Question about Sharp Office Equipment & Supplies
Error code H5-02 on Sharp Copier AR-287 - Sharp Office Equipment & Supplies
  • 26 Answers
H5-02 = Fusing thermistor abnormality
hi Valerio
Posted on Sep 07, 2010
SHARP AR-287
Is the code a H5 ? Is it a AR-163 or a AR-287? Is the copier making a load noise when making a copy? Basicly, the code means you are have more then 5 paper jams in the fuser & there is a problem there & the copier is locked up.... It's self saving it self
May 05, 2010 | Sharp AR 163 Copier
Error f2-31 en fotocopiadora sharp ar 287
You must your copier TD cartridge,then solve your problem.If you are not fix it,Then press
C>Photo>C>photo>16> start key
Apr 19, 2010 | Sharp AR 163 Copier
I have sharp ar-287 error ha-04. How to fix?
this sounds like you have a jam in your fuser unit.To remove this jam open the door at the left hand side,you should see a green lever to the back end lift up and take paper out,after doing this you then have to reset this error code.To enter service mode press P interupt C interupt key in 14 press start key then press CA.Photocopier should reboot if this does work then you need to get your service engineer out
Sep 15, 2009 | Sharp AR-507 Copier
Sharp AR-287 HR-00 error code
I'm sorry for not getting back to you sooner - I lost track of this question. If you still need this info here it is :
H3-00 indicates a temperature problem in the fuser unit. not reaching a certain temperature within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Mar 30, 2009 | Sharp AR 163 Copier
Need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
Mar 25, 2009 | Sharp AL-1641CS Laser Digital Copier
F9-00 (Print Function) Error Code on Sharp AR-287
this copier will display f9-00 if the nework is not connected or the card is bad this means network connection lost usaally resting copier will work if the network is on if not call service
Mar 03, 2009 | Sharp AR-235 Copier
Sharp AR-287 fault code E7-11
Hello sir; The error code means there have communication problem between main board and sub board,operation board, icu board or print, my suggestion, go buy a new copier, it not worthy to repair !
Feb 27, 2009 | Sharp AR-235 Copier
Sharp AR-287 error code HR-00
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
Dec 24, 2008 | Sharp AL-1641CS Laser Digital Copier
My Sharp AR-287 Copier is showing F2 error
there Should be 2 additional numbers. F2-??
Oct 29, 2008 | Sharp AR-235 Copier
I want a solution for a Sharp AR - 287 Digital Image problem
H4 for an error code on all Sharps indicates that the fusing temperature isn't correct. It needs to have a new thermistor installed or the heating lamps need to be replaced.
Oct 21, 2008 | Sharp AR-235 Copier
202 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
