Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
I overstuffed my washer and now the led reads f du. How can I unlock the door
2 Suggested Answers
  • 1028 Answers
SOURCE: washer keeps reading Du
sounds like lid lock failure clips each side just below top eadge of washer about 3-4 insches from outside edge use stiff putty knife to push clips in and release top should be able to acess switch from there swtich will need replacing
Posted on May 01, 2008
My washer says DU
The DU indicates a door unlock failure which seems to be the problem...I found this answer through google.
you may want to do the same just type it into google.
all I typed in was...what does du mean on a washing machine..
so check it out before you do anything to your door.
Nov 12, 2016 | Washing Machines
Error code " du "
DU = Door Unlock code
Washing machine displays error code F/DU after six attempts to unlock.
-Door lock assembly failed.
-Test door lock switch
-Visually inspect wire harness connection on CCU, Door lock assembly, replace door lock assembly.
The door lock assemble on this washing machine can be replaced from either the top of the front. The door boot can be removed or the top of the washer can be removed.
Hope this helps.
Jun 22, 2011 | Washing Machines
What is DU blinking on a Whirlpool Cabrio washer mean?
'DU' stands for Door Unlock Error. There is likely to be a problem with either the door solenoid/lock or the 'door open/closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Hi. My washer is coding dU then F as codes.. I cant get it to shut off and unlock the door to get cloths out. The book does not have a code for dU.. PLEASE SOMEBODY HELP ME :)
Door unlock error. The machine tried 6 times to unlock the door. Must be an item of clothing jamming the door. take the bottom panel off and reach up and grab the emergency ring, GENTLY release the door amigo. Use this GUIDE for repairs
and use your tech sheet inside that base panel for error codes and diagnostics.
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I overstuffed my GE front load washer and now the door won't unlock. How do I manually override the door lock feature? Thanks!!
Let it run through its cycle. At the end take 1/4 of the clothing out put it aside in a hamper. re run load with some of the clothes taken out. Then washer the other clothes afterwards.
Mar 05, 2010 | GE WSXH208A Front Load Washer
Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHAT IS DU?
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • May 19, 2009 | Kenmore Elite 45986 Front Load Washer
    My front loader washer whirlpool codes fdu and the door won't unlock.
    F/dU error means --------- Door Unlock Error
    A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error. -------- to resolve the error --------- Door Lock Mechanism broken. globul1a.gif Check Door Lock/Switch Assembly for foreign objects globul1a.gif Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
    Apr 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore front loading washer
    brand new and you changed the latch mech.? door latch or lock asm.? DU is door unlock error, it tried to unlock and cant. usually replace lock asm (inside machine) for this problem. may have latch out of alignment.
    Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    23 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Carew
