Question about Caterpillar American Construction Equipment 1:87 Scale
Cylinder head torque specs for D8H Caterpillar Dozer I need to know the ft pounds of torque for the head bolts on my D8H engine. the engine serial number is 46a26732. need answer asap
Cylinder head to engine block torque sequence and ft lbs
    images for Cylinder head to engine block torque and ...
    More images for Cylinder head to engine block torque and sequence
    Small Block Chevrolet V8 Engine Specs ' Torque Specs ...
    boxwrench.net/specs/chevy_sb.htm
    their specs. Click Here! 3/8 Connecting Rod Bolt, Engine Oil, 45 ft-lbs. 11/32 Connecting Rod Bolt, Engine Oil, 35 ft-lbs. Cylinder Heads. Engine oil. (blind hole).
    [PDF]
Nov 29, 2015 | Cars & Trucks
2000 model mazda 323 astina cylinder head bolt torque specs
Three stages with new bolts (a must), 1st 60 pounds, then 70 pounds then final torque is 80 FT Pounds.
Feb 16, 2012 | Mazda 323 Cars & Trucks
94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
Sep 17, 2009 | 1994 Mazda 2WD B Series Pickup
Escort Mk2 1600 valve and torques settings what are they
cylinder bolt torque settings stage 1 15 ft pounds
stage 2 50 ft pounds
stage 3 85 ft pounds
valve clearences 0.15 - 0.20mm inlet
0.22 - 0.27mm exhaust
these are the figures i have been supplied with, you can also use
cylinder bolts stage 1 10 ft pounds
stage 3 + 90deg.
with my exp, i would use the first guide as the degree method has a tendancy to snap head bolts, especially on older vehicles.
May 12, 2009 | Ford Escort Cars & Trucks
Head gasket torque specs
Here you go, I hope this is what you were looking for:
For 1987-94 models, the cylinder head bolts are tightened in 3 progressive steps. Tighten them in the proper sequence as follows:
Step 1: 50-55 ft. lbs. (68-75 Nm) Step 2: 60-65 ft. lbs. (81-88 Nm) Step 3: 70-85 ft. lbs. (95-115 Nm) Let me know if I can assist you with anything else.
Apr 30, 2009 | Ford F-150 Cars & Trucks
Head bolt torque
They have this listed under a 2007 E-350 but I new it couldn't be. Any how the torque specs are as follows. The big bolts 1-26 are to be torqued first they are torqued to 120 ft. lbs. then rechecked to 120 ft. lbs. Then tightened 1/4 turn or 90 degrees. After that that loosen all the bolts up till the washers are loose again then perform the exact sequence all over again. After that tighten the small bolts on the outside part of the cylinder head all 7 of them to 20 ft. lbs. Good luck.
Apr 11, 2009 | 2007 Ford E-350 Super Duty Length XLT
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Mar 26, 2009 | Craftsman Garden
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
Chevy 5.7 17 bolt heads tork specs
Cylinder Head Bolt (Preferred Method) All Bolts First Pass in Sequence 22 ft.lb Long Bolt Final Pass in Sequence 75 deg. Medium Bolt Final Pass in Sequence 65 deg Short Bolt Final Pass in Sequence 55 deg. Cylinder Head Bolt (Optional On-Vehicle Strategy) First Pass in Sequence 26 ft.lb Second Pass in Sequence 44 ft.lb Final Pass in Sequence 66 ft.lb
Oct 13, 2008 | 1999 Chevrolet C1500
Caterpillar American Construction Equipment 1:87 Scale Logo
351 people viewed this question
Top Caterpillar Toys Experts
fordexpert
Ted Maxwell
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
