Question about Garden
I am unable to start CS26. CS26 is RYOBI string trimmer. The starting instructions are being followed exactly, Have tried them verbatim several time. It act acts as though there isn't any fire or any fuel to fire. The fuel bubble is full. Checked shut off switch by flipping it on/off several times. Again, there IS NOT any attempt to START. ANY SUGGESTIONS. By-the-way this unit is , NEW, right out of box. Thanking you in advance.
    Brigadier General:
  • 4,088 Answers
This sounds like a warranty problem--return it to the dealer for warranty repair or replacement. Hope this helps!
Posted on Sep 06, 2010
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
Need service manual for Ryobi Gas Powered String Trimmer CS26
Search ebay prob your best bet for a service manual for cheap
Nov 04, 2013 | Ryobi Garden
Ryobi cs26
Mike it sounds like the head has sheared where it goes onto the shaft. You may be able to get the head off and see if there is any way of re attaching the shaft but it may be tricky. You could use the modelling clay that is also a resin that sets rock hard. (milliput) works for me.
Oct 18, 2013 | Garden
Does the Ryobi, model CS26, curved shaft string trimmer require an air filter? I dropped it the other day and the cover over the carburator popped off revealing a place for an air filter but there was not...
I have the exact same trimmer and mine did not come with an air filter. There is a screen, but that's all. There is nothing in the manual or parts diagram that shows an air filter. In fact, the manual on page 11 says, "For proper performance and long life, keep air filter screen clean".
Jul 05, 2011 | Garden
My Ryobi string trimmer (CS26) starts fine but bogs down when it gets hot.
Try turning high speed screw (furthest out from engine) clockwise 1 quarter turn. Also check spark aresster screen. You will find it at muffler exit. Usually 1 screw holing it in. Remove it and clean, I use a bernzomatic torch to burn out deposits.
Oct 06, 2010 | Garden
Ryobi cs26 won't start
My 39500 will not start. I change the plug and replaced the fuel lins and bubble
Aug 13, 2010 | Ryobi 26CC, 22 In. Hedge Trimmer
How to start a Ryobi Gas trimmer CS26 RY26500B? I
turn switch to on possition press primer bulb 5 to 7 times choke pull rope then turn choke off
Jun 27, 2010 | Garden
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
there is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
May 31, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
833 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
