FixYa.com
Tags:
Intel Server Platform SRKA4
SRKA4 - Interpreting start up beep codes
posted by Tigger908 on May 13, 2008
I'm setting up a SRKA4 server which has been boxed since its purchase in 2000.
At present its beeping but nothing else and though I've searched the documentation I can't find a complete list of beep codes. The current code is 2-2-3-3 but there is nothing in the user documentation on this code.
The error (whaterver it is) prevents the server from reaching the stage where it displays any infomation on screen so I only have the beep code to interperet the error.
At present the machine has 2GB of memory installed in slots A1-A2 ->D1-D2 and a single 500mhz processor but has all the VRM and blank CPU's fitted.
Any assistance would be appreciated.
Glenn
Comment by Tigger908, posted on Jun 16, 2008
I managed to fix the problem myself, turns out it was incompatable memory. The server itself is extreemly picky about the memory you put in it.
At the moment I'm installing drives, but the 9gb drives I have while being recognised are taking and age to format (11 hours and still not done). I'm wondering if there may be a problem.
Glenn
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi ,
1) your server is 8 years old (in box). Many things could be wrong. It could be dead on arrival , damaged in transit , etc.,
2) These beep codes are only released to tech crew . Search their web site for the info.
3) The web site may not have the info (they usually show the up-to-date models only).
4) Find a tech crew to service it.
5) Any new server / equipment must be tested on arrival to make sure they work. Else , you would be paying for goods that are faulty (DOA) , in which case you qualify for one to one exchange. Don't let is just sit there. Test them even though they are not needed immediately due to change of project schedules etc., You can always test , UAT , then box it back up. This way , when you need it quickly , it will probably work. I find this the best way to be ready for quick use.
Good luck
David
Rating Locked! (?) Tigger908 has rated this solution as Thanks for Trying
Can you Help with these Servers problems?
Servers
sxe not work
sir tell me plz my sxe injected... Answer This...
Servers
Hack
Counter Strike Sxe Hack Answer This...
Servers
torrent download problem
I am using internet for last... Answer This...
SRK4A wont power on
Have 3 redundant power... Answer This...
Power modules on Standby
Experienced a severe electrical... Answer This...
Repair Service
Find Server Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
