Question about GE Refrigerators
Ge Model gs23 sounds like the ice maker is making a whistling noise
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
SOURCE: Whisling noise coming out of inside the refrigerator. Louder when freezer door is open. maybe ice maker area?
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Posted on Aug 08, 2009
SOURCE: GE Refrigerator, model PSS26MGPBBB, stop
PROBLEM IS ASSOCIATED WITH THE TEMP SENSOR INSIDE ICE MAKER. I HAVE TRIED TO FIND THE PART, BUT WITH NO LUCK. IT LOOKS LIKE WE WILL HAVE TO PURCHASE A NEW ICE MAKER.
Posted on Aug 15, 2009
  • 152 Answers
SOURCE: GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Posted on Feb 28, 2010
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
Posted on Apr 04, 2010
I have a tfhw24 whistling ge refrigerator and the ice maker is not working. water is not entering, nevertheless the filter is connected to the appliance.
Since this is an older model it would not hurt to replace both the=> WR57X10051 Water Inlet Valve and the=> Ice Maker Assembly WR30X10093 To test feel the ice slots for any remaining cubes if no cubes of ice are there fill the ice maker to the near top and allow to freeze. If after the water is frozen the ice maker cycles and drops the ice in the ice bucket and does not refill with water change the water control valve. If the ice maker does nothing while there is ice remaining in the ice slots replace the Ice Maker
Appliance 911 Sea Breeze
Nov 25, 2015 | GE Refrigerators
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
Very Loud Ice Maker in GE gfss6kkxs Fridge
Sorry to inform you but GE refrigerators are known for their noise making machines. I myself have a GE Profile side by side but will never own another GE product. After repairing appliances GE is better priced than their competition and the reason cheaper made product. Sometimes cheaper doesn't mean better. Outside looks really good but what you don't see is ugly. BB
Jan 20, 2010 | GE Refrigerators
Apr 19, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE Model GSH22KGRBWW has two problems. 1st
Here recently I have run into 2 of these units that do this and have found that the dispenser line is frozen in the freezer door. The way to test this is to remove the kick plate under the doors (It is easiest to open both doors to do this) Disconnect the union in the water line leading to the door by pushing in on the waterline and pulling in on the end of the fitting. When the line is apart, close the doors and push in on the paddle as to fill a cup with water. If you get water out of the line under the door then your line in your door is frozen and you will either need to replace your door or let the unit thaw for 24 hours with the doors open. Cheaper to thaw. If no water comes out under the door when paddle is pressed then you will need to replace the water valve as long as you have 120 volts at the valve when actuated.
I have had some of these same units making noises like this. One I found was leaking water down from the water inlet tube and in behind the ice maker and behind another panel that shoots up to the ice maker and building up behind that panel and causing a whistling sound. Removing the ice build up solved this one problem but couldn't find solution for the problem for the other. Dismissed it to change in the weather and expanding and contracting of the liner of the unit. Hope this helps.
Apr 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
In our 22 cu ft GE SxS fridge /freezer, the freezer fan speeds up and slows down frequently and creates a whoooing sound like a quiet hoot owl when reaching the peak speed of the speed up phase of the ebb...
I have had some of these units making noises like this. One I found was leaking water down from the water inlet tube and in behind the ice maker and behind another panel that shoots up to the ice maker and building up behind that panel and causing a whistling sound. Removing the ice build up solved this one problem but couldn't find solution to the problem for the other. Dismissed it to change in the weather and expanding and contracting of the liner of the unit. Hope this helps.
Apr 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge is whistling
Mine was making a moaning, whistling noise coming from just above the ice maker. It happened when the fan speed changed. I learned on this site that the motherboard was probably defective.
Rather than go thru GE, we found a new one online for 66 bucks. I replaced it in about ten minutes and it's all fixed. Poor materials on the original, but this site was very helpful.
Jan 08, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
