Question about Canon imagePROGRAF iPF8000 Printer
Canon ipf 5000
Error displayed:E141/4046
printer will not work!!!
any help would be very appeciated
rob
  • swamphen May 13, 2008
    hi,
    many thanks for your reply.
    the printer is only 1 1/2 years old,can the problem be repaired or does this mean a new printer?
    even the canon technicians are confused
    thanks
    Brigadier General:
  • 6,966 Answers
Hi
The error indicates "Recovery system rotation count reached 50000" or "end of life". The printer has reached maximum expected printouts.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 13, 2008
  • Louie  Role
    Louie Role May 13, 2008
    Hi again,
    The Service Manual says that any EXX.XXXX error is a Service Call; you need to ask for tech support from Canon authorized techs. However, your post "...even the canon technicians are confused..." means you already did and unfortunately no corrective actions were done. If you can contact them again, you can try asking them to do a firmware upgrade/update using GARO Firmware Update Tool and an L Printer Service Tool. Firmware update/upgrade. Performing an upgrade/update is akin to resetting the 50,000 count down to 0 and/or the end of life back to start of life.
    If you want to try a DIY. Even if the error is "Recovery system rotation count reached 50000" or "end of life", you can always try to fool the printer into thinking that it just started its life or that the 50000 has not been reached. This could be done in Service Mode by doing a clear of all the factory counts and re-initializing the major components.
    Canon IPF5000 printer counts:
    1. the print length;
    2. number of ink tank replacements;
    3. carriage driving time;
    4. number of cleaning operations;
    5. number of cutter operations;
    6. and too many to list
    and stores them in the main controller's EEPROM as a service mode counter. Most would have to be reset back to 0.
    Enter the Service mode following the procedure below.
    i. turn off the printer;
    ii. turn on the printer while holding down the [Paper Source] button and [Information] button]. Keep pressing the above buttons until "Initializing" appears on the display;
    iii. "S" is displayed in the upper right corner of the display showing the version;
    iv. after display of "Online", pressing the [Menu] button displays the SERVICE MODE top menu and the MESSAGE LED flashes.
    The Service mode is added to the options in the Main menu. The Service mode can be entered even in the error status (when an error message is shown on the display) by turning the power off and then using the above key operation. it would be required to manually go through all the counters reset and re-initialize most major components.
    Would appreciate updates on any development (or even the lack of)
    Cheers.
Pf-03 printhead reset
Procedure to enter Service Mode Canon ImagePROGRAF W8400
Turn power off
Hold paper feed button and info button while powering on
Release at initializing screen
Once in service mode, perform a printhead reset.
In Case You Still Having Problem Then Follow Us For On :
Canon Printer Support
Apr 07, 2013 | Canon 2251B003AA PF03 Print Head ONLY...
Canon ipf 750 service mode
i have Canon IPF 750, the display show "execute printhead cleaning, if this message is still displayed, replace the printhead"
somehow actually i just replace the head 5 months ago, and the print quality is still oke before this error issue occured. please help me.. Thank You
Jul 10, 2012 | Canon imagePROGRAF IPF710 Printer
My print head on my canon ipf 605 wont clean??
Hello!
I have printer Canon ipf 605 , on display is displayed print head error, I have put new print head, and the problem is the same, I tryed several print heads , most of them new , and it dont want to start....again and again printhead error is displayed...
Dec 11, 2010 | Canon imagePROGRAF IPF605 Printer
Error code E141-4046
Hi we have a big problem with our Canon IPF 8100 printer. We use it since 1, 1 and 1/2 years. We print 2500 A1 pages every week.
Today the following error appeared:
Error E141-4046
Call for service
We read another post about IPF 5000 and it was written, that it is a page count error.
We entered Service Mode but we don't know what and how to reset.
P.S. the problem is that it's Sunday in our country and none of the service companies work. We have a lot of copies to print.
Please help. And thanks.
Sep 19, 2009 | Canon imagePROGRAF iPF8000 Printer
CANON IPF610 ERROR-CANT ACQUIRE STATUS
There might be a problem with the network settings of the printer canon e40
Aug 21, 2009 | Canon imagePROGRAF iPF8000 Printer
I have a print cartridge for the Canon IPF 5100 that we miss ordered and it is supposed to be for the Canon IPF 5000. Is there a way to use this cartridge on the IPF 5000 or is that not recommended?
Hi ptgraphics
Had a quick look at the cannon web site and the supplies and accessories for both printers are the same.
Yes you can use the cartridge. If you want to double check follow these two links.
IPF5000 http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SNAModelSuppliesTabAct&fcategoryid=860&modelid=14005
IPF5100 http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=180&modelid=15275#SNAModelSuppliesAct
If you are still unsure contact teh supplier where you ordered the cartridge and ask them to exchange it for you.
Regards
Go-Tech
Dec 16, 2008 | Canon Office Equipment & Supplies
Reset Ink Tank for Canon IPF 610
How do you reset the waste ink tank on the IPF700? Would appreciate it if someone could help me.
Thanks
Nov 10, 2008 | Canon imagePROGRAF iPF8000 Printer
Thanks 4 fixing my canon ipf 5000,blodey good job would not be going if it was left up to the technicians. swamp heen
You are more than welcome and glad to be of assistance. I would likewise appreciate if you can rate the posted solution as you see it fit here. Cheers.
May 17, 2008 | Canon imagePROGRAF iPF8000 Printer
Canon imagePROGRAF  iPF8000 Printer Logo
1,298 people viewed this question
old marine
old marine
