Question about Belkin Computers & Internet
I am trying to get a laptop to get connected wireless but it keeps coming up with a passphrase and password and I don't understand why it keeps taking me there and I cannot connect to the internet. And also a certificate authinication and also name.
Silverblade
  • 173 Answers
SOURCE: Losing internet connection when enabling ICS on the wireless network connection
Do not enable ICS on any of the computers that are connected to a router regardless if it's wired or wireless, you only need to enable ICS is if you don't have a router/server on your network(the purpose of a router is to share a single internet connection from your ISP). To connect your computer wirelessly to the router(on a Windows XP computer given that you do not have a 3rd party Wi-fi application installed) is to right click on wireless network connection on the System Tray(lower right hand side of the computer's Desktop near where the clock is) or you can do it the hard way by going to Control Panel then Network Connections and choose view available wireless network and under the list of available network that your computer can detect, select the network name(also called SSID) of your wireless router and try to connect(of course if you enabled Wi-fi security you also need to key-in the security key(WEP/WPA) you configured on your router and that's it both wired and wireless computer/devices connected to the router should work at the same time.
Posted on Nov 05, 2008
  • 134 Answers
SOURCE: authentication failed!
You need to contact your isp for DNS, see:
Click here!
Posted on Feb 19, 2009
  • 628 Answers
SOURCE: Need passphrase from D-Link router DI-524
1. if the default login never been modified b4, u can hook a network cable to the router, type "192.168.0.1" to enter the router config. Once inside, u can edit the password or disable it.
*U may prompt for username (admin) and passsword(empty).
2. If the default login has been modified and u r not able to enter the router config, u can just reset the router by inserting a pin to the small hole to get back the factory default settings. Then u can perform above step again to reconfigure your wireless router.
Posted on Mar 13, 2009
SOURCE: Cant find certificate for wireless
To fix, you go into the properties page of your wireless connection, go to "Wireless Networks" tab and then to Properties of the chosen wireless network you are trying to connect to. Then go to "authentification" tab and untick the box saying "Enable IEEE802.1x to the availiable network" and that should solve your problem
Posted on Jun 16, 2009
govinda123
  • 2260 Answers
SOURCE: I want to connect my iPhone 3G to my home wireless
The security type on the router is WEP.
In this case you will need to use the key 1. that will be the network key for your wireless network.
Check just next to the wireless security tab , you will see wireless MAC filter. It must be disabled. If it is Enabled then disable it and save the settings.
When you try to connect using the WEP key 1 , do you get any error message ?
If you get any error then try $ sign and wep key1.
Click Here for more info
Posted on Nov 23, 2009
Don't know my password
Are you looking for wireless network password or Linksys router password?
If you are trying to connect to the wireless network then it might be asking you for the wireless network key or the passphrase.
You can open the setup page of the router and check the wireless settings.
Read Wireless network key WEP WPA
Dec 12, 2011 | Linksys Wireless-G WRT54G Router
My computer tells me that I have the wrong router model but I'm sure that it's the one it is asking for. It says that NETGEAR doesn't support any other router but WNR1000 or higher and I have a...
it would be easy, first things first. you need to connect your laptop directly to the netgear router. by plugging the ethernet cable on the first slot after the yellow slot on its back. after making sure that we are connected. try to open up internet explorer or mozilla firefox. then type this numbers, " 192.168.1.1 it should ask you for a username and password. username is "admin" all in lower case and password is the word "password" itself. all in lower case. after that it would take you now to the netgear page. then try to check the leftside of the screen and look for wireless settings. make sure you would be on wireless settings. because the other one is advance wireless settings. then create your own network name in SSID. then choose security options as WPA PSK TKIP. then create your own personal password in passphrase. make sure its 8 characters long then click apply settings. then try to access it now then unplugged cable. then try to access website. it should work.
Aug 23, 2011 | NetGear WNR1000 Router
My T40 will not connect to my wireless network at home. I don't know what to do, please help.
Make sure the wireless card driver is installed and working.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jun 12, 2011 | IBM ThinkPad T40 2373 Notebook
We don't know how to connect the router
May 23, 2011 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
I can not seem to remember my password for my WiFi. I have an Ipod touch that I would like to connect to, and it keeps asking me for the password. EVERYTHING I try comes up unable to connect. What am I...
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the Ipos, laptops and orcomputers with these router's wireless settings. Then the Ipod, laptops and desktopcomputers can communicate with your wireless router.
May 06, 2011 | Linksys WRT160N Wireless Router
Trying to connect my wireless epson printer to Netgear router WPN824. When setting up the printer it finds the SSID but after I enter the passphrase and say OK it tells me that the connection is...
Launch a web browser from a computer or wireless device that is connected to your router's network. Type http://routerlogin.net into your web browser's address bar. The user name is adminand the default password is password.
Check or set your WiFi password/passphrase. Here then on any wireless device you want to connect.
if you have 2.4 AND 5.8 ghz you have to set the SSID & passphrase on both.
May 11, 2017 | NetGear Computers & Internet
I am trying to connect my laptop to my hp printer
It's the password you used to setup security in your wireless router.
Feb 02, 2010 | HP Officejet Pro L7680 All-In-One Printer
Passphrase my isp does not have this information either
I understand that you are trying to connect the wireless adapter in your notebook computer to the wireless network being offered by your own router.
Login to your router's web-server, and query the pass-phrase it is using, or reset the pass-phrase.
Oct 31, 2009 | Toshiba Satellite A105 Notebook
Trying to set up laptop internet connection on vista keeps asking for passphrase i do not have this information
the passphrase is a security that is attached to the wireless router you are using, you can contact the person that configured the router to give you the passphrase or you can reset the router to factory setting by pressing the reset botton for 5seconds
TCP connection
hi i two laptop one is sony and is working perfectly with wire connecter to router n with wireless but i buyed another laptop toshiba and try router connection its working brilliant but when i try connecting wireless its keep asking me a network security key or passphrase for zyxel and under that it say the person who set up the password can give u the key or the passphrase
please help me my email is ashwaq_20002001@yahoo.com
Jun 18, 2008 | Zyxel Prestige 660HW Wireless Router...
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
