Question about Watches
Fossil Explorer watch BQ9381. It has 3 batteries. 2 are held with small screws and can easily be replaced. But the other one, how do you remove it?
  • Matt Thompson Mar 14, 2013
    Read Step 5 of my write-up.
    New Friend:
This watch is relatively simple to work on, though you have a total of nine (9) screws, three (3) batteries of two different types, a spring-pin in the wristband, and an o-ring seal to contend with. Nonetheless, you should be able to do this in half an hour with the following tools: Fine tweezers, preferably curved tip; these tweezers should be able to draw blood if you poke yourself lightly with them. Miniature (jewlery) screwdriver set, with tips no wider than the thickness of a dime. Clean toothbrush. Mouse pad for a work surface (optional but highly recommended). READ ALL OF THESE INSTRUCTIONS BEFORE DOING ANYTHING. If you feel you are not up to the task, take it to a jeweler or reputable watch retailer (NOT WALMART!!!)1. Disconnect the 12 o'clock half of the wristband from the clasp. Remove the pin, and re-install it into the clasp so you don't lose it, or simply set it aside if you're afraid of it launching.2. Remove the four Philips-head screws from the caseback. Lift off the caseback and check the o-ring seal. If it starts to come off, remove it and set it aside.
3. There are three batteries in this watch: two (2) 392 silver oxides (they may also say 41, 192, or 384) run the analog movement and are held in place by two (2) Philips-head screws each, and one (1) 364 (it probably says 621) silver oxide running the digital circuit. It is best to replace all three at once to get the maximum life out of each battery per change to minimize damage to the seal by unnecessarily opening the watch several times.
4. Using a pair of tweezers, carefully remove the self-adhesive insulators that cover the two larger 392 batteries; set them aside adhesive side up where they won't get in the way. Then remove the two Philips-head screws from each battery clip. After removing the first one, the second will likely get "stuck" in the clip as the contact pushes it upward at an angle, engaging it with the threads. Don't worry about that, but do be careful not to lose either the screw or the clip. Repeat for the second 392 battery.
5. Remove the one slotted-head screw from the 364 battery clip. You may need tweezers to remove the screw, clip, and battery from the battery recess. DO NOT TRY TO DROP OR SHAKE THESE OUT.
6. At this time, you may want to clean the perimeter of the watch opening where the o-ring seal will be replaced. Use a toothbrush and try to scrub away any dirt. Don't brush across the open PCB of the watch as you will get dirt inside it that way. Gently work your way around the outside.
7. Installation is reverse of removal. Remember, there is ONE of the smaller 364 batteries down in the recess, and there are TWO of the larger batteries on top.
8. When you have ensured that all five battery screws have been properly replaced, and the self adhesive plastic insulators have been positioned properly and are sticking to the clips on the 392 batteries clips, hold the o-ring seal between your fingers only tight enough that you can pull it through your fingertips with little effort. Wipe the entire o-ring seal in this manner for several rotations.
9. Gently stretch the o-ring around the perimeter of the opening. Use tweezers to position it, then hold it down on one edge and work the tweezers between the inside of the o-ring seal and the outside perimeter of the opening so that it guides it into place. It may try to "roll" out of position; keep running the tweezers around the perimeter until the "roll" works itself out and the o-ring seal stays seated nicely in position on its own.
10. Replace the caseback, ensuring that the orientation is correct: the top of the text will be in the 12 o'clock position, which is where the band that was disconnected from the clasp is. The crown knob will be facing left with the watch face-down while the text is legible.
11. Re-connect the band to the clasp. Insert the pin into the end of the band, then insert one end of the pin into the clasp. Angle the other end in and if your band hasn't twisted around too much, you may need to use your tweezers to compress the pin into place. Rotate the pin and band until both ends find their hole.
12. I did mine in about 15 minutes, and no additional work was needed to "restart" the watch although the time needed to be set, obviously. Your results may vary. The digital portion was not dead when I replaced its battery. I am not responsible for lost or damaged watch components. I'm just a guy on the internet.
Posted on Mar 14, 2013
  • Matt Thompson Mar 15, 2013
    My apologies... I erroneously stated that the two (2) 392 batteries operate the analog movement, and that the single 621/364 battery operates the digital circuitry. I had these reversed; there are two batteries for the hand and one for the display.
  • Paul Cofrancesco Jan 11, 2017
    I just threw out two fossil watches in perfect condition with dead batteries. One had 3 batteries inside! fossil = legacy junk.
4 Suggested Answers
slp11508
  • 43 Answers
SOURCE: remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Posted on Jan 14, 2009
escapement
  • 2334 Answers
SOURCE: POD watch battery replacement.
Unscrew the screws holding that contact. Memorize where each screw was - they can be different in length. Fit new battery, put contact back in place and screw all screws back exactly where they were. After that you may need to shortcut battery's+ and AC point (marked on movement) for resetting your watch. Use tweezers to do that. Rate me, plz.
