Question about Lexmark X4550 InkJet Printer
Control pannel once you lift the control panel can you put it down again or is it stuck permanently?
    Genius:
  • 2,785 Answers
It should fit with the body of the printer
Posted on May 13, 2008
Dow do I remove the passenger inside door panel?
You can remove it by firstly removing all plastic most plastics wil have a place you can lift with flat screw driver then remove all screws and wangle pannel loose
Dec 01, 2015 | 2004 Nissan Quest
POWER BUTTON STUCK IN MOGEL # GFDN240ELWW
I took off the front panel by removing the philips head screw behind the control knob. The front control panel will lift straight up. Remove the 6 philips head screws which secure the control board to the inside panel. When you lift up this module you will see the power button. It is made from cheap plastic including the hinge. Only way to repair is to either super gluie the hinge or replace the entire control panel. I think this is an extremely poor design, especially coming from G.E.
Jul 24, 2011 | GE GFDN240ELWW Dryer
How do i remove the wing mirror (power adjust & power fold) on the ford f250 super duty?
Roll the window down first, you will need 2 hands. Pull the small cover off that is at the top front of the door pannel. You will then disconnect the wire connector and remove the three 11mm nuts that are holding the mirror in place. Pull mirror out and replace.
If you dont have just that little pannel you will have to remove the door pannel. If you dont have power windows pull the cover out on the window crank and move it to the side, there will be a screw holding the crank in place. Remove it. If you do have power windows remove the window control switch plate (it will just pop up using a small screwdriver) and disconnect the wires. If equipped, remove the front door trim panel reflector or the courtesy lamp lens. Then remove the screws. DO NOT pull directly outward on the door pannel, something will brake. Remove the front door trim panel by pulling it straight upward.Lift and remove the front door trim panel. Then the nuts holding the mirror will be visible, remove and replace the mirror.
Dec 07, 2010 | 2000 Ford F250 Super Duty Crew Cabs
Control Panel Light is out.
I'm not sure if you have removed the trim on the right and left front. so if you have not then open the bottom oven door and in the lower right and left corner near the hing should be a screw, remove them and pull down on the trim pice and now this will revial a screw at the top right of the control pannel on the left and right , now remove them screws and make sure power is turned off at the fuse box and lift on the control pannel. if this does not work you will need to remove the unit.
May 24, 2010 | Whirlpool RBD305PR Electric Double Oven
Rear passanger window fell off track
First you need to remove the door panel, which usually is just a few philip head screws or 10 mm socket sizedbut before you try pulling if your car has a tweeter/audio on a corner of the window make sure sure you remove that first very carefully you don't want to force since it is only held by its on clips... Then once you are ready to remove the door panel start by inserting a flat head screw driver in between the metal and the plastic pannel.
Then star opening it in a uniform manner only start opening from side till you open it since it has a bunch of plastic clips going all around the pannel to hold it on the metal.
once it is open you might need a rachet, a 10mm or 12mm socket and an extension for thet rachet.
Look for about 2-3 round holes enough to fit the socket in connect the power and psition the screwns of the control arm holding the glass and lossen the screws so tha glass can be pulled out its better and recommended to be done by two persons one holding the glass and one removing the screws.and then when the glass is pulled out all the way out is easier to re-aling it and as well one person pushes down and holds the glass the othe one makes sure from the insid panel area that the glass is going on its channel/u shaper rubber all the way....sets the screws back of once is well positioned start tightening the screws back on...and test it with the swich once is done, if stays in the track it means that you succeeded and your control arm is in good working condition and as boost up put some kind of lube on its track from up to down....And if it comes off the track againg you might need to replace the control arm which is that piece that holds the glass with the screws on it...
and to star putting the door pannel back on start by aligning it on the top , make sure that that ruber that keeps touching the glass gets in all the way and then just make sure that all the clips holding the pannel are all attached to the pannel and so just start pushing the pannel against the metal and it shoul clip once is well positioned.then just put the screws you took off the pannel and you should be don....don't forget to carfully clip back the and connect the tweeter window if has one....and voilah...you're done.
Mar 15, 2010 | 1995 Jeep Grand Cherokee
Will not start. control stuck on glasses cycle. display states "39" cannot change cycle or cancel
Go to the fuse pannel and trip the fuse breaker off and then put it on again. It will reset the automatic cycle. Vitally
May 13, 2009 | Frigidaire PLD4555RFC Dishwasher
The rear left passenger door window power lift mechanism is broken on my 2001 Suburban. I have to physically lift the window up and tape it in position to keep it closed. How do I remove the door paneling...
the power window on 2000 chev suburban is stuck down. i removed the door pannel and the motor works but it appears the wiring on the pulley is not right any info how to remove.or repair that system?
Apr 04, 2009 | Chevrolet Suburban 1500 Cars & Trucks
How to install door window in 1993 cadillac deville
The interior door panel needs to come off; the panel comes off by pushing it up from the bottom. Make sure you remove the window, seat, and mirror control panels first and pop off the clip that holds the plastic corner sail panel by the mirror. Also CARFULLY remove the pastic panel with the power lock controls and unplug the wiring harness. Pop off the two plastic covers on either end of the door-pull handle and remove the screws with philips screw driver . After doing this, CARFULLY lift from the bottom. Once the panel as come off, CARFULLY pull the panel far enough away from the door to pull the two speaker connectors off. Put the panel someplace safe, along with the power controls. In order to get to the power window equipment you need to pull back the black rubber sound absorber panel. It is stuck on with a black, gummy, tar like substance. Again, be careful with this as well.
Feb 24, 2009 | 1991 Cadillac DeVille
Two error messages persist after replacing toner cartridge.
This kind of error indicates that your toner is not properly set or there is some paper jam. so please follow the instruction and open the panel and remove the toner and check for any kind of paper piece and than refit toner properly and close the panel and than check you will definatly able to resolve the problem ok
Dec 20, 2008 | Canon imageCLASS MF4270 All-In-One Laser...
1996 Jeep grand Cherokee Larado, rear door stuck
go throu licence plate pannel pull up on bar and on the inside under ur pannel the nut fell off the mechanism so just put on a new nut
Aug 09, 2008 | 1996 Jeep Grand Cherokee
Lexmark X4550 InkJet Printer Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
