Question about LG WFT1071TP Top Load Washer
MY WASHER IS NOT DOING THE SPIN CICLE, DRAINS ALL THE WATER OK, PUMP IS FINE, JUST DOES NOT SPIN
Are there any solutions here that don't require clicking on one of "D. Floyd Kolb" generalised answers links. By the way, the above link, does NOT address this question.
Posted on Nov 17, 2011
  • LG Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 06, 2010
We just put a drain pump on a samsung top loader and since then it drains and spins but the clothes are stuck to the sides but are still wet.
When a washer is doing it's final spin, there is a short period when water is sprayed into the tub.
It sounds like your washer is spraying water into the tub, during its final spin, for a much longer time than usual
Aug 14, 2016 | Samsung 4.8 Cu. Ft. HighEfficiency TopLoad...
Samsung WA422PRHDWR/AA not draining
i had a the same issue and my fix ended up being the leveling sensor. repair man said if you tilt your washer to far in any direction it throws it off...hmmm
Dec 27, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Willnot spin
You may have a bad lid switch.
Mar 07, 2010 | Maytag Admiral AAV7000A
Machine does not drain and spin at end of cicle It is a LG top loader washing machine model R852
Your motor clutch is bad. That controls on the motor along with the timer on a washer from going to spin or agitate.
Dec 05, 2009 | LG Washing Machines
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Won't advance to spin cycle from drain cycle
install new timer....thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Washing Machines
Washer dryer sticks on j cycle does not spin or drain
check no foreign object stuck in pump impellor and that it turns freely. if that is ok then check continuity thro drain pump. if no muiltimeter, try connecting drain pump to mains direct to see it works
Aug 21, 2008 | Zanussi W1242W Front Load Washer
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Help 3
you need to remove the lower panel on washer the pump pluged up the hose going to the pump from bottom washer can be removed but be aware all the water in washer will go on floor remove what ever in the pump put hose on put in to the spin cycle when done should open
Feb 28, 2008 | Washing Machines
LG WFT1071TP Top Load Washer Logo
157 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
