Question about HP Compaq Pavilion dv6110us Notebook
Was successfully using a linksys compact wireless-G USB adapter to access the net through our wireless Linksys router. Now the computer will not boot and has this message "104-Unsupported wireless network device detected. System Halted. Remove device and restart. removed the adapter and the same message comes up. have pulled the battery and same message. How do I boot into Safe mode? another approach?
  • 12 more comments
  • dwimar Sep 06, 2010
    that is not working. I can press F10 and get to a set up menu
    I have worked with Safe Mode before and have successfully used F8 before. I have tried restarting the computer after waiting 20 seconds and either holding down F8 or repeatedly pressing F8 as soon as the power comes on after hitting the power button. What next? Keep on trying?
    Hitting F8 repeatedly has not brought up Safe Mode and have tried that many times. I put in Office XP disc and it will not load, whether I have it in the CD-ROM drive prior to powering up and after the computer is already powered on.
    As you suggested, I have tried F8 unsuccessfully many times and putting in the XP operating system does not get the machine past the error message, whether I have the CD-ROM in the machine when already powered on or before I power up the machine
    Any suggestions from my last comment?
    I have gone to F10 and in system configuration selected boot options then boot order. I made the CD-ROM the first choice, put the Windows XP disc in and same error messsage pops up. What next?
    Yes, the CD-ROM is first in the boot order. I power on the computer with the XP disc already in the drive, it sounds like the CD-ROM drive starts and then stops and then the same error message comes up.
    Please respond, I have done F10, put the CD-ROM drive as the first bootable drive, shut off the computer, put the Windows XP CD into the drive, restarted the computer and end up at the same error message.
    I have already run the primary hard disk self test - everything passed. I went back into the BIOS set utility using F10 and under the Exit tab the last choice is "Load setup defaults" and it asked "load default configuration now?' I selected enter and hit F10 to save the changes. same error message. what next?
    Ok - recently I purchased a new wireless card and installed it. Like the original one, it also did not work. Maybe the whole issue to begin with was the bios or something. I will follow the directions in the link you sent me and I will be back to let you know the results. Thanks
    Progress - the link you sent me to directed me to remove the wireless network card and update the BIOS. Actually there is a more BIOS update than in that link. With a hardwire connection I downloaded the BIOS update and shut the computer down. I then reinstalled the original wireless network card and powered up. The computer recognized new hardware. I checked device manager and now the network card was displayed and it was enabled with no red x through it. When I check properties, the device status states it is working properly and is enabled. The blue light is on on the front of the computer. Yet the wireless assistant in the tray on the botton right of the desktop has a red X through it and it can not pick up our wireless network and when I right click on the wireless assistant it states the card is disabled. What next?
    I uninstalled the wireless card, shut down the computer, then restarted it. Now the Wireless Assistant is working yet it will not connect. When I right click on the wireless icon in the tray and then view available networks, the message says "Windows cannot configure the wireless connection"
    What do I do with that?
  • dwimar Sep 07, 2010
    Based on the the link you supplied, removing the malfunctioning new wireless card allowed the computer to boot. Updating the BIOS and other drivers from HP, reinstalling the old working wireless card, and the going to services.msc and starting it and making sure automatic was showing, the computer is back to full working condition. Thank you for your help.
  • dwimar Sep 08, 2010
    I am all set. The issue has been worked out successfully with "marked" at FixYa. Thank you.
  • HP Master
  • 6,487 Answers
Base from the description of your problem , Yes Safe mode will be the next thing to do here, To do that power off the computer then once its OFF press the power button to turn it ON and once you press the power continuously press F8 to load the advance boot menu where you can select Safe mode.
Once you load safe mode you can uninstall the software for the wireless adapter.
Posted on Sep 06, 2010
  • 11 more comments
  • Mark Gil
    Mark Gil Sep 06, 2010
    OK lets try this steps then.
    1.Press and hold the power button until your computer turns off completely (that can take several seconds)
    2.Wait 10 to 20 seconds, then push the power button so the computer begins to power up.
    3.As soon as the first screen appears, press F8 over and over again until a menu appears. Compaq computer use F8 to boot into safe mode.
  • Mark Gil
    Yes F8 is the only option to go there , yes try it again repeatedly press F8 as soon as you power it on.
  • Mark Gil
    If still wont load Safe mode and you have a operating system installation CD that will be the next thing to do , repair the system using the operating disc to correct the problem.
  • Mark Gil
    Before you put the XP CD to your drive access first your BIOS and set the first boot device to CD drive and then save the changes on your BIOS and then restart the computer with the XP CD inside the drive.
  • Mark Gil
    Did you already tried changing the boot sequence on your BIOS to load first from the CD drive? That is needed to load the XP CD to repair the system.
  • Mark Gil
    To load your BIOS do these.
    Press the power
    button to turn on the PC.
