Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
It is running but the screen says: uL, what does this mean?
    President:
  • 1,932 Answers
Hi
This means unbalanced load.Please put the load properly and start the cycle.
Thank You
Posted on Sep 06, 2010
  • Toby Gomes Oct 24, 2010
    This is not the solution to the unbalanced load problem. If the machine detects an unbalanced load, why would it flash UL and THEN do an automatic load distribution routine. Would it not do the routine first, and if that fails then flash UL? To solve this problem, tilt the machine backwards and lay it flat, using an allen wrench, remove the centre bolt of the motor. pull off the rotor which has all the magnets in it. remove the four bolts which hold the windings and lift windings off. Unplug harness and speed sensor. Look carefullt at plastic onto which windings are housed. You will see cracks in the plastic. There's your problem.
  • miss_spinkee Oct 25, 2010
    I am passing this on to my husband, thank you, this has been driving me nuts. How do we fix it from there if we do in fact see cracks in the plastic?
What does code uL mean. this comes on in the drain spin cycle
Hi, a UL error code means a load not balanced. The washer is running a load-balance correction routine. Please allow the washer to continue. If the dial is flashing and the washer has stopped, redistribute the load, close the lid, and press START/PAUSE.
Aug 14, 2016 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
What does the error code UL mean?
UL means UnLevel. To fix , open door of washer, and redistribute the clothing/laundry in the machine, and press start. It should start spinning again. Sometimes , if you have a overly heavy load of laundry above will not work. What I have done is, put my weight on the machine (upper body laying on the top) until the machine has extracted enough water so the machine will be balanced.
Dec 10, 2015 | Washing Machines
UL error code on frigidaire dishwasher
Thank you for your inquiry, Elizabeth!
I see that your Frigidaire dishwasher is displaying an error code of "UL" and you would like to know what it means. A "UL" error code means that your dishwasher is in relay test mode. You should be able to clear out the error code by pressing cancel and holding down the hi-temp button. If that does not clear out your error code I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. Hopefully this information is helpful. -Matt
Apr 24, 2015 | Frigidaire 24 in. FDB635RF Built-in...
Why does my mr hh300 display UL on the screen. It won't do anything but display UL. The batteries show fully charged. I worked a couple of months ago. Unplugged due to getting new flooring and
UL means "Out of Lock". The synthesizer is having a problem. This can have many causes. Did someone try to modify it for expanded channels, that is mostly what causes this. If the radio is factory original it could be the VCO, the PLL chip or the reference oscillator that is causing the problem. The reference oscillator is the easiest to check; listen on a shortwave receiver if you can hear a carrier coming from the CB at 10.240 MHz (hold the receiver antenna real close to the CB)
Sep 16, 2014 | Radio Communications
What does the message ul mean?
The UL code means a unbalanced load,sometimes it can as easy as leveling the washer,or a odd load such a towels all being on one side of tub and thinner less water retaining sheets being on the other side.
Gene
Aug 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
When washing comforter the ul keeps coming no matter what is dine to level the load?
UL = Unbalanced LoadUL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load.
Jan 08, 2011 | Whirlpool LSQ9500L Top Load Washer
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
In the Spin cycle, after 9 minuts, it will stop with a "UL".
"UL" means "Unbalanced Load" - make sure the washer isn't overloaded first or if you are doing rugs, blankets, or lots of jeans, split the load. You can also try running an empty or light load and see how the machine behaves.
If you still have the problem, you may have some issues with the drum bumpers, etc., but try the easy things first.
Jul 12, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does UL code mean on washer?
What does error code UL mean on digital Kenmore Washer?
Jan 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Unlock my phone
Dear sir, How are you, I'm sending you some codes and I hope these codes will surely help you out.:)
Nokia Code & their function:
  • *3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
  • #3370# Deactivate Enhanced Full Rate Codec (EFR)
  • *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
  • *#4720# With this Nokia code you can deactivate the Half Rate Codec
  • *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
  • *#9999# Phones software version if *#0000# does not work
  • *#06# For checking the International Mobile Equipment Identity (IMEI Number)
  • #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • *#147# This lets you know who called you last (Only vodofone)
  • *#1471# Last call (Only vodofone)
  • *#21# This phone code allows you to check the number that "All Calls" are diverted to
  • *#2640# Displays phone security code in use
  • *#30# Lets you see the private number
  • *#43# Allows you to check the "Call Waiting" status of your cell phone.
  • *#61# Allows you to check the number that "On No Reply" calls are diverted to
  • *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
  • *#67# Allows you to check the number that "On Busy Calls" are diverted to
  • *#67705646# Phone code that removes operator logo on 3310 & 3330
  • *#73# Reset phone timers and game scores
  • *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
  • *#7760# Manufactures code
  • *#7780# Restore factory settings
  • *#8110# Software version for the nokia 8110
  • *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
  • *#94870345123456789# Deactivate the PWM-Mem
  • **21*number# Turn on "All Calls" diverting to the phone number entered
  • **61*number# Turn on "No Reply" diverting to the phone number entered
  • **67*number# Turn on "On Busy" diverting to the phone number entered
    Good Luck. :)
Dec 16, 2009 | Motorola Mobility E770 Cellular Phone
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
185 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
