Question about Maytag Neptune MAH5500B Front Load Washer
When we use the cold water it is just trickling in. I cleaned the water inlet screen for the cold water on the back of the machine but it is still only a trickle. Is there another screen inside the back panel?
  • Maytag Master
  • 43,501 Answers
Often there is a screen at the inlet of the hose also...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Sep 06, 2010
Cold water trickles in and fills up slowly
You either have a water pressure/flow problem or the inlet screen in your inlet valve is clogged. Remove the cold water hose and use a bucket to check if you have good pressure and flow. If that is good, look and clean the inlet valve screen for debris. Hope this helps.
Oct 26, 2010 | Speed Queen AWS44NW Top Load Washer
Cold water rinse doesn't come in very hard. Just a trickle. Warm works fine. I just had the water shut off due to a water main break which is now fixed and water is back on. Warm wash fills fine. Cold...
Remove the cold water hose and check the screens for debris and clean. Also look inside the water inlet valve where the hose connects there should be a screen in there remove and clean. If this doesn't fix it the water inlet valve will need replacing. Here is a link that will walk you thru cleaning and inspecting the valve http://appliancehelponline.com/topwaterinletvideo.html
Sep 08, 2010 | Kenmore 22422 Top Load Washer
Cold water is trickling in want to clean filter/screen where and how too
There is probably a filter built into the inlet valve where the hose screws onto it. There may be a filter/seal where the hose screws onto the tap. If there is water pressure to the inlet valve, it could be that the inlet valve itself is faulty........Generally a simple job.......Good luck...Nomess
May 16, 2010 | Washing Machines
Only a trickle of cold water coming into washing machine
If there is no other restriction, the water should flow freely from the hose into a bucket as a test. If good, then it must be a restriction in the solenoid valve. Some can be disassembled and cleaned but the valve assembly is not expensive to replace.
Nov 23, 2009 | Kenmore Washing Machines
Ty for being here. I have a kenmore stack washer dryer. Washer is a model 417.94802 301. The hot water feed work fine comming into the machine. However the cold feed only comes in at a trickle. I...
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 05, 2009 | Washing Machines
Cold water into tub of wash machine
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Mar 05, 2009 | Kenmore Washing Machines
Cold water feed into tub seems somewhat pluged.
8. re-try.
Whirlpool washer cold water takes forever to fill
your cold side on water valve may need the screen cleaned.if that doesnt help then you will need to replace your water valve.take hose off cold water side of water valve and you will see the screen.it may have alot of blockage.
Jan 04, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool washer approximately 2 1/2 year old
The screen at the cold water inlet is clogged. Cut off the cold water line and unscrew the line to the washer at the washer. Use a flathead screwdriver and pry out the metal screen that is visible Wash it out in a sink and re-install it. Re-attach the water line,turn it on and your'e good to go. If not you will need a new water inlet valve. These are the only things that can cause your problem unless there is a problem with your cold water supply pressure. Good Luck!!!!!
barneyluc
Oct 03, 2008 | Washing Machines
Water Trickles in When Filling
check the sreens in the hot and cold water valves on the machine make sure there not plugged with rust
Mar 06, 2008 | Roper RAS8445KQ Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
270 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