    When the HP or Compaq logo appears, press F10
    to enter the BIOS Setup.
    Once you have BIOS menu open look for boot sequence or boot priority set CD drive as the first boot device.
  • Mark Gil
    OK let me just first clarify you restart the computer while the XP CD is inside of the drive is that correct?
  • Mark Gil
    Ok this error have cause some corruption on your BIOS that;s why the Safe mode options and XP CD wont load, what we can try now here is to restore your BIOS back to its default settings. Do that once you load BIOS using F10 key.
  • Mark Gil
    The next thing to do here is to update or flash your BIOS you can download it from HP site.
  • Mark Gil
    You can check this link from HP site with this same issue that you have.
    Just click HERE.
  • Mark Gil
    Yes that is possible, no problem just do provide me an update.
  • Mark Gil
    Mark Gil Sep 07, 2010
    OK that is a good progress now, do this Click start > RUN type services.msc hit enter and then services window will load and from there scroll it down and look for wireless zero configuration if you fin it right click on that and click start or restart. then close the window and try to connect again to wireless.
  • Mark Gil
    Good to hear that and happy to help you.
  • 4,281 Answers
First when you power up the computer press F1 or F2 or del or aTL+F2 key to enter in bios then go to boot menu and set first device as your harddrive disable boot from network then save settings and exit from bios. Then check if still same then when you power up the computer press F8 key 5 to 6 times so you can see safe mode and other menu then enter in safe mode. Uninstall wireless driver then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Sep 07, 2010
  • Hi
    For that you need to windows disk for repair windows .
    Insert windows disk into cd /dvd rom then when you power up press F1 or F2 or del or ALT+F2 then you can see bios setup go to boot menu and set first boot device as cd/dvd rom then save settings then it boot with windows disk follow the procedure and choose R for repair windows .
    Then it will work fine.
Linksys router driver for WUSB54GC
Please go here and choose your hardware version. It should say on the card or box.
Thanks
Mar 10, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
I'm trying to find the security key for my Linksys WUSB54GSC. How do I do this? Thanks, Paul
Is there any computer online using the router.
If yes then you can open the router set up page on
that computer.
router set up page is the page where you can check
all the router settings.
Click Here for more information about the routers
and network
Jan 12, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
No power
The light on the adapter indicates if there is network activity.
Check in device manager if the adapter is properly installed. Right click my computer, then select properties. Go to the Hardware tab and click Device manager.
If there is a yellow exclamation point on the USB adapter then you may need to reinstall the Linksys adapter.
If the Linksys adapter is installed properly, then check the wireless network connections if it is connected.
To ensure that you are connected to your wireless network, you will need to know the settings on your wireless router or access-point. Take note of the wireless network name (SSID) and the wireless security and network key.
If you are using the Linksys Wireless Utility, go to Site survey, select your SSID then click connect. Type the network key if wireless security is enabled.
If you are using the default wireless connection on your computer, just right click the wireless network connection icon on the system tray (lower right conner of your screen, near the clock), then select view available wireless networks. Select your SSID, then click connect and type the network key (if wireless security is enabled).
Hope this helps! Good luck!
Jan 03, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Belkin router not giving signal to linksys adapter HELP!!!!!
I dont think belkin has a stable driver for win.7 at this time. I have a belkin n router with a belkin adapter and had no luck.
Some people have had some success using a Vista driver.
You could go to www.bioticaindia.com and download a win 7 driver there. They show a 48% success rate.
Dec 13, 2009 | Belkin Computers & Internet
When I installed my Linksys WUSB54GSC Adapter my computer will not boot up. I have Windows Vista. The computer is new.
Disconnect the usb adapter and see if your computer still boots up. If it does, try connecting the adapter on another usb port and see what happens. If your PC will still not boot up using another usb port, try the adapter on a 2nd computer. If 2nd PC fails to boot up when the adapter is plugged in, most likely the adapter is faulty.
Jul 01, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Failed connection - Linksys Compact Wirless-G WUSB54GSC adapter
1.uninstall the driver
2.restart computer..
3.in the windows..run the cd driver of WUSB54GSC and install...next..next...after that..restart computer...
4.in the windows..insert your linksys usb wireless device...and start using your wireless..
Jan 04, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Linksys Wireless-G problem with Internet connection
Have you tryed unpluging both routers then pluging them back in?
This will refresh your Ip's
Dec 11, 2008 | Linksys Wireless-G WRT54G Router
I have cable modem along with the Linksys wireless - G Broadband Router. Added another PC to my home. Purchased Linksys compact wireless-G USB adapter. Installation went fine and able to connect to the...
You should have an RJ-45 cable connected from your ADSL modem to your router's internet RJ-45 plug then download network magic or similar software to input your user name and password on the router. this way you'll have internet even if your computer is turned off.
Nov 29, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
HP Compaq Pavilion dv6110us Notebook Logo
76 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
