Question about Sony Handycam CCD-TRV68 Camcorder
When I connect the handicam to the tv there's a low hum. When I press play the hum gets louder and the picture is distorted. Any idea what is causing this?
  • 76 Answers
Could be feed back from the drum assy(video head) going bad. Make sure that the 2 devices, your tv and camcorders audio are in sync by turning the audio all the way up on the camcorder and then turning your tvs audio up as loud as youll listen to it then backing the audio down with the camcorders controls. If that doesnt get it then your video head may be going bad. I hope this helps.
Posted on Sep 06, 2010
  • doremifabulo Sep 06, 2010
    Thanks for the suggestion. I tried it and here's what happened: the hum did not disappear when I turned the camcorder volume down. It did disappear when I turned the tv volume down. Does this mean the video heads are bad?
    I should mention that the hum is not there when I view the video directly on the camera.
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
TV plays fine when dvd recorder is off. As soon as you turn on recorder the picture gets snowy. It doesn't matter whether it is on video 1 or on the channel setting. I have changed all the cables, still...
It seems that you are keeping the recorder close to the TV set resulting distortion in the picture due to power supply hum,check by keeping it away from set if no change than check the reason of hum received from power supply of recorder by replacing electrolytic capacitors for leakage or proper shielding of power supply in side the recorder.
Jan 22, 2011 | Panasonic DMR-ES40V DVD-Video Recorder
I have a Samsung LCD 46" TV, only 4 months old. Almost since the beginning, it has emitted a low hum that varies with the volume. The hum has gotten louder and is audible even during normal TV watching....
And it will get even worst you have a bad color weel good thing is that it is separate from engine in almost all samsungs you will have to disasemble the back of tv butits not to difficult should be coverd under warranty if not repair costs around 230 with labor
Dec 19, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
My television has an annoying hum/buz when annimated movies are playing. The intensity of the hum/buzz varies as the brightness of the tv image changes. What is the problem?
This is waht is known as vision on sound.
Sharp bright edges on the picture such as seen on cartoons, generates high frequency interference which is picked by the sound channel. That is why you get louder infererence when the picture is brighter. There are filters built in to the sound circuits to reduce this. Intensity of the problem depends on the quality of the design.
You could try reducing the contrast level some time called "picture" or if you have a sharpness control reduce sharpness.
Nov 26, 2009 | RCA 27R410T 27" TV
We have sound but no picture i have sound but no picture. when you change inputs the word input is doubled up and distorted
There were not much info in the manual but it did suggest trying this.
1st- Unplug for a few minutes and then plug it back in. Or use the reset button look it up in the manual. MANUAL
2nd- Blank screen troubleshooting
• If you're trying to watch TV, change channels or press the ANTENNA button to switch tuners.
• If you're trying to watch something that's playing on a component connected to the TV (like a DVD or a VCR tape), press the TV
button on the remote, then press INPUT until you get to the correct video input channel.
• If you're trying to watch a component (like your DVD player or VCR), make sure the component connected to the TV is turned on.
• If you're trying to watch a component (like your DVD player or VCR), make sure the component is connected correctly.
Post back if non of these ideas work and explain if there are any lights flashing or changing colors on the front where the green light usually is. A fixya rating would be appreciated, thank you for stopping by Fixya!
Feb 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Sony SLV-D300P Video Distortion
Have you tried pressing the progressive button on the front panel of the player?
Mar 27, 2008 | Sony SLV-D300P DVD Player/VCR
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
Sony Handycam CCD-TRV68 Camcorder Logo
44 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
