Question about Sharp Brown & e Digital Micrometer Micromaster Mm2000
How do I re-set my old Brown & Sharp 0-1" micrometer ? Right now, all the way closed, it is reading .001" So how do I reset it to read .000 when fully closed ?
  • 10,865 Answers
Hi. I recommend that you work directly with company support
http://brownandsharpe.com/contact-tech-support
J.
Posted on Sep 06, 2010
I have a fowler IP54 outside caliper micrometer 7-8" that is zeroed out. There are only 2 keys, a mm/in and zero. How do I reset to have it read 7.0 at 7.0?
Generally, micrometers are "zeroed" to a standard -- an object of a known specific length or diameter. If you have placed a 7-inch standard in the micrometer and brought the spindle into proper contact with that standard, and then zeroed the micrometer at that point, it will be properly set to seven inches. Standard micrometer travel is only one inch, and only that range is usually displayed. The user must then add the standard length to the face display or thimble reading to get the "developed" measurement.
Jan 08, 2015 | Fowler Measuring Tools & Sensors
My HD SAMSUNG HM500JI not work any more bad sector that cany be fix...!!!
Well.. I'm SAD to inform you..your drive has encountered a serious error.
There's a couple of options..none of which you will like.
Drives (SMART) report errors, but sadly don't fix anything. Once a bad-sector has been encountered, its usually an indication of major failure (google/39% of all drives w/bad sectors major failure..etc)
Your options.. Is your data super important--if so, STOP using the drive, send it to a DRC (Data recovery Center), expect to spend $600-1k for the data.
If you've backedup, good news-- drives are cheap.. buy another, plus your drive into tthe 2nd slot, copy off what you can..
the drive itself is having a major failure (meaning it cannot relocate the bad sectors any longer, hence the smart failure)-- meaning-- drives "TRY" to relocate (when they detect failures, they'll move the data else where, mark the bad area, and use a new spot)... Your drive has probably done that.. ALOT. And now... it's gone critical.
BEST solution for you, to save $$ and time.. but a drive ($80-150 bucks)... install your os... put the other drive on the other cable, copy off what you can..and call it a day.
A DRC won't do much more to be honest... if its SUPER critical, contact www.deepspar.com and see if they will recommend you to a DRC locally to you, or do it them selves...again $$$
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
How to reset depth micrometers , any style , easiest method for Mitutoyo line
The nut on the end of each rod is for calibrations. On a clean flat surface check your reading at "0"and see if adjustment is needed either left or right on the nut for getting before zero or after zero readings. Adjust the nut as little as possible and re check for zero multiple times because the nut is sensitive. hope this helps.
Jun 29, 2011 | Mitutoyo Depth Micrometer 0-6"
My TT was imported new from Japan....Has AMAZING video and sound system unfortunateley its all Japanese to me!! The manual that comes with it is about an inch think...Its got built in Navigation system...
I know you can that you can change this by simply hooking up a scan tool for specific year. There are language options accessible for situations like this. Here is a sample of what can be changed using VAG 5052 or equivalent scanners.
Coding
  • 0?xxxxx: Model
    • 1 = Lamborghini
    • 2 = Audi A3 (8P)
    • 3 = Audi A4 (8E)
    • 4 = Audi A4 Cabriolet (8H)
    • 5 = Audi A6 (4B)
    • 6 = Audi TT (8J)
    • 7 = Audi R8 (42)
  • 0x?xxxx: Treble Speaker Monitoring inactive
    • 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
    • 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
  • 0xx?xxx: Sound Characteristic
    • 0 = Sound Characteristic linear
    • 1 = Audi A4 (8E)
    • 2 = Audi A6 (4B)
    • 3 = Audi A4 Cabriolet (8H)
    • 4 = Audi TT (8J)
    • 5 = Audi A3 (8P)
    • 9 = Sound System
  • 0xxx?xx: Telephone/Telematic
    • 1 = Telephone not installed (Remote Feed Voltage for Microphone active)
    • 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
    • 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
    • 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
    • 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
    • 6 = Telematic US (Remote Feed Voltage for Microphone inactive)
    • 7 = Base Plate diagnostic capable with Comfort Control
  • 0xxxx?x: Equipment I
    • 1 = Tuner not installed
    • 2 = Digital-Radio installed
    • 3 = Satellite-Radio installed
    • 4 = Satellite and Digital-Radio installed
    • 5 = Analog Input (AUX) installed
    • 7 = Satellite-Radio & Analog Input (AUX) installed
  • 0xxxxx?: Equipment II
    • 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
    • 2 = TV-Tuner installed
    • 3 = CD-Changer installed
    • 4 = TV-Tuner and CD-Changer installed
    • 5 = Multi-Function Steering Wheel installed
    • 6 = TV-Tuner and Multi-Function Steering Wheel installed
    • 7 = CD-Changer and Multi-Function Steering Wheel installed
    • 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
Adaptation Channel 001: Tire Circumference The tire circumference is beeing adapted in "mm".
Channel 002: Wheel Pulse The wheel pulse describes the amount of wheel pulses per revolution.
If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
  • 43 = Audi A3 (8P) / Audi TT (8J)
  • 45 = Audi A4 (8E)
Channel 003: Language (Screen)
  • 0 = German
  • 1 = English (UK)
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
  • 6 = Portuguese
  • 7 = English (UK)
Channel 004: Back-Up Camera
  • 0 = Back-Up Camera not installed
  • 2 = Back-Up Camera installed
Channel 005: Speed Threshold (Video Input)
  • 0 = max. 0 kph or 0 mph
  • 1 = max 5 kph (Standard for Europe)
Channel 007: Options Channel 008: Volume Characteristic Channel 010: Region
  • 0 = Europe/North America
  • 1 = Australia/South America
  • 2 = South Africa
Channel 011: Language (Speech Recognition)
  • 0 = German
  • 1 = English
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
Channel 018: Start Screen The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding.
