Question about Pentair 3hp Whisperflo Pool Pump In - Ground
I have a 1hp whisperflo (we24). It became noisy but was still pumping normally so I sent it to get fixed and they changed the bearings. When it came back the flow was down by about half...so much that my salt system is telling me "no flow". They took it back and changed some screws that were broken but it just came back with the same very low flow. It looks as if the impellor is not seated properly. Any suggestion?
  • 990 Answers
Their is a wear ring that goes on the front of the impeller. Be sure that is there and on right. Most people will put this on with the large side against the impeller but it goes on with the large side out. This is so when the pump starts it will slide forward and give you all the pressure you can get. Also make sure you have the "O" ring on the front of the diffuser. It will help to seal and divert the water in the direction it's suppose to go.
Without these on correct the water can go from the pressure side of the impeller around the diffuser and back to the front of the impeller again. Loosing up to 30% of your pressure.
Posted on Sep 06, 2010
Pump high whisperflo 177476
bad bearings replace motor or pump
Jun 23, 2013 | Pentair Intelliflo Pump 4x160
Pentair WhisperFlo 1hp, 230v, Dual Speed won't start in morning
If the high speed side of a two speed pump will not operate it is because there is a problem with the windings on the high side of the motor.
You will need to either take it to a motor shop and have them fix it or replace the complete motor.
RodUS Parts Center888-521-6813
Feb 27, 2013 | Pentair Dual Speed 1hp Full Rated 230v 60...
How to change the start and stop time on a pentair pump
see you tube video on Pentair whisperflo programming it helped me
Jul 09, 2012 | Pentair 1hp Whisperflo Pool Pump In -...
My WhisperFlo 2.0 HP pump is making a shrill sound, can I fix this issue?
More than likely, the bearings are going out on the motor. Usually you'll hear a loud screeching sound when this happens. You have 2 choices here. You can either take the pump to a local repair shop and have the bearings replaced, or you can replace the motor and pump seal. By replacing the bearings only, you're not guaranteed that the motor will last much longer. I always recommend replacing the motor and seal that way you'll be trouble-free for another 4-6 years.
Jun 15, 2011 | Pentair 2.0 Hp Whisperflo Pump
I just had someone look at my WF-6 pump because of a loud whining sound. Everything is running fine, but noisy. They said they believe the bearings are going out and suggested replacing the entire unit for...
You can have the bearings replaced for about $100. It is something that you will have done by a professional. Consult with a local pool store and they should be able to direct you to someone that does that.
Dec 29, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Good morning. Three years ago we had an inground 15,000 gallon salt water pool installed that included a Pentair pump. The last couple of mornings there is a terrrible whine occurring as the pump kicks...
More than likly it's a square flange motor. If the noise is just starting when you take the pump apart you can check the impeller for problems but the most likley is a bearing going bad from a seal leak. If you remove the wires and take the motor with the back half of the pump to a pool store they can diagnose it for you and do the nessary repairs at the shop. Usually they will do this for a small bench fee or for just the price of the nessary parts.
Oct 07, 2010 | Pentair 1hp Whisperflo Pool Pump In -...
Pump is getting very noisy
It's possible your bearings are going bad. If you have or have had a shaft seal leak, the bearings will get progressively louder until the motor seizes. Then it will just hum. You'll need to replace the motor and shaft seal.
Aug 14, 2010 | Pentair 1.0 Hp Whisperflo Pump
Motor is very noisy
Noisy motor indicates bearings on the shaft are going bad. This happens when you have a shaft seal leak and the leaking water is getting to the bearings. Sounds like you need to replace shaft seal and set of shaft bearings. Easy fix is to replace the motor only for about $150.00 for motor replacement. Around $40.00 for seal and bearings and some of your time.
May 31, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Pool pump starts & stops on its own outside of programmed run
There are several potential problems:
  • freeze protection circuit causing pump to start - could be a bad outside air temperature sensor.
  • It is possible the new relay is bad.
  • There could be a short in the control wires to the relay
  • old programming shadow stuck in memory (not likely since you changed the boards)
Yes, the starting and stopping can harm your pump.
Jun 04, 2009 | Pentair 1hp Whisperflo Pool Pump In -...
Pentair 3hp Whisperflo Pool Pump In - Ground Logo
117 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
