Question about HP LaserJet 2840 All-In-One Printer
Starts to copy or print,stops and says page to complex
    Champion:
  • HP Expert
  • 202 Answers
Replace your scanner assembly your problem will resolved,it is faulty.
Posted on Sep 06, 2010
I'm trying to print its says page too complex
A solution might be the proposed in this webpage:
http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-Drivers/page-too-complex/td-p/88560
Also, might be a problem with your driver, Download from HP website the latest driver available for your pronter model and intall it.
At this webpage you have the procedure for some other model but it shold be basically the same applied to your model.
HP Color LaserJet 2600n Page Too Complex Errors along with Blank Pages
page too complex
If still can't print, do a Google search for "PAGE TOO COMPLEX" and youll find more comments about issue.
Oct 23, 2015 | HP Color LaserJet 2840 All-in-One -...
I need to know the settings on the hp photosmart c7200 printer I should be set for me to get the absolute clearest scans of docs and also my drivers license
Hi. Here are the specs of your printer or simply follow this link to know more.. http://www.shopping.hp.com/shopping/data_sheet/cc567a.html
Print specifications -Up to 1200 x 1200 rendered dpi black when printing from a computer -Up to 4800 x 1200 optimized dpi color when printing from a computer and 1200-input dpi -Print speeds vary according to the complexity of the document -Panorama-size printing -Method: drop-on-demand thermal inkjet -Language: PCL3 GUI -Duty cycle: Up to 3000 printed pages per month
Copy specifications -Copy resolution up to 4800 x 4800 -Digital image processing -Up to 99 copies from original (varies by model) -Zoom to 400%, fit to page (varies by model) -Copy speeds vary according to the complexity of the document.
Scan specifications -Image editor included -Integrated OCR software automatically converts scanned text to editable text (if installed) -Twain-compliant interface -Resolution: up to 4800 x 9600 dpi optical (varies by model); 19200 dpi enhanced (software) -Color: 48-bit color, 8-bit grayscale (256 levels of gray) -Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
May 06, 2011 | Office Equipment & Supplies
The orange lights are flashing, is there something wrong?
Try:
1 Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
2 PPM print speeds are based on the highest speed printer driver mode. Photo print speeds are based on the default mode driver setting using Canon Photo Paper Plus Glossy paper. Print speeds will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. CPM copy speeds based on fast mode setting using plain paper. Copy speeds may vary based on document complexity, copy mode, page coverage and number of copies.
3 USB 2.0 Hi-Speed requires Windows XP, 2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v.10.2 to 10.2.6 operating systems, the printer will operate at USB 1.1 specifications.
Oct 22, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon B640 printing problem
The scanner lamp is not working. When making a copy, the lamp lights the source document, so if there is no light, the source document 'looks' black. Your machine will need to be serviced.
Jan 26, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Printing problems
GO ON LINE AND TYPE IN THE FOLLOWING INFORMATION.
EXCEL ERROR PCL XL ERROR
ENTER
LASERJET ERROR KERNEL ILLEGAL OPERATORS SEQUENCE ENDCHAR POSITION 293
ENTER
CALL THE MANUFACTURES CUSTOMER SERVICE LINE AND ASK FOR TECHN SUPPORT AND GET THE RIGHT ANSWER TO THIS COMPLEX QUESTION PLEASE
ROD GANDY
Jan 22, 2009 | HP LaserJet 4250n Printer
Prints java script instead of highlighted page
First, you probably should not stop the printer after it starts printing, it always creates problems. Second, you should clear your browser history and then you should select the range of pages to print on your print properties menu. If this does not work try reinstalling the print drivers.
Dec 13, 2008 | Brother MFC-210 All-In-1 Print/...
HP LaserJet 2840: Page 'Too Complex'
Description
The device could not print the current page because of its complexity.
Recommended action
Press ENTER to clear the message.
Allow the device to finish the job, or press CANCEL to cancel the job.
Lower the USB speed on the product by turning off "High Speed USB". Following are instructions on how to do this from the Secondary Service Menu:
To access the Secondary Service Menu press the Menu button.
Now press the #2 button and use the < arrow to navigate to the High Speed USB selection.
Press Enter and then use the arrow key to go to Off and press Enter again.
Press the Cancel button twice to exit the Secondary Service Menu.
Nov 11, 2007 | HP LaserJet 2840 Printer
try sending a page with extremely little to print, such as one word...any change...I am suspecting printer memory overflow
May 30, 2007 | HP LaserJet 2550Ln Printer
Error Message "Page too Complex"
Hi Sccfire, This apparently is a fairly common problem with the 2800 series printer and associated with connection to a PC using USB. It can only be overcome by manually configuring the printer?s USB port to work in standard mode rather than at high-speed USB2.0 mode which probably won?t be to much of a problem. Here is a link from a support page on HP?s site that should walk you through the process: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00506095 Let us know how it goes and please don?t forget to rate the posting.
Jan 05, 2007 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 2840 All-In-One Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
