Question about Ruud UBHC Air Conditioner
Compresor make aice - Ruud UBHC Air Conditioner
  • 43,501 Answers
There is low air flow because of a dirty air filter, bad indoor blower motor, or low on charge because of a leak...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 07, 2010
How do i know if my AIC motor is bad?
the idle would be to low or it could stick at a high idle try and clean it and the throttle body
Aug 15, 2012 | Cars & Trucks
Stalls when placed in drive
Have you tried to check your mass airflow sensor? or come carb or injector cleaner? that could be the simplest and cheapest to fix. But first,Do the RPM's increase when you turn on the AC at idle? You idle is controled by the AIC (Air Idle Control). This is that part that is bolted to the drivers side of your intake . The AIC's job is to give you no-touch starting, keep the idle up, and increase idle when you turn on the AC. If it isn't working it will start/stall even in park when its cold. That is a very common problem to have. The AIC usually runs about a hundred bucks. so its best to hope its just the sensor of your carb/injectors need cleaned.
Aug 26, 2010 | 1991 Ford Explorer
I HAVE A PIECE OF EQUIPMENT THAT RUNS AT 75 PSI. I NEED TO BUY A COMPRESSOR THAT WILL HAVE A DUTY CYCLE OF 50%. HOW CAN I SELECT WHAT SIZE COMPRESSOR I NEED?
That is an extremely high pressure. I would firstly check to make sure that THAT is what you need, then MOST compressors have a regulator where you can adjust the pressure required.
It is not so much the pressure you need as the STORAGE of air that you need for a pressure that high. MOST tanks are around the 20 or so litre. To utilise a tool requiring the pressure of 75PSI I suspect you would need a tank of somewhere around the 2-300 litre size or maybe even bigger. But first just make sure that you DO need the 75PSI you mentioned.
Feb 10, 2010 | Air Tools & Compressors
I need an instruction manual for my 4-qt ice cream maker, model AIC-204EM
Hello there
please refer to these links ok
best regards michel
  1. Aroma AIC-304EM Learn more about the Aroma AIC-304EM before you decide to buy. Download User Guide and Manual ... Find best prices for AIC including Aroma AIC204EM 4 Quart Ice ...www.retrevo.com/s/Aroma-AIC-304EM-review-manual/id/21195dj098/t/1-2 - 58k - Cached
  2. Aroma AIC-107 ... 107 before you decide to buy. Download User Guide and Manual ... I Heart my Pets Stainless Steel Italian Charm Link, Aroma AIC204EM 4 Quart Ice ... ice cream. ...www.retrevo.com/s/Aroma-AIC-107-review-manual/id/21195dj096/t/1-2 - 61k - Cached
  3. Aroma AIC204EM 4 Quart Ice Cream Maker Aroma AIC204EM 4 Quart Ice Cream Maker - Add to the festive mood of any barbeque, ... parts make cleanup a snap, and a recipe book and instruction manual are included. ...www.showroomsdirect.com/p~p-43779176.aspx - Cached
Sep 15, 2009 | Aroma AIC204EM 4 Quart Ice Cream Maker
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
Fridge freezer not working/power ok,
If the compresor is very hot and won't start,the clicking you heard is the overload at the compresor that goes on & off beacause the relay ,that makes the compresor start is bad or the compresor is bad ,if you know how check the compresors coil if not try replacing the relay with a same replacement(no more than $20 or $30) if still won't start the compresor needs to be replaced.
Apr 24, 2009 | Refrigerators
Ruud UBHC Air Conditioner Logo
35 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
