Question about Homelite Curved Shaft Trimmer Bump Feed Replacement Line
Homelite trimmer F2030 - UT20777. Spool housing/release cover broken. Where to obtain spare parts. This model probably superceeded now.
5 Suggested Answers
  • 313 Answers
SOURCE: Can't find spool replacement AF-150-04
not sure but .065 maybe
Posted on Jul 09, 2008
SOURCE: Worx WG150 Cordless Grass Trimmer spool nut keeps falling off
Thanks for update. Glad you got some resolution.
Would you mind rating my response?
thanks...
Charlie
Posted on May 30, 2009
SOURCE: removing spool from homelite 13 inch electric trimmer
The entire cap does not come off. You push the buttons in on each side and only the very top of the cap comes off.
Posted on Jul 23, 2009
  • 6 Answers
SOURCE: Can't figure out how to replace the trimmer line
Throw the trimmer spool in the garbage and get a Gator head. It will be the best $20.00 you ever spent.
Posted on Mar 31, 2010
Toro tb65ss upper string head removal
  1. Pull the spark plug wire from the top of the spark plug. Bend the wire to the side to prevent accidental starting.
  2. Place trimmer on its side with the trimmer spool head facing you. Press the two tabs on the side of the spool head with your fingers.
  1. Hold side of the head and slowly allow the head cover to push away from the inside of the spool head. There is a spring between the spool head housing and the spool that pushes out when releasing the cover.
  1. Pll the knob and spool out of the spool head. The spring should come out on the back of the spool.
    Electric Trimmer
  1. 1 --> Unplug the Toro trimmer power cord from the electrical outlet.
  2. 2 --> Lay the trimmer on its side. Hold the spool housing tight in one hand and twist the cap counterclockwise with your fingers. If necessary, use a pair of large slip joint pliers to start turning the cap. The cap is the center piece of the spool.
  3. 3 --> Pull the cap off the spool and remove the spool from the housing.
Apr 26, 2014 | Garden
Spool cover need
Norma try Maturi's in Birmingham or Central spares
Sep 29, 2013 | Homelite Curved Shaft Trimmer Bump Feed...
I have a ryobi RWT285DS and the head is not releasing the whire evenly, upon closer inspestion i found the part that the wire is wrapped around is sitting loose. what part am i missing?
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, ff
Jan 08, 2012 | Ryobi Garden
How to change the trimmer line
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, ii
Jan 06, 2012 | Homelite Mighty Lite Lawn Trimmer
My Homelite XH2XS-0254RA Trimmer gas lines have broken off inside the gas tank, can replacement parts be obtained
Hi carlfreeland...
Yes, your fuel lines can be replaced, be sure to get the right size to fit your machine.
Go to your parts supplier with the model/serial number and manufacturer of your weedeater.
Most of the time there will be two size fuel lines, the bigger one is the one the fuel filter inside your tank is connected to.
Please take time to rate me
Jul 03, 2011 | Homelite Expand - It Brushcutter...
Spool cover required for hg500b grass trimmer
Hi, mine broke yesterday (Sovereign HG500B Grass Trimmer). I took the grass trimmer to Homebase but they've told me that this model has been discontinued and they don't sell spare parts for it. I believe it's still within the guarantee period so if I can find the reciept they'll organise some sort of replacement, but if I can find somewhere that sells a replacement spool cover I'd rather just buy that and replace it...so far no luck.
Aug 04, 2010 | Garden
My homelite trimmer string keeps getting stuck and when i tap it to release more string it doesn't the spring in it doesn't spring at all. I constantly have to stop take it apart pull enough string to edge...
It's sticking pretty good. Try what I do: Pull the head off and clean it out pretty good. Also clean where the spool attaches to the trimmer. Before you reassemble it, give it a shot of powdered graphite (I get mine at the hardware store. It's for locks). Reassemble the spool onto the trimmer. Bump it on the ground several times to distribute the graphite within the head. Now, press the head in and pull on the trimmer line. It should dispense a little line and stop, just like when the machine is in operation. If it works, you're done! If it doesn't work, you will need to replace the spool. They are available at the major hardware stores. Even if you have to replace the spool, the graphite trick is a good one. It'll keep the head dispensing line smoothly. I add the graphite probably every 7th or 8th time I rewind the spool.
Best regards, --W/D--
Aug 09, 2009 | Homelite Garden
Removing spool from homelite 13 inch electric trimmer
Jul 05, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Adjusting the start handle
After I get the rope rewound on the spool, I place the spool in the housing pull about 2 inches of rope through the slot in spool and rope end will be facing you. Then wind the spring by turning the spool in the same direction that you would pull to start. Then thread the rope through the starter housing and then tighten keeper that holds the spool in place. If is still will not keep tension, your spring is probably broken.
Apr 11, 2009 | Homelite Garden
Homelite Curved Shaft Trimmer Bump Feed Replacement Line Logo
228 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
