I have a 1987 renken with a merc 120. im having fuel problems. i changed the fuel filters n spark plugs i only have half throttle when i have a load on it but when just in neutral i have all throttle
  • 4,340 Answers
Your post is in the wrong category. Look into timing chain loosness, and engine timing issues.
Posted on Sep 06, 2010
My troy built riding mower won't run full throttle it only run at about half throttle
if it runs good at half throttle, it just wont throttle up it sounds like the throttle cable has slipped. you might try to adjust it to get full throttle back .but if when you turn it up to full throttle and it dies then you have a choke, carburetor, fuel line, fuel filter or fuel tank problem. hope this gives you an idea.
Mar 29, 2016 | Troy Garden
Xr400r's been stood a while, had trouble starting it, changed the plug, now starts easier but bogs on use of the throttle and only runs with the choke on half, changed the fuel cleaned the main jet but...
Make sure the carb is thoroughly cleaned, all jets not just main. The half choke is compensating for the slow circuit jet. Check your air/fuel mixture. Also, check the air and fuel filter. If all checks out fine and you still encounter the problem, could be : bad gas, wrong spark plug heat range, or most likely the diaphragm for the top of the carb.
Aug 12, 2011 | Honda XR 400R Motorcycles
I have a 1993 Toyota Marino with a 4aFE engine. it's fuel consumption is very poor, 6.5km/liter. I have changed spark plugs, spark plugs reeds, fuel injectors and nothing changing. I checked the check...
Well you got half the tune up done, So replace the fuel filter and air filter. Gets some brake cleaner and clean inside the throttle body. check all the vacuum lines and make sure they are not broke or leaking. Also check the catalitic converter/s, These start clogging and will excessive fuel consumption.
Randy
Apr 21, 2011 | 1993 Toyota Corolla
I have a 1987 wrangler with a fuel injected 6 cyl that will start but will not accelerate. have changed fuel pump & filter, throttle position sensor and air flow sensor. what could the problem be
Check the cap rotor spark plug gap and spark plugs also check the timing get back to me and give me more details sounds smells vibrations
Jan 06, 2011 | 1999 Jeep Wrangler
1987 ford mustang LX 2.3 just started giving me acceleration and stalling problems, ive cleand the throttle body, ive cleand the map sencor, i took out the thermostat completley, changed the fuel pump, the...
make sure the air filter is intact and clean, the engine needs to breathe
do you have fuel pressure?
how about spark, do you have a good spark ?
change plugs and wires
Nov 07, 2017 | 1987 Ford Mustang
Ok again. forget what money i put into it. Right
I dont know if this may help or not but 87-91 jeeps had bulhead and wiring problems at the firewall area,
also had distributor and computer problems. relays were also a problem with tese vehicles. Good luck with your problem
Oct 01, 2009 | Jeep Cherokee Cars & Trucks
Fuel problem
first i would cover the basics. change the fuel filter, next change the spark plugs, careful this car takes special spark plugs. probably have to get from toyota. next clean the throttle body, pull air nozzle off and open the butterfly so you can spray throttle body cleaner in their and clean with toothbrush. also dont be alarmed after cleaning the throttle body and changing the fuel filter it will be hard starting, hold the gas pedal half way.
Jun 07, 2009 | 1993 Toyota Tercel
1987 Chevy Suburban 350 2wd not starting or running right
What size engine do you have in it? And, how many miles on it?? Well, I guess it really doesn't matter. At first thought it sounds like you are experienceing a fuel problem, and changing the throttlebody didn't solve your problem. I would start by looking and checking my fuel delivery system. The fact that you had to spray gas into the throttlebody tells me that fuel is not getting there. I would start with the least expensive thing to fix first. Check your gas filters. These are often , OFTEN, overlooked as a sorce of problems, and are rarely changed and often overlooked, and are the problem alot of the time. If that dosen't cure your problem check your fuel pump. Make sure it is delivering the proper pressure. I would bet your problem would be solved, but if it's not then next I would check the electrical components of your fuel system.
May 12, 2009 | 1987 GMC Suburban
Computers & Internet Logo
David Payne
David Payne
