Question about Ford Tractor Naa Golden Jubilee Emblem
I have a ford 801 desiel tractor that i cant get the fuel to come out of the pump to the injector what could it be
dgjtex
  • 405 Answers
SOURCE: 1993 ford escort wagon,no electric to injectors
The fuel delivery system uses an electric fuel pump to provide high-pressure fuel to the fuel injectors. The fuel pump is located at the rear of the vehicle, mounted in the fuel tank. It can be accessed by removing the rear seat.
The fuel tubes leading from the fuel tank to the engine are under pressure during vehicle operation. When the engine is turned OFF, the fuel in the fuel tubes remains pressurized for long periods of time to provide quick start-ups. Fuel not used by the fuel injectors during operation is routed back to the fuel tank through the fuel return tube.
The fuel handling components are protected by three fuel filters. A replaceable in-line fuel filter is located inside the engine compartment between the fuel tank and fuel injection supply manifold. A serviceable filter screen is located inside the fuel tank at the fuel pump inlet. A non-serviceable filter screen is incorporated into each fuel injector.
I can get you trouble shooting tips if you want them.
58866017
125387887
Posted on Dec 28, 2008
  • 1779 Answers
SOURCE: 1988 ford truck f-150 xlt lariat cant get current to fuel pump
Have you checked the 'inertia switch' which in the event of an accident shuts off the fuel supply to prevent a fire . It's usually located in the cab on pass. side. Some models have one reset button, some 2 which have to be pressed at the same time. If that's not it, here's how the power to the pump SHOULD work, you will have to follow the path to see where it stops. When you turn the key on it turns on the EEC power relay on, this relay then provides power to the PCM (power control module) and the control side of the fuel pump relay. Power for the fuel pump is supplied through a fuse link or high current fuse attached to the starter solenoid (battery side). From the fuse link or high current fuse current flows thru the fuel pump relay and inertia switch to the fuel pump. The fuel pump relay is controlled by the PCM. When the ignition switch is turned on the fuel pump will operate, if the switch is NOT turned to start position, the PCM will shut off the fuel pump off after 1 second. This is to avoid flooding the engine when it is not running, just key on. So check out to see if you have a fuse link or a high current fuse and if they are blown.
Posted on Apr 15, 2009
  • 122 Answers
SOURCE: ford explorer no fuel coming through
disconnect fuel filter on flow side turn key on if it spits fuel you should check the sparkplugs and injectors for propper spray pattern
Posted on Jun 05, 2009
alicantecoli
  • 22219 Answers
SOURCE: 90 ford escort 1.9 no fuel to the fuel injector,
is this vehicle petrol or diesel ??? 1.9 is a diesel ,1.6 is a petrol so am i to assume this is a diesel vehicle?? if it it a diesel then check the primer on top of the fuel filter ,it a thin rubber membrane and they split very often ,try pumping it and diesel leaks renew it.
Posted on Sep 20, 2009
Testimonial: "it is gasoline 1.9ltr thanks"
SOURCE: injectors not getting fuel
i have an 88 chevy truck, not getting gas to come out of injectors.. getting gas all the way through the lines all the way up to the tbi but not out of injectors. pressure gage check done! new fuel regulator done! . u can put gas in the throttle body and it fires right up.??
Posted on Dec 27, 2009
My 8n ford tractor blade is slow going up and down and sometimes wont drop at all unless use draft lever.
I would suggest you contact Rob Rinaldi with Ford N-News magazine. infon@n-news.com if he can't answer your problem I'm sure he knows someone who can. News The Magazine for the Ford Tractor Enthusiast
Feb 21, 2015 | Ford 8N Tractor
I am not gettin any fuel to the injectors i was driving the tractor and it just shut off could any one help its on a 1700 ford tractor
Try looking at fuel pump, check fuses, test for power to pump, is power to pump the more than likely failed pump.
Oct 06, 2014 | Cars & Trucks
How to change injector pump on a ford tractor 4600.
You will have to get a work shop manual to set the timing marks correctly.
Aug 23, 2014 | Cars & Trucks
Cambelt timing marks 4jx1
sounds like the injector sleeve O rings have failed this was common.
if you put a clear plastic piece of hose on supply line for diesel fuel filter to head fitting at front and fuel is not black but normal diesel colour thats good.
then put clear hose on return line fitting at rear of cylinder head and fuel is now darker, engine oil is by passing injector sleeve top O rings and entering into fuel gallery in head.
rocker cover, injector rail, injectors need removing and injector sleeves need replacing as well as O rings and seats.
a special tool is needed to remove the injector sleeves out of the head. you will also need to drain the cooling system before removing the injector sleeves, so coolant is also needed.
dealers have special tool for injector sleeves
Mar 28, 2014 | 1998 Isuzu Trooper
How to remove a diesel injector pump off. 1972 model ford tractor
First you'll want to put the engine on TDC with # 1 piston. then remove the injector line from the pump. then remove injector pump flange bolts. If the pump does'nt come off still then look for a bolt coming in from the front side of the injector pump drive gear. I could probably give you a little better description if I new exactly what model Ford tractor you have. I was a mechanic at a Ford/ New Holland dealership in 2011. I hope this info helps, good luck.
Mar 15, 2014 | Ford Tractor Naa Golden Jubilee Emblem
I need a diagram for a 1962 ford 2000 industrial diesel tractor fuel system, injector lines, fuel pump, tank, return lines. Thanks
The best place to get this will be from a ford tractor dealer or from a tractor manual.The good thing about this is that most tractor engine ran similar fuel system set up so if you another tractor of the same age and HP you will probable be able to see how things are set out
Feb 20, 2013 | Cars & Trucks
Can,t get injector pump to inject desiel
if you have fuel at the pump and you crack of an injector pipe and dont have fuel at the injector the chances are the pump is at fault
Feb 22, 2011 | Volkswagen Camper Cars & Trucks
Fuel pump or fuel line blocked?? toyota surf
most definitly the fuel pump. but good news, there is a fuel pump shut off switch located on the vehicle somewhere (on most models). check with your local parts store and they will be able to tell you if there is one or not. try this site (autozone znet.com) it will answer any question you have.
Nov 29, 2008 | 1990 Toyota Pickup
1999 dodge truck desiel auto surging between 30 and 40 mph between 300 to 400 rpms almost like its shifting up and down in gears
it could either be bad injectors or the injector pump could be bad, first try jsut changeing the fuel filter. then go to the injectors and if that dont fix it its got to the injector pump.
Aug 01, 2008 | 1997 Dodge Ram 2500 Club Cab
Ford Tractor Naa Golden Jubilee Emblem Logo
59 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
