Question about Jenn-Air JED8230 Electric Cooktop
I have an older Jenn-Air cooktop (electric).. is there somewhere or someone who can refresh me on how to use the CLEAN feature of this.. i thought i was doing everything right, but it doesnt seem to work.. maybe im missing something, or not doing something right.. OR could something just have went that would make this feature not work anymore......PS.. im not even sure this is the correct Product # as this is 20 years old.....
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
Posted on Feb 08, 2008
Eddie Rentas
  • 59 Answers
SOURCE: jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Posted on Jul 23, 2008
ginko
  • 19396 Answers
SOURCE: Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Posted on Oct 12, 2008
aborcass
  • 2651 Answers
SOURCE: cold air draft
the only way is to block off/check the flapper., if your not going to use for the winter you can disconnect the vent from under the cabinet temporaily and close off there till you can gain access to check outside grill
Posted on Nov 25, 2008
kamal1984
  • 1383 Answers
SOURCE: Need To Replace the Cooktop of my Jenn-Air downdraft
open that two screw also check there is other screw or not?
Also check there is any locksystem if u find any lock then open it then remove the cook top easily.
Posted on Apr 25, 2009
I have a older Jenn air electric cook top and I need to replace the burner element on one side. How do I get the old one out and where do I find parts. JEA 800 ADB
get a gas repairer to check for you or you go back to where u bought it and the burners will be replaced or sold to you if the cooktop is still under one year warranty
Jan 19, 2011 | Jenn-Air JED8230 Electric Cooktop
How do I clean my new electric Jenn-air cooktop with its glass top? Do I need a special cleaner for the glass?
  • Step 1 Wipe up spills as soon as they happen with a clean dry towel. According to the Jenn-Air website, for glass top cooking surfaces, you should do this even if it is hot since it will be harder to clean up later. Be careful not to get burned.
  • Step 2 Use a cooktop cleaner once it is cool. You can also use dishwashing detergent and water or just a baking soda paste (made with water).
  • Step 3 Apply the cleaner to a sponge, cloth or paper towel. For more stubborn stains, you can use a non-abrasive or "scratchless" pad.
  • Step 4 Rub the soiled areas until clean. Rinse well, especially if you used the baking soda paste as that can leave a residue.
  • Step 5 Use a razor blade for burned on and crusty stains that will not come off using the previous methods. Jenn-Air states to hold it at a 30-degree angle to carefully remove the stain.
  • Or you can use this on the link below.
    http://www.amazon.com/Blue-Ribbon-88100-Cooktop-Cleaner/dp/B000HM5INA
    Good Luck and please rate 4 thumbs up for the free answer
    Jun 25, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Do i caulk around my jenn air cooktop?
    hello I assume you mean you are installing a new cook top, You can use caulk but its not easy to clean up after. Normally when I install a new cook top I use plumbers putty to seal it and bed it in. Hope this helps! Mike
    Oct 27, 2009 | Jenn-Air JED8430 Electric Cooktop
    WHAT DO I USE TO CLEAN AN ELECTRIC JENN-AIR CERAMIC COOKTOP; THE BURNT FOOD BUILDUP.
    a good product is CERAMABRYTE. it is designed for ceramic cooktops and is a white lotion type cleaner. if there is a lot of burned buildup you may also need to purchase a special scraper with a blade in it. but make sure you smear the cleanser on FIRST or you will scratch the surface.
    Oct 24, 2009 | Jenn-Air JED8230 Electric Cooktop
    How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
    1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
    Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
    Spot on Jenn Air smooth cook top stove with down draft.
    Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
    Mar 26, 2009 | Jenn-Air JED8430 Electric Cooktop
    I have a new Jenn-air ceramic cooktop- what do I do to clean it.
    Greases lightning is a great cleaner for cooktops and work great on the grease filter it is sold at most stores. Be careful however when cleaning around the control knobs. They do have a rubber dust cover over each switch but if any fluid drips past it and into the switch it could short out the control.
    Jan 31, 2009 | Jenn-Air JED8230 Electric Cooktop
    Melted plastic help!!!!!!!
    While the cook top is cool, use a razor blade scraper to remove most of the melted plastic.  Turn on the cook top to warm the remaining plastic slightly, turn off the cooktop,  and then wipe off the excess.
    Sep 23, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Jenn-Air JED8230 Electric Cooktop Logo
    137 people viewed this question
    Top Jenn-Air Cooktops Experts
    Dan Webster
    Dan Webster
    jason
    Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
