Question about Marzocchi Cycling
I own a Marzocchi 55 TST2 Bomber fork. With air pre-load or not, my fork will only compress an inch and a half and it's a 160 MM fork. This happens on and off the trail (manually compressing)
3 Suggested Answers
Coachphil
  • 347 Answers
SOURCE: hi my forks are 2nd
The best thing to do is take your forks into a bike shop that works on suspension and have them take a look. It could be low on oil and/ or air and bottoming out or it could be something more serious.
If you know the year of the fork you can pull an owners manual from the Marzocchi website. They keep a running inventory of all their manuals in PDF, this will also help to diagnose the problem and let you know what you will need to overhaul.
Posted on Apr 07, 2011
dunnbiker
  • 8546 Answers
SOURCE: hello, I have a marzocchi
Look what I found by just Googling "marzocchi atom bomber z2 fork manual"...
http://www.enduroforkseals.com/id12.html
Many manuals including the '98 Z2.
Fixya queries should not replace simple web searches for answers.
Posted on Sep 14, 2011
How much oil should i put back in the fork after a seal change on a 2001 mx 50
The Marzocchi Workshop: oil quantity's & levels
marzocchiworkshop.blogspot.com/p/oil-quantitys-and-levels_858.html
Oil quantity's are measure in volume in 'cc', always use a narrow measuring jug for ...MY, Fork, Measurement, RH, LH .... 2001, Z-1 MCR QR20+ 01, Height (mm), both legs, 50 .... 2003, MX PRO COIL c.105 SSVF, Height (mm), both legs, 50.
Aug 19, 2015 | Motorcycles
Oil level in Marzocchi ET85
I tried to find this for you. Try using the terms you gave on a Browser search for that Title. There are all sorts of Blogs and hits ranging from the TRW company buying Marzocchi to both the gearbox and fork oil sumps.
Seems Marzocchi also was into the electric Power Steering on cars as well as Ducati products. On the Blogs, there were people talking about changing the oil in their units. This would perhaps help you find the quantity and type of lube they used. I did see a 2.5W oil mentioned but it did not show the application.
Hope this helps you.
Dec 26, 2011 | Cars & Trucks
Hello, I have a marzocchi atom bomber z2 forks, believe is a 1998, i'm looking for the manuel for it so i can change the oil on it. thanks Gari
Sep 14, 2011 | Marzocchi Cycling
Hi my forks are 2nd hand off ebay, they are marzocchi dirt jumper 3s and every time you compress them, even slightly, there is a sort of click/knock sound. is this normal or is there something wrong? what...
Apr 07, 2011 | Marzocchi Cycling
How much air pressure should I put in my XC 600 TST2 fork? I weigh 220 lbs.
i adjust mine by feel. go with what's comfortable. try different pressures for different rides, terrains etc.
keep track, ride longer, be comfortable.
Feb 08, 2011 | Marzocchi Cycling
Hi i bought a kona stinky 2008 and the front 66rcv are stiff.how do i release air.do i unscrew the nut on bottom of the fork.also the rebound screw dosent move.any help good thanks.Also how do i get the...
This is most likely not the answer you are looking for, but I would highly recommend taking these into a bike shop that has experience with the Marzocchi's. These are fairly complicated and require some speciality tools, and extremely easy to do damage that will be an expensive fix later.
First red flag is that the rebound screw does not move. A fork overhaul is probably in order, replace the seals and oil, check all the screws too make sure they are not stripped, adjust the air pressure, and so on. The bonus is a shop that can perform this overhaul, will also be happy to show you how to maintain the fork and how to adjust everything properly, and if you don't have a fork pump, sell you that as well. Trust me, these can be challenging without knowing exactly what you are doing, I am highly trained and I still have issues now and then with Suspension Forks.
I have included a video with a Marzocchi tech guy explaining a slightly newer version of your fork, Yours is basically the same.
Here is the link to the Owners Manual for your fork. If this is not correct you can get any manual for any fork they have made off the Marzocchi website under tech.
Dec 21, 2010 | Marzocchi 08 66 Rc3 Mountain Bike...
Hi, i have a pair of marzocchi dj3 currently on my bike and a pair of marzocchi dj2's on my old bike. i would like to change my dj3's back to my dj2 as more travel and suited to my riding uses. although...
The steerer tube is not listed as a separate part, therefore it can't be switched. Considering how critical it is to have strength at that junction it's not surprising that it is integrated.
2012 DJ 2 2012 Forks Marzocchi MTB Suspension
May 10, 2017 | Marzocchi Cycling
Hi, I have a new 2010 "Wheeler" mountain bike with a front suspension from "Marzocchi". On top of the front suspension on the left hand side is the termination of the front suspension locking system wire....
Sure, that fork is (as you've guessed) a Bomber 22 Lo fork. Marzocchi has a product page for it here.
The owners manual doesn't have a parts diagram, but you can use their "Locate a service center" link at the bottom of that page to find an authorized shop near you.
Sep 27, 2010 | Marzocchi Cycling
( I'm Spanish..and leave in Spain)..well...I go change the front whell of my VTX 1800C'02...my mechanic..d'ont know the size of original rim...¡ and I..so ¡¡..(please,sorry my...
Here are all the specs for your bike,Please take time to rate this a fixya.
2003 Honda VTX1800 Retro Spoke
Engine Type: 1795 cc, 4 Stroke - Liquid Cooled - V Twin
Engine Bore and Stroke: 101 mm x 112 mm
Compression Ratio: 9:1
Valves SOHC, 3 valves/cylinder
Carburetion: Programmed Fuel Injection (PGM-FI) with automatic choke
Ignition system:Solid-state digital, two spark plugs per cylinder
Claimed Horse power:107 hp (79.8 kW) @ 5000 rpm
Maximum Torque: 163 Nm (120.2 ft. lbs) @ 3000 rpm
Transmission type: 5 speed
Drive:Shaft
Starting: Electronic
Suspension - Front: 45mm inverted fork, 130 mm travel
Suspension - Rear: Dual shocks with five-position spring-preload adjustability, 100 mm travel
Front Fork - Rake & Trail Angles: 32 / 163 mm (6.4 inches)
Tire- Front: 150/80-17
Tire - Rear: 170/80-15
Brakes- Front:dual 296 mm discs with 3-piston calipers
Brakes - Rear: single 316 mm disc with 3-piston calipers
Overall - Length: 2456 mm (96.7 inches)
Overall - Width: 932 mm (36.7 inches)
Overall - Height: 1128 mm (44.4 inches)
Seat Height: 693 mm (27.3 inches)
Wheelbase 1715 mm (67.5 inches)
Ground clearance 130 mm (5.1 inches)
Fuel Capacity: 17 l (4.5 Gal)
Dry Weight (without fluids): 320 kg (705.5 pounds)
May 16, 2009 | 2003 Honda VTX 1800 Retro Spoke
Cycling Logo
507 people viewed this question
Top Marzocchi Cycling Experts
John Egan
John Egan
Are you a Marzocchi Cycling Expert? Answer questions, earn points and help others
