Question about Acer Aspire One PC Notebook
When I try to start io my netbook, it sounds as if the disk is going, like it does when it starts up normally, but the green processing light doesn light up and it starts to sounds as if the disk is 'idling', for lack of a better word. It intermittently tries to get going again, but goes back to idling right away. Any thoughts, this thing was just working 12 hours ago, and has only been in sleep mode between then and when I tried to wake it back up.
    Sergeant:
  • 172 Answers
1. turn off your netbook completely.
2. unplug the ac adapter and remove the battery
3. press the power button for about 5-10 secs
4. plug in the ac without the battery and turn on the system
-if still doesnt work unplug the power cable and press the power button for 5-10 secs
5. turn the netbook upside down
6. locate the memory door and reseat the memory
-make sure that the memory is properly installed from the slot
then put back the memory door and all the screw
7. restart the computer
Posted on Sep 07, 2010
Plotter fails to boot normally.
I would get it repaired by an authorised repairer. Sounds like the IO board has failed.
Jan 07, 2016 | Computers & Internet
My netbook keeps returning to start win normally
try to go to the BIOS setting by pressing F2 or del while in POST (exactly after you press the power button and the screen is on)
try to set the BIOS to it's default setting,save & exit,restart your computer
if it still doesn't work,go to BIOS again and look for something called "boot device priority". it usually placed in advanced settings
then set your hardisk as your 1st boot device. save&exit,restart
Aug 19, 2012 | Acer Aspire One AO532h-2727 Netbook
How go i defrag my asus netbook
Try This:
  1. Open Disk Defragmenter by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking All Programs, clicking Accessories, clicking System Tools, and then clicking Disk Defragmenter. 18abb370-ac1e-4b6b-b663-e028a75bf05b_41.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. Click Defragment Now.
Disk Defragmenter might take from several minutes to a few hours to finish, depending on the size and degree of fragmentation of your hard disk. You can still use your computer during the defragmentation process
Aug 16, 2012 | ASUS Eee 701 Netbook
My DELL XPS dimension Gen 4 wont boot up. The amber light is steady and no diagnostic lights are lit on the back. The processor fan is going at maximum speed. Before this problem I could not plug in a...
The indications are of a NO POST. This can be caused by:
  1. Failed motherboard
  2. Failed Front IO Panel
  3. Damaged IO Panel Cable
If issues connecting USB connections occurred via the front connection, I'd suspect the IO panel as the issue. If the IO panel doesn't resolve, then motherboard is likely failure point.
Jun 27, 2011 | Dell Dimension XPS Gen 4 PC Desktop
Okay so I have an hp pavilion dv6000 laptop. When I turn it on, it says something about new hardware or something. It gives me two choices: start windows normally or let windows fix problem or something....
maybe there is trouble with your hardware go to bios setup and set as default. then start windows normally, if no effect reinstall your OS, maybe will work
Dec 04, 2010 | HP Pavilion dv6000z Notebook
When turning on the netbook it askds to start
You can try repair your windows by inserting the windows disk.
this could solve your problem othewise try reinstalling the os.
Apr 06, 2010 | HP Mini 1000 Netbook
Hp mini wont start
i had a similar problem. this made my netbook start again. turn off your netbook and then remove the battery. then (with the battery still out) slide the power switch into the on-position and hold it there for a minute. then reinsert the battery and turn on your netbook. as soon as it turns on, keep repeatedly pressing the F10 key till you see your screen light up. then login normally and go to the hp site and download the driver for your netbook. i think its under BIOS? hope this helped. sorry if it didnt...
Apr 08, 2009 | HP Mini 1000 Netbook
Dell wont start up
On the back of the chassis, there are 4 LEDs above the PS2 connections marked ABCD what do they indicate? During the boot process the lights normally flash on and off green, when the boot process is complete, they should all be green GGGG.
If any are Amber then they are indicating a power on self test (POST) failure. AAGG is bad memory for example.
Post the indications
Aug 06, 2008 | Dell Dimension 4600 PC Desktop
System does not start
The beeps are error codes and if you listen carfully you will hear a pattern of short and long beeps. If you can identify the pattern we can help you figure out whats going on....
Feb 14, 2007 | Dell OptiPlex GX110 PC Desktop
Acer Aspire One  PC Notebook Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
