2003 is officially limited to 1 Gigabyte (GB) of memory.
This limit appears to be a limit on the working set memory used by the Excel process, which is the memory reported by Windows Task Manager.
Although Excel 2003 has a substantially increased memory capacity, many of the individual specific memory limits listed below have not changed in Excel 2003.
Excel 2007 is limited to 2 Gigabytes of memory for the Excel process under Windows XP/Vista (Windows memory limit).
This 2 Gigabyte limit is a limit on the Virtual Memory address space. Virtual memory used by a process is larger than the working set memory reported by Windows Task Manager, so the amount of useable memory under Excel 2007 is considerably less than twice that of Excel 2003.
Because Excel 2007 (Excel12) also requires more memory to store the indexes to the increased number of rows and columns you may not be able to load larger workbooks under Excel 2007 than was possible under Excel 2003. Memory Fragmentation may also mean that it is difficult to make use of all of the available 2 GB of virtual memory.
Many of the individual memory limits listed below have been removed in Excel 2007.
Excel 2010 is available in 2 versions: 32-bit (2 Gigabytes of virtual memory) and 64-bit (8-Terabytes (which is 8000 Gigabytes of virtual memory)).
The 32-bit version has the same memory limits as Excel 2007, but the 64-bit version, when used with a 64-bit Windows operating system, will have extremely large memory limits.
Note that the different versions of Windows Vista 64-bit and Windows 7 64-bit support differing amounts of RAM.
Aug 17, 2014 | Microsoft Excel for PC
Tip
Solution to Virtual Memory Too Low Problem
This problem was reported by one of our readers that in spite of having a sufficient amount of RAM, he is running out of Virtual Memory and his Windows PC gives the following error:
Your system is low on virtual memory. To ensure that Windows runs properly, increase the size of your virtual memory paging file. For more information, see Help.
This is a common problem and you may have seen it if you are trying to open many heavy applications at the same time like Microsoft Office.
Let’s see what the causes are and what can be done at this stage.
Windows XP or Vista uses the concept of Virtual Memory that aims at providing the additional memory from the Hard Disk if most of the RAM of the computer is already occupied. This memory used from the Hard Disks is called Paging File. Windows reserve some part of the memory for this purpose only (this is one of the reasons why we see less memory than specified on the hard disk).
Virtual Memory also known as Page File or Swap File can be located at C:\pagefile.sys (it is system hidden and can be viewed if you Uncheck the option of “Hide Protected Operating System Files” inside Folder Options).
on Nov 17, 2008 | Microsoft Windows XP Professional With...
On initialising my web cam , my windows 7 shuts down saying virtual memory low
To increase Virtual Memory ( Vista)
Start > Control Panel Home > System and Maintenance > System > view amount of RAM > Advanced System Settings > Advanced tab > Performance - Settings > Advanced tab - Virtual memory will be displayed - mine is set to 3000 MB > change >
min 3000 max 3050 > OK
Apr 25, 2010 | Umax Astrapix PC102 Webcam
I absolutely hate vista....i wasn't able to transfer my microsoft money so had to download quicken and transfer info...then twice now i have had to reinstall quicken because it won't open up...i guess it...
There is a work around to getting Windows XP programs to work under Windows Vista - Virtual PC 2007.
Virtual PC 2007 is a free download from Microsoft and it allows you to install any operating system and run it in a "window" on your Vista desktop.
Download Virtual PC 2007, create a Windows XP virtual machine, install Microsoft Money and transfer in your data. You can install Quicken as well.
The virtual machine will use your PC's actual connections (network, serial and printer but not USB) to connect to devices and the Internet.
Again - this is a work around that is proven to work. One side benefit - you can copy the virtual machine to an external hard drive / USB memory stick and run it on any comptuer that has Virtual PC 2007 installed on it.
Hope this helps
Nov 18, 2009 | Microsoft Windows Vista Ultimate Edition
Juiced wont start because it asks virtual memory to be enabled
the best fix is to open up properties, click run in windows xp and...da da! it works (as long as youre running in vista). this is to do with vista being able to employ more ram than xp.
Oct 04, 2009 | Video Game Consoles & Games
Low virtual memory
You have to increase the Virtual memory.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Dell Inspiron 1300 Notebook
Vertiual memory
Virtual memory is really hard disk space used as memory.
If you are running low on virtual memory, make sure your hard disk is not nearly full (check in MyComputer). or adjust Virtual Memory settings:
On Windows XP look in
  • Control Panel
  • System, Advanced,
  • Performance,
  • Settings,
  • Advanced,
  • Virtual Memory.(set to a larger number)
I believe it's in a similar location in other versions of Windows.
Oct 25, 2008 | Gateway Computers & Internet
I need to increase virtual memory
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
Jul 15, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
