Question about GE Advantium 120 Convection/Microwave Oven
SCBReplacing interior light bulb on model SCB1001KSS01
  • jackmyers123 Sep 11, 2010
    this is built -in stackable combination
    please have someone contact me
  • 1,040 Answers
Click on this link. It will take you to your microwave. There are 5 different views that you can zoom in on and scan across. You shouldn't have any problem finding out how to do your repairs.
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-SCB1001KSS01/0432/0123100;jsessionid=h9UUDwYyMEfOtjHehA9Nxw**.pdapp403p2
Jim
Posted on Sep 12, 2010
  • Jim Parker
    Jim Parker Sep 16, 2010
    Did this help?
    Jim
  • Jim Parker
    Jim Parker Sep 17, 2010
    I messed up the first link. Copy an paste this one:
    http//www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-SCB1001KSS01/0432/0123100;jsessionid=h9UUDwYyMEfOtjHehA9Nxw**.pdapp403p2
    Jim
  • GE Master
  • 19,396 Answers
Hi.
Replacing the bulb in this oven is fairly easy.
Disconnect power. Undo the single screw holding in place the protective lens panel in front of the light. Replace the light. Put the panel back in place.
The light is part nr 282 in this diagram.
Here part.
Halogen Light Bulb - 120V 20W
Posted on Sep 11, 2010
Change interior light In my ge pvm1870sm3ss microwave
have to take the outer shell off to access the light .
Mar 09, 2016 | GE Microwave Ovens
How to install interior light bulb in ge microwave oven model jvm1490sh02
by removing the outer case is the only way I have seen
Mar 01, 2015 | GE Microwave Ovens
Ge microwave interior light bulb replacement. model #PVM1970SR1SS
Open the cover n you will see the bulb open it by turning it sideways
Sep 12, 2014 | GE Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
How do I change the light bulb in my Advantium Micro Wave. Model is a 120 number SCB1001KSS01. Please send me instructions. Thank you. Karl kflorian5@gmail.com
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 01, 2011 | GE Advantium 120 Convection/Microwave Oven
Microwave light bulb out
This is simple, and "FixYa" technical staff has clearly not looked at our model.
Take off the vent across the top (three long screws) to expose a single screw over the keypad.
Remove the single screw, and the whole keypad consile will lift up and off, likely hanging by a plastic tab/support on the bottom.
Now you can twist the light bulb plug to remove it from the support structure, change the bulb, and replace all that you've done.
Simple.
Feb 07, 2009 | Frigidaire FMV156DC Microwave Oven
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | GE JES1289SK Microwave Oven
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Dec 23, 2007 | GE XL1800 1100 Watts Microwave Oven
Replacing interior light bulb in m/n 63694
On many recent models, it is necessary to remove the mircowave from the wall, then remove the cover to change the cavity bulb. They suggest that only an authoirzed servider replace them, in order to avoid liability. You can enter your actual, full model number (63694 is not enough) and get helpful exploded view drawings and order parts at http://www3.sears.com (the three is correct). Do not handle the bulbs with bare skin, it will shorten their lives. Use a clean dry cloth or gloves.
Apr 29, 2007 | Kenmore 63692 / 63694 / 63699 900 Watts...
GE Advantium 120 Convection/Microwave Oven Logo
227 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