Posted on Feb 02, 2010
mcdevito75
  • 1970 Answers
SOURCE: I have a Fossil Automatic Watch, model ME1032. The
mcdevito75 here, Almost any jeweler should have another screw for the case back. You may even save a few bucks going to a small jeweler shop over one of the big concerns.
Posted on Jun 15, 2010
Testimonial: "Outstanding!!! -- *****"
Can:t remove back from Fossil watch BS9839, TO REPLACE BATTERY
you need watchmakers screwdrivers you can get them and other tools aswell off ebay ,,,,click on the link below,,,,,,,
http://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313&_nkw=watch+makers+screwdrivers&_sacat=0
Aug 01, 2012 | Watches
How do I change the battery on fossil motorcycle clock?
You will need a very small (watch or glasses) Philips head screwdriver, and a SR626SW (or know as a 377) watch battery.
Remove screw 1 to remove the motorcycle back cover.
Remove the other 2 screws to take off the clock backing.
Remove the white plastic ring by pulling directly up.
Remove the battery.
Put the new battery in.
Press the white plastic ring back on.
Reassemble the clock backing with the two screws.
Reassemble the back of the motorcycle with screw 1.
May 24, 2012 | Watches
I need to know how to replace the battery in my fossil watch. how do i get the back off to check the battery
IF YOU LOOK AT THE BACK THERE SHOULD BE A GROOVE IF YOU GET A PIN IN IT IT SHOULD PRISE OPEN OR A SMALL JEWELLERYS SCREW DRIVER
Jan 28, 2011 | Fossil Blue watch #AM3423 Watch for Men
I want to change out batteries
1. Lay the watch upside down on top of a towel or cloth on a flat workspace. Use a small flat head screwdriver or blade to pry under the watch backing, then lift the backing from the watch. Slide the battery cover to the side to access and remove the battery.
2.Take the battery to any electronics store to purchase a replacement. Bringing the old battery will ensure you install the correct type of battery in your Fossil watch.
3. Replace the battery and the battery cover. Apply pressure to the backing until it "pops" back into the watch.
THANK YOU FOR VISITING FIXYA
Aug 05, 2010 | Fossil Dress - Analog Glitz Red Dial Watch
I have a Fossil Automatic Watch, model ME1032. The case back is held intact by four small screws. I lost one of the screws after I cleaned the movement. Where may I purchase another screw without going...
Jun 15, 2010 | Fossil AU4003 Wristwatch
Fossil Kaleido Watch LI22248 replacement batteries???
Depending on the age of the watch it could have a ECR series battery over the top of the 377 powering the movement or it could have 2 377's in the circuit board over 1 377 in the movement.
I always recommend taking Fossil watches to a certified repair shop that can re-seal the watch so you dont void your 12 year warranty and the watch remains water resistant and resistant to small particles.
Sep 01, 2009 | Fossil Sport Auburn University LI2248...
CH2301 battery replacement. How open compartment?
There are 2 ways that Fossil closes the caseback on their watches.  It is either a 'pop-off' caseback that you will need to pry off.  Get something very small and thin, such as a small flathead screwdriver.  There is usually a small groove somewhere around the edge of the caseback where you can insert the blade.  The other type screws off.  You will need to unscrew the caseback.  You can determine if it screws off by looking for 6 notches around the outside edge of the caseback.  You will use these notches to insert a tool to rotate the caseback off.  Without a specialized tool called a watch-wrench, I suggest bringing it to a store such as Precision Time or Tourneau.
Jan 18, 2009 | Fossil CH2331 Wrist Watch
Replace a band on a fossil watch brand 2753 georgia bulldogs
Bands are held to the watch body by springpins. To disengage them, I use a fine blade knife, and pull one end of the pin down by causing the blade to bite into the metal of the pin, between the eye of the band and the watch body. This method will work when dealing with leather straps, perhaps not with a metal band, depending on how much clearance there is between the watch fork and the band's eye.
If there is no clearance, it may be necessary to destroy the springpin to get the band free. Replacement pins can be purchased at a watch repairer.
Replacing batteries: You need the back off. Some screw on, most press in. Press- ins can usually be released with a knife blade, or small leverage device if there is a specific release place on the rear cover. On odd occasions, it becomes necessary to "use a hammer and chisel". Not easy.
Screw- off backs need a tool to engage the slots on the rear. Sometimes can be done with a pair of long- nose pliers.
The backs often have a fine rubber sealing ring, for water resistance.This needs to be put back in place carefully.
The batteries are held in place by various means, spring tension, clamping etc. Sometimes a screw or two must be loosened to free the battery.
Really, it is all a job for the experienced.
I only do work on my own and other family member's watches. I have a range of tools I have made for these. I wouldn't risk doing outsiders' watches. I do bands and batteries, but leave it at that.
May 30, 2008 | Fossil AM3784 Wrist Watch
Changing battery
Generally, there's a small clip that can be held out of the way with a screw. You may need to hold it back, and tighten the screw in order to insert the battery. It may be enough to hold the clip out of the way.
Nov 01, 2007 | Fossil ES9825 Wrist Watch
Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Mar 15, 2007 | Fossil University of Oklahoma LI2282 Sport...
Watches Logo
1,070 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
