Question about Electrolux Refrigerators
Electrolux RM212,F, wont cool on gas but appears to be ok on electric. The flame lights but can only feel a slight chill in the freezer box, and the flame does not seem to adjust with the control.
Posted on Jun 09, 2008
Dometic 3way fridge model RM2350R. the fridge works ok, but when i run it on gas the flame lights first time, but the flame indicater does not work,the thermocuple has the right ajustment,is clean,wh
The flame indicator works on very low voltages from electricity generated via the thermocouple. Check the connections and if OK, I would say you are correct in assuming the indicator has failed. These are very sensitive and a bit of a knock can damage them. Try Dometic or Electrolux for a replacement indicator.
Nov 21, 2014 | Dometic Refrigerators
Electrolux rm212 knob replacement
assemble any thermostat switch.all work one.
May 30, 2012 | Electrolux Frigidaire Fridge Defrost Timer...
We have just bought this Refrigerator and when we plugged it to the electrical wall socket, both the fridge and freezer was not cooling, but the inner light was on.Please what was the problem?
Set the temperature control to the coldest
temperature and wait for an hour. The
freezer should get slightly chilled and the
motor should run smoothly.
Jan 02, 2011 | Samsung RS2630SH Side by Side Refrigerator
I have 660 hobby van and a electrolux fridge gas and electric, when you turn it on with electric nothing happens when you try gas i can hear it light but the fridge does not get cold please can you help
Hi , I am guessing this is a kind of RV. If it is, I am wondering if you just got it?? If you did just get it then I will say that those kinds of Refrigerators can take up to four hours to show good cooling. Just a thought. Wayne
May 21, 2010 | Electrolux Freezers
Any info on electrolux RA1300 gas fridge. Freezer works well but fridge compartment doesn't chill
If you had an electric fridge the problem is usually the evaporator fan motor ($30).
I suspect that you may have the same problem. Generally, freezers are cooled only, when the fridge needs cooling, the evaporator fan comes on and blows cold air from the freezer to the fridge compartment. The advice below is for an electric fridge but may also work for you, it's worth a try I suppose.
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Available from a parts supplier or electric motor company.
Unplug fridge, or disconnect gas etc. Fan should be located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Nov 10, 2009 | Electronics - Others
Refrigerator isn't very cold- drinks are just slightly chilled
Usually caused by failure of defrost system, Air ports from freezer to fridge blocked by ice
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 23, 2009 | Whirlpool Refrigerators
Dometic RM2607
It sounds like the thermocouple is either faulty or incorrectly installed. In other words the sensor bulb may be very slightly to far away from the flame to get sufficient temperature to keep the gas flowing. This is a safety device to cut off gas supply should the flame blow out. But if you are parked at a bit of an angle, the flame will also angle away from the sensor, causing it to shut off gas supply. With regards the freezer being temperamental, this is a strange one, because on this model of fridge/freezer, the actual cooling starts from the freezer coil and ends in the fridge. Try to check the thermocouple first. Also be sure there is nothing obstructing the flame.
Apr 15, 2009 | Refrigerators
Freezer working ok, fridge not chilling well - slightly cool but no temperature change
check for a frosted over evaperator, the cooling part in your freezer. check for airflow to your referidgerator
Nov 04, 2008 | Bosch Refrigerators
We have caravan electrolux rm 4230 light is on for 240 chilling, but fridge does not cool. appliance does however cool fine on gas.
Problem is either thermostat or heating element...not sure which yet..but found website supplying most usable parts for RM series fridges. Hope this link is of use.$$6.aspx
Jul 05, 2008 | Electrolux Refrigerators
Refrigerators Logo
926 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
