Question about Directed (491C) Remote Control
Need a schematic to find wiring for Remote Programmer Switch on a Directed Electronics model 6200. Trying to program DEI485M Remote to replace the old broken DEI491 Remote. There is no Programmer switch in whole harness. bingo3285@yahoo.com
  • 10,865 Answers
Hello. here is the contact info for your product. Contact the company and they will provide you with whatever you need. http://www.streetperformance.com/index.html?detailedlisting=10794
J.
Posted on Sep 06, 2010
How do you unplug or remove viper remote system
You just need to remove the two connected to the starter wire (ignition switch), and connect the car side of the two together. Then the ignition switch will control the starter again, without interferance.
Mar 26, 2011 | Directed Electronics 479V Remote Gen 2...
We just realized that the previous owners of our vehicle had already installed a Python 1400XPL remote start system, but did not provide the remotes. I was going to try to program my spare remote from my...
Any valet switch will work. Then simply program your remote. As long as you have a DEI remote there should be no problem unless you are trying to program a two way remote (pager) to a one way system (non pager)
Jan 10, 2011 | DEI Python 1400XP Remote Start/Keyless...
I fried my 1400xp, so I purchased a used on on Ebay. How do I program my remotes to work with the new brain?
To program new remotes: turn key to the on position; within 10 seconds, press and release the programming switch one time. Press the switch once more and HOLD. While holding the programming switch, press and release the lock button on the new transmitter. Once the code is learned, the programming switch can be released. Turn ignition off. Test remote. Repeat as necessary for other transmitters.
Nov 24, 2010 | DEI Python 1400XP Remote Start/Keyless...
Had to change the battery in my Python Keyless Start/Remote and now it wont work. How do I reprogram it
To program remote:
turn ignition on
press and release programming switch once ( the siren/horn will honk once)
press and hold programming switch
while holding programming switch, press lock button on remote ( the unit will chirp/honk to confirm programming)
turn ignition off
test remote
Oct 07, 2010 | DEI Python 1400XP Remote Start/Keyless...
I have a 471t model remote starter, it fires up
Could be one of a couple of things. Tach not programmed properly or wire not connected correctly. Or the immobilizer bypass is not programmed or working properly.
Oct 18, 2009 | DEI Valet Keyless Entry System
Trying to find an affordable replacement key fob for the 1400xp.
thats a good price... never seen em cheaper than $40 programmed, you might find cheaper online, but then you need to program it..
Jan 16, 2009 | DEI Python 1400XP Remote Start/Keyless...
Remote went through washer and dryer...Does not work. Does the system have to be rewired or can I just purchase a new remote
you need to purchase a new remote and the program the transmitter to the brain. it is real easy. but make sure that you purchase the same model of transmiter.
Jan 03, 2009 | DEI Python 1400XP Remote Start/Keyless...
Car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Dec 16, 2008 | DEI Valet Keyless Entry System
Directed (491C) Remote Control Logo
24 people viewed this question
Top Directed Televison & Video Experts
ted dux
Christopher Stearns
Are you a Directed Televison and Video Expert? Answer questions, earn points and help others
