Question about Refrigerators
Cant bring the temp down using set button. - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Posted on Sep 06, 2010
Setting an ultronic touch screen alarm clock
TD00552: 12 hr--military time toggle= tap time set button. Set time= hold down time set button till up & down arrows show on r & l sides; set hour, tap time set button, then set minutes, repeat, seconds, repeat. Date change= tap hour if needed to show day & month; then hold set button on left till up & down buttons show at edges of screen. Up/down buttons to set year on lower right screen, tap set again to change # day of month, tap set again to change month, and the day will correct itself. Change temp c° -- f°= tap alarm button if needed to display temp b them tap set button next to it to change temp scale. Alarm- off/on= tap screen button if needed to show alarm time; tap alarm set button next to it- it will toggle on/off. To set= with alarm time showering, hold down alarm set button till up/down buttons show; follow same process as above.
You are all welcome ??
Jul 01, 2017 | Televison & Video
Fedders Air conditioner
Try a hard reset first.Disconnect the machine for about 30 minutes and reconnect after that to see if the issue is resolved.
Jun 07, 2008 | Fedders A6P09S2A Air Conditioner
I want to connect my tv to wifi but i couldn't find the setup menu
first your tv needs to be a "smart" type tv set this has both a wired network connection and a wifi connection if it does not have this you will need a converter , you will need your routers password , as you will need to authorize the tv in the routers set up (yes even if you have a dhcp router ) , turn tv on if your using a universal remote most times they cant access the tv set-up menu (on purpose ???) anyways find the tiny buttons along edge to set id bet its near the power button , till you find "menu" press this it will bring up a new screen on tv , use your up/down arrows on remote to go to network , press enter on remote this will bring up a new screen , select "enable" on wireless network an press enter key , this will bring up a new screen it should after a few minutes show a list of routers It can "see" select your routers name using up/down arrows on remote and press enter , a password prompt should show up , enter the network password (from router) and press enter when done , takes a few moments but it should finally say connected (if you did it right ) then exit out of this and bring up "browser" from your menu , this will look like a normal pc browser an you can enter your destination from there , this is a general set up method your tv might be slightly different but this shows suspected path to follow
Jan 22, 2016 | Televison & Video
It is increasing temp 2 hours before scheduled
Most programmable thermostats are "smart stats" which use a programmed algorithm base on a preprogrammed P (proportional) I (Integral) D (derivative) Loop. To make a long story short, the programmed temperature will make the room that temperature by the programmed time. This is based on how long it has taken it in the past to bring the room up or down to temperature. So if your setpoint is 70, and your set time is 7 AM, then the furnace or AC will bring the room to that temperature by the set time...not start at the set time.
Dec 04, 2013 | Heating & Cooling
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
I have NGC tornado Turbochef, it is toasting too
the subway ovens are supposed to be around 1000 dont change any of the settings if you think you are having programming issues speak to your field rep and ask them to reprogram your oven. they have a smart card for doing this. it will give you all the latest buttons including hashbrowns and breakfast stuff.
most common problem with toasting to dark is that you are using the wrong buttons
try cooking the next sandwich on the 1meat hotwell setting and select the sandwich size. you will notice the sandwich cooks much lighter.
if you cook using the combo subs button this could be your problem. most of the time re-training is just needed
Dec 11, 2009 | TurboChef TORNADO Electric Oven
Cant get the dmtech lq17xts tv's freeview to work
General reset procedure for DM tech is:
1. Have Analogue station showing,
2. Press display button on remote,
3. With display info panel in view on screen, press 1 1 Line buttons on remote, this should bring up reset menu on left hand side of screen.
4. use up/down arrow buttons on remote to select either Reset or EEPROM then use right arrow button on remote to select the appropriate procedure
NB - on my set, selecting OFF the annoying melody that plays when the TV is turned ON/OFF diasbles Digital TV (Freeview). Turning ON the annoying melody makes DigiTV work again!
Jun 24, 2009 | Televison & Video
Cant close down my acer laptop have to use the power button each time?
ou might want to run a spyware/virus scan. Seems like some process is running that your system can't kill during the shutdown process.While you're at it, you also might want to check your startup environment and see if there's anything in there that shouldn't. Clean out your temp folders...
c:\documents and settings\<your account>\local settings\temp
c:\documents and settings\<your account>\local settings\temporary internet files\
...and install current patches & hotfixes.and for more info contact
Jun 20, 2009 | Acer Aspire 5535-5050 Notebook
How can I change the Resolution?
Olympus has its own way of showing the resolution settings. It is OK once you get used to it. Turn the Camera On. (On the back you will see an OK button surrounded by 4 arrows.) Press the OK button to bring up the menu. Press the left arrow button That should bring up a choice of: TIFF, SHQ, HQ, SQ1, SQ2 Use the up/down arrow buttons to move the cursor to SQ1 Then press the right arrow button That should bring up a choice of settings. Use the up/down buttons to select a setting. I suggest you select 2048x1536 (which is 3 megapixels) Then press the OK button. ................ You should think about getting a memory card with a greater capacity.
Sep 06, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
