Question about Sony VAIO VGN-SZ330P/B Notebook
Lcd monitor has 3 pink vertical stripes I bought a used Sony Vaio SZ330P; the screen developed a large dead pixel spot, I don't know why. I would like to find a replacement screen.
  • Anonymous Mar 21, 2014
    red and blue pixels on LCD
  • 41 Answers
I have a black line at the top of my screen
THIS DEAD PIXEL.SO THIS IS NOT REPAIRABLE.IT WORK NORMALLY.DON,T FEARING.
Jul 06, 2010 | Acer 22" X223w LCD Monitor
I have my LG LCD flat screen TV, accidentally i bottle of Soda burst on the screen, i wipe it a dried it using a dry cloth, the next morning i have this black spots on my screen, please help
If you are sure its not a stain. then its a dead pixel on your monitor.. sooner or later it will spread out. To be sure if its a dead pixel, run your monitor in different colors, black screen, green, red and blue.. If the spots stays then its dead pixel.. You will be replacing the lcd when time comes that it spreads out.
May 18, 2010 | Televison & Video
LG Flatron L1930B lcd monitor - 3 vert. stripes, center one dead
sounds like the pixel controllers have gone bad or one or more of the color (RGB, RED, GREEN, BLUE) controllers have gone out. this is quite common in lcd monitors/tvs and is usually caused by pressure on the edges of the screen (you grabbed it too tightly when moving the monitor) or just faulty controllers. they are expected to eventually go bad, ask LG for yourself, they will tell you the same thing. If you just bought it, that can be considered a mfr defect that they will replace, IF IT IS IN WARRANTY!!!!! Unfort. there is no fix due to seal that placed on the actual lcd panel inside the plastic casing. Youd spend more money trying to find the part and install it than just buying a new monitor. hate to say it but im an avid gamer and have gone through about 4 lcd monitors in tha past 3 years due to everyday use
Sep 18, 2009 | LG L1930B 19" LCD Monitor
Black spots appeared on 17" LCD Monitor-SyncMaster740N
you might have what you call "dead pixels" or a "stuck pixel" try a simple test like this one now it is not the most creative one, but it does help to see if that is the case. u might be able to Fix a STUCK pixel, but unfortunately you can not fix a "DEAD pixel" simply because it is DEAD.
try this website for simple fix instructions.
if is dead pixel what you have, if u can live with it, great, if not , it might be a good reason to get yourself an another monitor.
Good luck
Jun 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Sony Vaio Laptop Display Screen problem
even if ur in warranty period they wont change ur display so try to take any serivece center and change other wise in any laptop try to get
any help so first just see sony engineer get his assiant usually they use have contact where u can get serviced
Jan 30, 2009 | Computers & Internet
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
hi i have a sony vaio VGN FZ21M DUAL CORE 2 2GHZ 2 G RAM 200 HDD FULL HD DISPLAY AND BLU RAY DISC AND THE LCD IS BROKEN HOW OR WHERE I CAN FIX?? IM IN MIAMI BEACH.
THANK YOU
Apr 17, 2008 | Sony VAIO VGC-LS30E 1.73GHz Pentium Dual...
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
Pink Stripe
I must say thanx to Bogdan, his suggestion really did helped to fix my Dell :D
Only, the hard part was the opening of the case, it has no screws saide the middle behind the holder, but just hidden plastic border pins like on average cheap plastic remote control. After that, and removing few tin shells, second plastic connector ribbon from 10 of them needed a little press by nail and this is it! Thanx again :) I must point out that 2 local dell services said that lcd is unrepairable?!?! But shure, they did not bother to even open the case, or else, I would see the opening marks on plastic.
Mar 28, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Replaced LCD Screen
There 2 diffrent LVDS connectors normally on the monitor. a plat one with contacts on one side and a female connector that accepts pins on the end. I would make sure the connectors match. If that does not fix it I would change out the logic board. Check www.lcdrepair.us for instruction videos and parts for that unit.
Sep 01, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Sony VAIO VGN-SZ330P/B Notebook Logo
307 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
