Question about Ovens
Please do you have a wiring diagram for dioplomat select 920
How to wire t71th thermostat?
Try here, select thermostat model scrool to the bottom, wiring diagram available
http://www.macspares.co.za/stoves-microwaves/type-591035-71th-thermostat-6mm-shaft-bush-mount
Jun 04, 2014 | Ovens
I have a Zanussi ZHQ575 X Double oven, the main oven will not work when I select the Fan Oven setting. I have tried a new selector switch but it still will not work on this setting. The fan comes on but...
I have the same problem.... It's not the element gents, please read the question again... the oven heats up on the other settings it's just when you select fan oven (the most popular) I too have tried replacing the selector switch with no luck. Really need a wiring diagram.
Apr 14, 2012 | Zanussi ZHQ575 Electric Double Oven
Hi need a manual for a select 920 diplomat oven
I have a Hygena 920 twin oven and grill .The electrical element in the grill started to droop several months ago, now it has stopped working . the element has burnt through. Could this have caused a fire?
I should like to know if it is possible to get a spare element and fit it myself. What would be the cost of the element? Thanking you in anticipation.
Mr J. Walden
Sep 02, 2009 | Ovens
GE J BP27G R1AD Oven Not Heating Fully
Hi Jeff. You should have a wiring diagram with the range. Check for an envelope on the back of the range, inside the back splash, or taped to the inside side wall of the range if you remove the lower drawer. That all being said, first check to see if the start or stop time knobs on the timer have been pushed in (and possibly turned). If the clock runs, it will clear this out within 12 hours, but on these old ranges often times the clock no longer runs. Make sure these knobs are turned until they have "popped" out or you won't get the necessary voltage where you need it. Secondly, when a bake element burns out, it can cause damage to the electrical contacts in the oven selector switch (part number WB22X5122 ) which can be tested with an ohm meter if you can find the electrical diagram. Also, the oven thermostat (part number WB21X5320 ) can be damaged in the same way. Unfortunately, these parts for these old units are not very cheap.
The little bit of heat you are getting in your oven now is most likely only from the 120 volts going to the broiler element when in Bake. During Bake, your bake element should get 240 volts (until thermostat is satisfied). Setting to Broil should give 240 to the broil element.
Dec 14, 2008 | GE Ovens
Wiring diagram for jtp18
Call GE at 1-800-626-2005 to get a wiring diagram
Regards,
Powerman
Oct 26, 2008 | GE Profile JTP18 Electric Single Oven
HOBART AM14F wiring diagram
I can tell you where the wires need to go.What are you trying to hook up on the dishwasher?
Feb 23, 2008 | Ovens
Need wiring diagram for old 1960's General Electric Wall Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Jan 26, 2008 | Ovens
DIPLOMAT SELECT 920/AHY4401 S/S OVEN MANUAL
I have a copy of the Select 920 double oven instruction manual. Send an email to sharemonger@tiscali.co.uk and I will reply with a copy in .pdf file format.
Dec 24, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
