Question about Maytag MBB2256G Bottom Freezer Refrigerator
Maytag bottom freezer fridge model # MBB2256GEW the fridge part is not cold. The freezer is freezing just fine; the fridge is not cold at all. We noticed this two days ago. I have turned the temp dial to as cold as it can go yet it is not responding. It is more than the recommended 1/2 inch away from the wall. Can you tell me what might be wrong and how to fix if it is something the owner can do? Thanks. Paul Thompson
  • Paul Thompson Sep 06, 2010
    Thanks! I will follow these steps!
  • 2,382 Answers
Hi, these are the possible cause of the problem, you have to check one after the other to proffer the solution.
  • Vents between fridge and freezer sections are clogged with ice. Warranty guy told me to unplug 24 hours, replug and everything should work out.
  • Fautly thermostat.
  • Clogged/dirty evaporator coils (underneath in newer models, on back in older models).
  • Bad "Adaptive Defrost Control Board", Google it, it's an easy fix, about $35 on ebay, just make sure you get the right one for your model fridge.
Posted on Sep 06, 2010
  • Tunde Autos
    Tunde Autos Sep 06, 2010
    O.k., don't forget to accept and rate the solution...
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
My maytag side by side is not cooling right.when the weather gets hot and humid the freezer won't freeze anything and the fridge isn't cold enough.when the weather is cooler everything works fine. it is an...
Clean the condenser coils underneath the fridge.
Check condenser fan at bottom of back of ref.
that its not slowed or stopped
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 02, 2010 | Refrigerators
Maytag fridge which freezes food in fridge compartment
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Maytag MFI2569VE Bottom Freezer French...
Defrost Timer?
depending on model thats either your timer or cold control would be about 200
Mar 19, 2009 | Maytag MBB2256GES Bottom Freezer...
Crisper door/water line freeze problem
mar...you're box is set too cold. Use -17 C/38 F on the freezer side which is about 38F/4C on the fridge side. Use an outdoor thermometer and let it sit closed for at least a few hours. Adjust accordingly and this will work out. One adjustment is often the cold vents from the freezer into the fridge. If set too wide, too much cold air gets into the crisper and water lines.
Feb 01, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Maytag side by side model GS24C8C3EV Refrigerator too warm
it is almost certainly a defrost problem. when fault has occured, remove freezer bzck panel and see if there is ice build-up. if so this confirms a defrost problem - possibly that the element is open circuit
Jun 21, 2007 | Maytag MSD2434GE Side by Side Refrigerator
Freezer compartment not defrosting
most refrigerators utilize an electrical heater coil to prevent freeze-ups. your coil has most likely failed. hard to pinpoint without being there, however, i would check its resistance with an ohm-meter with power off: if no resistance, then coil is burned out. look for around 2 ohms
May 26, 2007 | Maytag MBB2256G Bottom Freezer...
Maytag MBB2256G Bottom Freezer Refrigerator Logo
903 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
