Question about LaCie Computers & Internet
Hi there my Lacie 500GB d2 Quadra won't show up on the desktop. I have a macbook pro running Tiger. I want to back everything up so I can run an erase and install and update to snow leopard, but the external hard drive seems to have disappeared on me, like I say. It has a lot of media files on there - I've tried using cables for firewire 800, firewire 400 and USB, and I can hear it booting up, but nothing shows. It's listed in disk utility, but I can't access it. Love you forever if you can help!
  • 6,487 Answers
Try disconnecting the firewire/usb cable from the drive and take the drive to a quiet place.
Power up the drive and put your ear next to it. Listen for the internal disk to speed up and then click (which means it's ready). At this point you should have a solid blue LED on the enclosure.
If not, either the disk is bad, the enclosure's controller is bad, or the external power brick is bad (put your ear next to the power brick and if you hear a faint clicking sound, the power brick is bad and you can order a new one from LaCie for about $16.00.
Posted on Sep 06, 2010
My Macbook Pro running Mountain Lion does not recognise My Lacie D2 Quadra V2 (301442a) after upgrade from Snow leopard
Here's a good start.
Plug your Lacie drive into someone else Mac or PC using MacDrive Pro and see if it shows up.
Dec 02, 2017 | Computers & Internet
My 500gb lacie d2 hd quadra is no more recognized by my macbook pro sys 10.7.3 (lion)???...
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
May 10, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Upon start up I see the icon on my screen but then disappearing and reappearing along with all my other icon. the Lacie is disrupting my entire desktop & when I shut it down (Lacie) everything goe
I think the problem is because mounting problem of the logical drive .In this case to access your data in the drive you just need a macbook hard drive recovery tool .Remove the drive from your pc install the drive in some other mac pc and start it in target mode .Install this recovery tool and start recovering files but save it in different healthy drive .I am suggesting this tool because it works good for my missing partition problem.But purchase the full version to get good results.The demo version link is here...
Feb 03, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Hard drive makes a clicking sound and does not connect to my Macbook Pro. When i unplug the USB or firewire cord from the computer and turn on the drive, it doesn't make the clicking sound
if the harddisk is making clicking sound,, then there may be an failure of motor inside it,,, ,, nothing but giving your HD for replacement by manufacturer
Sep 28, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Drive not showing up on my desktop
i'm not sure i can solve this problem--which started for me tonight as well with my lacie d2 quadra 500 gb--but i can share a possible explanation i've found online: apparently, they have lots of problems with their power supplies. see if the power adapter (the black brick) is making a hissing sound, or if there is a ticking sound coming from the drive itself. i have both these sounds. i am hoping all my data is safe and that my i.t dept. will be able to fix it with a new power supply on monday.
Sep 21, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie drive does not come on
Maybe the usb chip in the hard drive enclosure that converts ide into usb failed. You could replace the enclosure (they sell enclosures at best buy) but it could be quite a hassle.
Jan 04, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Installed on MAC, then Plugged it to PC, now MAC won't recognize Drive
look into Disk Warrior...its a hundred bucks, but it is a miracle worker of sorts and might fix everything for you.
the frustrating thing about DW besides its $100, is it takes less than a minute to fix problems I would fret over for weeks
Dec 29, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Computers & Internet Logo
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
