Question about RCA Televison & Video
Is it possible for my RCA DRC290 5-disc player to play each disc in sequence without a prompt from me? If so, how do I program it?
  • 10,594 Answers
You can playback 5 audio disc only in this player continuously because VCD and DVD has inbuilt chapter menus that will halt/ stop the continue operation and wait your chapter selection.
Chapter selection in menu is DVD format design and unavoidable that is why dvd playback gets stop on some stage and wait user command/ selection to playback further files on disc.
Only audio discs can be playback from disc-1 to disc-5 continuously.
Hope these info will help you.
Thanks.
Posted on Sep 06, 2010
Have an LG BH7520 player and cant play my region 2 dvd movies
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your player(region free). However, some DVDs (multi region in particular) will not play, since they require region detection from the player unit.
Sep 23, 2013 | Televison & Video
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Require to unlock Region Codes for an RCA Portable DVD player code DRC6318E. Can you help please
I'm sorry for the difficulties you're experiencing in playing other region disc in the RCA Portable DVD player. Please follow the below steps to unlock the region code and check the operation:
  1. Turn on the player without any disc inside
  2. Enter the code "321 789 456" before the player menu appears
  3. Select 'all' in the appearing list for region free
  4. Turn the player off
Thanks for understanding. Please let me know the result after performing the steps. Also let me know if you require further assistance.
Sep 11, 2011 | RCA DRC6318E Player
Will my rca dvd player, DRC 290 play each of my five dvds in sequence without a prompt from me at the end of each dvd? If so, how do I set this up?
It will not do this during basic playback. You may be able to use the programmed Playback. Press Program when the unit is not playing back a DVD. Then use the numeric input buttons to choose the title or track. Then use the up/down and right left arrows to enter additional titles to playback.
You can find your manual here: http://support.rcaaudiovideo.com/manual.aspx?product=125
I hope this helps.
Sep 06, 2010 | RCA DRC290
RCA DVD player model DRC105N that won't read discs anymore
If the DVD is not reading any CD, then it is often a lens problem.
If th lens cleaner does not work the unit must be taken apart, to clean the lens pickup with isopropyl alcohol and soft cotton tips.
In some case is necessary to replace the lens pickup, as this is defective.
Nov 26, 2008 | RCA DRC105N DVD Player
RCA CDRW 140 dual deck CD recorder
READY
Place cd you want to copy in tray A (EVEN WHEN YOU WANT TO GET ONE SONG COPIED )
Blank Disc in tray B .
Program tacks in any desired sequence
Press the TIME SET / PROGRAM button on recorder or remote..."WAIT" appears then "01" flashes to let you know the unit is ready for the first track.
Enter the first track you want to program using the numbers buttons on the remote .
or SKIP / SEARCH button on recorder.
When the track flashes PRESS TIME SET / PROGRAM on remote or recorder.
to select it , "OK " appears
HOPE THIS IS HELP YOU NEED >> GOOD LUCK
I WISH MINE WOULD WORK IS DOWN AND OUT !
Oct 08, 2008 | RCA CDRW120 2-Disc CD Recorder
Need code for durabrand portable dvd player
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Cd player shuffles through all discs, but won't play
contact Durabrand at 1-800-252-6123 or Venturer Electronic
203 Eggert Rd,Bufflao New York 14215-0248
Dec 23, 2007 | Durabrand W600 Shelf System
1015 Display Flashing #8!
Sounds like you may have a "timing" problem with the changer mechinism. Could be a worn gear or some broken teeth on some gear or some slack in the mesh between gears and it jumped a few teeth. That would explain the doubling up and out of sequence problem with the rack and it might be the problem with it not playing too.
Jun 26, 2007 | Wurlitzer Jukebox 1015 One More Time...
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
