Question about Dometic Rooftop RV Air Conditioner
Ac was not cooling very well,breaker was hot -turned off-reset breaker-ran and cooled good, but would not shut off,the remote would not work-turned breaker offto stop unit -Now nothing works,manuel controls or other wise,breaker checks ok ,it is incorporated with hot water heater,which is 15 left side,ac 20 amp breaker right side.
  • 674 Answers
Turn the breaker on and remove the cover from the A/C and check for proper voltage coming into the unit. If you don't have it the circuit breaker may be bad. If you do have it, set the thermstat to make the A/C try to come on and check the contactor to see if it is pulled in. If it is pulled in, check for voltage on the load side of the contactor. Also check the condition of the contacts, make sure they aren't really burnt or pitted. If it isn't pulled in, check the output of the low voltage transformer. It should be 24vac. If you don't have it verify you have power on the primary side of the transformer. If you have power on the primary and none on the secondary the transformer is bad. If you have 24vac, go to the thermostat and install a jumper between R and Y. If the contactor pulls in with the jumper installed then the thermostat is bad. If the contactor doesn't pull in with the jumper installed, check for 24vac on the contactor coil. Notice you will have line voltage on L1/L2 and low voltage on the coil so use caution. If you have 24vac and a jumper installed and the contactor still isn't pulled in then the contactor is probably bad. You can also check for low or high pressure switches. If the contactor and thermostat is good then check your capacitor. Let me know what you find and I can give you some more suggestions.
Posted on Sep 06, 2010
Rv ac throws breaker. what all is wired to the breaker?
You can narrow it a bit. Turn the ac off and reset the breaker. If it trips then you have a short to ground likely BEFORE the machine. If it does not then it's internal. Only turn the fan on, no heat or cool. If breaker trips then it's in the blower. If not, turn on cooling. If it trips then, likely in compressor. Good luck!
Mar 21, 2017 | Heating & Cooling
How do i shut off hot service light and cool the burner
Good Afternoon Friend,
I understand you want to know how to turn the "Hot" service light, and cool the burner on your Frigidaire cooktop, model# GLEC30S8. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any burner. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire 31 in. GLEC30S8 Electric...
Ac unit wont start
Sounds like a classic case of a burnt/pitted compressor contactor. The contacts can get pitted and sometimes burnt. This can cause them to stick and the unit will not shut off unless you shut off the circuit breaker. When you shut off the circuit breaker, the contacts would have cooled down which could have led to the problem you are now experiencing......will not come on. Open up the electrical box. Look near the bottom for a brown or black part with the wires from your circuit breaker wired directly to it. This is your contactor. In the center is the piece that moves up and down to allow the electricity to go to your compressor and fan motor when there is a call for cooling. Check to see if it looks burnt or otherwise damaged.
Apr 04, 2010 | Carrier 38CKC048 Air Conditioner
The remote control operates intermittenly and there is no other way to shut down the AC
You have a ton and 1/2 split that's running all the time and problems with the remote?I am sure you have changed batteries if it has them. I would shut it off at the breaker until you can have the remote checked out or replaced. I know this would be a pain, to do, but you may have to until the remote is working right. Good Luck
Shastalaker7
Nov 06, 2009 | LG LS-K1830CL Cool Mini Split Air...
The fan is coming on but the compressor is not.Even after the unit has been off all night (long enough to cool down or ice to melt) the compressor does not come on.
All window unit compressor have a thermal breaker mounted on it. It is to protect it from overload. On a hot summer compressor work harder to keep us cool. Sometimes this thermal breaker fails for good. Unplug the ac. Open it, on the compressor there is a bulging thing sometimes cover with rubber. Thats the thermal breaker. Check its continuity. If you don't have an ohmeter, just byspass the two terminal of the thermal breaker with wire. Plug it in, but be carefull, turn on your ac. The compressor should come on.
Jun 27, 2009 | Fedders AED24E7F Wall/Window Air...
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
91 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