  • 0 = Standard Start Screen
  • 1 = Audi S3 Start Screen
  • 2 = Audi S4 Start Screen
  • 3 = Audi RS4 Start Screen
  • 4 = Audi TT Start Screen
  • 5 = Audi R8 Start Screen
Channel 065: Read Test Channel 066: Self Test Channel 067: CD/DVD Drive
  • 000 - Normal/Eject-Button enabled
  • 001 = Eject CD/DVD (will not be saved)
  • 255 = Eject-Button disabled/locked (Anti-Theft-Protection)
Channel 068: Screen Test Values will not be saved, they only act as initiation for each Test Picture.
  • 0 = No Test Picture
  • 1 = Test Picture: Red
  • 2 = Test Picture: Green
  • 3 = Test Picture: Blue
  • 4 = Test Picture: White
  • 5 = Test Picture: Black
  • 6 = Test Picture: Checkerboard
  • 7 = Test Picture: Checkerboard (inverted)
  • 8 = Test Picture: 64 Gray Scales (vertical Bars)
  • 9 = Test Picture: Special
Channel 069: Display Mechanism
  • 000 = Display closed
  • 001 = Display open
  • 200 = Display half open (Obstacle)
  • 255 = Position undefined
Channel 070: Display Brightness
  • 0 = 0% Brightness (Display OFF)
  • 1 = 20% Brightness
  • 2 = 40% Brightness
  • 3 = 60% Brightness
  • 4 = 80% Brightness
  • 5 = 100% Brightness
Channel 099: Transport Mode Only applies to models without Gateway/Diagnostic Interface for Databus.
  • 0 = Transport Mode inactive
  • 1 = Transport Mode active
Channel 111: Reset
  • To perform a system reset/restart save 1 as new value.
Channel 114: FM Frequency
  • Range: 875...1080
Channel 117: Signal Test (Output)
  • 0 = Fader Center & Balance Center
  • 1 = Fader Front & Balance Left
  • 2 = Fader Front & Balance Right
  • 3 = Fader Rear & Balance Left
  • 4 = Fader Rear & Balance Right
Channel 136: Driver Position
  • RNS-E Basic
    • 03226 = Left-Hand-Drive (LHD)
    • 02632 = Right-Hand-Drive (RHD)
  • RNS-E High/US
    • 00005 = Left-Hand-Drive (LHD)
    • 00013 = Right-Hand-Drive (RHD)
Jul 04, 2010 | 2007 Audi TT
I lost my owner's manual and need to know how to reset the micrometer to zero
This is based on an old Brown & Sharp guide book. 1. Carefully clean the measuring surface by pulling a piece of soft paper between the surfaces while the anvil and spindle are in light contact with it. 2. with the anvil and spindle apart, unlock cap with spanner wrench (supplied with unit), then tighten cap lightly with fingers to bring slight tension between thimble and spindle. 3. Bring anvil and spindle together by turning SPINDLE and set zero line on thimble to coincide with line on barrel. 4. Move spindle away from anvil by turning SPINDLE, NOT by turning thimble. 5. Holding thimble only, tighten cap with fingers. Do Not Touch Frame. Lock cap with wrench, still holding thimble only, and adjustment is complete. NOTE: Check zero setting after adjustment is made. Hope this helps
Jun 04, 2010 | Mitutoyo #117 107 0 1 Uni Mike Micrometer...
The locking nut on my micrometer does not lock anymore, can i fix this?
yes. Just remove the screw in the lock, lift the lock arm off its shaft, and reposition at different angle. (put to lock, take off without turning, and set back on at unlocked position...may ned adjusting)
good luck
Mar 28, 2010 | Mitutoyo 0 1".001 Fric/Thimble Mti Outside...
Where/how do you make a calibrated adjustment on a 54-850-001 mictrometer?
Take a piece of paper, insert it between the measuring faces close the instrument using the friction spindle. slip the paper out from the measuring faces. repeat until the paper comes out clean on both sides. Close the instrument using the friction spindle. zero the unit. check the instrument on a calibrated standard like a gauge block or mic standard. It should be right on the money. As far as I know that is the only adjustment required.
Jan 29, 2010 | Fowler 0-1" ELECTRONIC MICROMETER #...
How to reset Mitutoyo 314-351 "V" anvil micrometer. It should not read "0" when turned all the way in.
In order to reset the zero point for your specific micrometer, you will need to have a standard set of pre-set dimensional pin(s). You can check the attached link (page 71 of the Mitotoyo catalog) for the information you need). I guess you could try to find or make a pin with the same dimensions as those noted on the catalog page, but if you're using this in a manufacturing setting, you might have no choice but to purchase a set of gauges for calibrating your micrometer.
The only other option is to contact the manufacturer for an alternative method, but I doubt they'll be able to provide any alternative, as precision setting of the zero point is required for accurate readings with this specialty micrometer.
http://www.mitutoyo.co.jp/eng/products/micrometer/Micrometer_2.pdf
Jul 28, 2009 | Mitutoyo Measuring Tools & Sensors
Thimble on 0"-1" micrometer is tight.
spray some silicone into the thread areaand open and close it a few times.
Mar 04, 2009 | Mitutoyo 0 1".001 Fric/Thimble Mti Outside...
Sharp Brown & e Digital Micrometer Micromaster Mm2000 Logo
226 people viewed this question
Top Sharp Tools & Hardware - Others Experts
john h
Are you a Sharp Tool and Hardware - Other Expert? Answer questions, earn points and help others
