Question about LG KG800 Cellular Phone
Camera problem my camera has turend al blue, i have tried all the settings, i think its screwed up, all settings seems fine..... is there any way to get my camera working fine again
  • rudyani May 14, 2008
    hi thank for your reply, i have tried that before but to no use, an now my camera screen just goes green, no pic at all, after some research i think its the flex cable causing it.
    tried again the modes and things no use, and added to that from yesterday my camera screen goes all green with no visible pic, after some more research i have come to final conclusion its the flex cable causing this for sure.
  • 41 Answers
When on camera mode change the setting to the different picture settings as in black and white, sepia go through 2 or 3 of them
take a picture, then put it back to normal, let me know on how it goes.
Posted on May 13, 2008
Projector clocked 1000 hours roughly and working fine. However 1 day I tried to turn it own and seems completely dead. no blue light. fuse r al good
Does this projector have an automatic timer that doesn't allow it to turn on after a set number of hours (@ 1000)? If so, you may need to re-set the lamp-hour clock (as if you changed the lamp even though you didn't). Some machines require you to at least slide open the lamp cover to make it think that you changed it.
Feb 13, 2016 | ViewSonic PJD6251 3D DLP Projector
My screen is blue but it sounds like it takes photographs how to fix?
Have the camera been bumped into something ? Or have it received a lot of temperature change ?
Oct 24, 2015 | Nikon D3000 Digital Camera
Problem with color on my lumix dmc-fh25 camera
Set the camera's white balance to match the lighting. Most indoor lighting has a yellowish cast to it, while by default cameras are set for sunlight.
Jan 10, 2013 | Panasonic Cameras
Nikon F3's light meter always underexposed
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Mar 06, 2010 | Nikon F3/T 35mm SLR Camera
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Kodak Z1285 Won't Turn On?
HAd exactly the same issue! You turn on the camera, lense comes out then the screen goes black (turns off)
The blue light stays on and the only way to get it to turn off is to take out the batteries.
Next time you turn on the device, the blue light comes on and the green led flashes, sometimes it powers down and other times the blue light stays on but you have no screen still. The lense stays out.
I tried the "tap" it approach and it now works fine! My suggestion has always been, if it don't work, kick it!! why didn't I try this with this camera firstly instead of trying all sorts of different button combinations to see if there was some sort of hard reset for it?
Thanks for the advice everyone and happy snapping!! :)
Jul 28, 2008 | Kodak EASYSHARE Z1285 Digital Camera
LCD screen all blue
i think it probably happened because either you let it be under direct sunlight, that can screw it up
or, your not pressing play
or, you color setting for your lcd screen is messed up and all the red and green colors were taken out, change it menu
check the color, if not try pressing play, or its messed up have sony repair it
Mar 25, 2008 | Sony DCR-DVD602E DVD Camcorder
Blue outside shots
colour combination seems to have gone wrong
all the outside shots looks blue because i think the adjustments for that shot has not been configured
Jan 05, 2008 | Sony Cyber-Shot DSC-S75 Digital Camera
Trv138
I had the same problem with the DCR-TRV250 where it just stopped playing back tapes. It appeared to be recording correctly but upon playing it back, all I got was the blue screen. I tested the USB, SVideo, and DV outputs and got the same blue screen.
After weeks of deliberating, I finally decided to try cleaning the heads and that cured it! I removed the screws that allowed me to remove the transport assembly cover, which made it easier to reach the heads with a Qtip. I cleaned them using rubbing alcohol and everything seems fine now.
Dec 06, 2007 | Sony Video Cameras
Images seem over-exposed
Time for a new one I guess- too old to consider remedial work.
May 17, 2007 | Casio QV-R40 Digital Camera
LG KG800 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
