Question about Simmons 511070 4x32 22 MAG Riflescope - Glossy Black
How do I adjust the reticle for a Simmons Mag 4X32 scope. The reticle is not straight up and down and level parallel.
    President:
  • 2,702 Answers
The reticle should be level if its not you need to turn the scope body round in its mounts till it is level and then nip the scope caps up
Posted on Sep 06, 2010
HOW DO I ADUST THE LENS ON BARNETT 4X32 SCOPE
4x32 mm Illuminated Crossbow Scope Owner's Manual - Crosman
https://support.crosman.com/hc/en-us/article_attachments/.../432RGMK-515.pdf
E. Windage (horizontal) Adjustment. F. Objective lens. 2. EYEPIECE FOCUSING. Without using your scope, look at a distant object for several seconds.
[PDF]4x32 Crossbow instructions - Mission Archery
missionarchery.com/wp-content/uploads/2014/07/4x32-Crossbow-instructions.pdf Keep the protective lens covers in place when the scope is not in use. ... This optimum adjustment may also require the rings to be moved along the scope rail.
Barnett Crossbow Scope Review - 4x32mm - HuntingOptics.net
huntingoptics.net/crossbow-scopes-reviews/barnett-crossbow-scope-review-4x32mm/ This is a bit above the curve for 32mm objective lens scopes, so I'd call the field of ... The Barnett 4×32 multi-reticle crossbow scope is very easy to sight in, once ... Thanks for reading my review of the Barnett 4x32 multi-reticle crossbow scope.
How to zero a crossbow scope (Tutorial) - YouTube
? 7:55
https://www.youtube.com/watch?v=Td-qESCt7Gw Nov 7, 2013 - Uploaded by Weaponsandstuff93
How to zero a crossbow compatible scope to shoot accurate groups with bolts. ... Some of them crossbows ...
Sighting in a Crossbow Scope - YouTube
? 3:03
https://www.youtube.com/watch?v=TnOIy1ZTe1U Aug 23, 2012 - Uploaded by Ghostkamo
Easy steps to sight in a Red Dot Scope. ... Just bought a Barnett Ghost 410 and needed to check how to ...
HOW DO I ADUST THE LENS ON BARNETT 4X32 SCOPE - Fixya
www.fixya.com/support/t26743320-adust_lens_barnett_4x32_scope 25 mins ago - If your rifle is taped for scope rings this is a easy thing to do, if you do not have any screw holes on top of the barrel you will have to have a smith ...
Sighting in my Barnett scope - HuntingNet.com Forums
www.huntingnet.com > HuntingNet.com Forums > Archery Forums > Crossbows Sep 1, 2009 - 10 posts - ‎7 authors
I have the Barnett 4x32 Multi Reticle scope and as per the instruction it tells me to set the top reticle line at 10 yards. So after about 10 shots I ...
barnett 4x32 scope Questions & Answers (with Pictures) - Fixya
www.fixya.com > Forum > Tags Get free help, tips & support from top experts on barnett 4x32 scope related issues. ... I have a chipped lens on the inside of the scope how do i get it fixed this will need to be sent to ... How do I adjust the reticle for a Simmons Mag 4X32 ...4X32 ... ADUST THE LENS ON BARNETT 4X32 SCOPE Google Search
Sep 18, 2017 | Optics
I have a Simmons Model ATV 4515 rifle scope. other
Your scope has 5 adjustments:
1. Eye piece focus - used to focus on the reticle.
2. windage adjustment - should be on the R side of the scope, adjusts lateral impact point.
3. Vertical adjustment - the top turret. Adjusts vertical point of impact.
4. Power ring - adjusts the magnification of the scope.
5. AO ring - Parralax adjustment - used to focus the scope at specific distances. Most markings are not exact, you should set it at the range you are shooting and fine tune focus when you look through the scope.
Sep 06, 2013 | Optics
The reticle on my konus pro 4 x 32 does not move when i adjust it
Are you trying to see the reticule move? Or are you shooting after moving the adj screws??? You won't see the reticule move, It only moves maybe 1/4 inch max both ways, If you have a bolt gun, mount the rifle in a vice or a cardboard box with v's cut in it to hold the rifle, aim at a given target app 100 yards away, then sight down the bore, you should be able to see the target, if not, line up the bore, then adj the scope to it, you will be on paper at 100 yards, Try it.,,,,, also, the cross hairs are mounted in a tube that is adjustable, the wires themselves are fixed.
Apr 17, 2012 | KONUSPRO 4X32 MBLK KON7262
Scope insternal adjustments do not do anything. This is the second new scope I have had this problem with. I have borescoped the rifle and no change in either windage or elevation screws over entire...
One of the things about bore sighting is there is no shock to the scope. They are meant to have some shock that goes along with an adjustment. Try smaller adjustments and tap the tube of the scope with a screw driver handle after every adjustment. Not so hard you dent it but hard enough to get stuff moving. Hope this Helps FixYa up.
Aug 24, 2011 | Simmons 511070 4x32 22 MAG Riflescope -...
My 22 mag 4x32 rifle scope not stay on zero inspite of tight mounting .
I don't know what you have done already, but, remember there are two areas to tighten. The scope rings to the scope mounts and the rings themselves around the scope.
you have hopefully forgootten one step.
If not, take it to your local Gun store and I'll bet they won't charge you much if anything for looking at it.
Apr 06, 2011 | Simmons Optics
The elevation adjustment screw will not turn on a simmons 22 MAG mini 4x28. Which way should it turn to raise point of impact? Counterclockwise or Clockwise?
all scopes are marked for up or down with a " u or d" or a
"+ or -" for up and down
just dont forse the turret screws or you will bust the scope
Aug 22, 2010 | Simmons 511070 4x32 22 MAG Riflescope -...
Have no idea how to set up the sight on my air gun
I don't have this particular model. Chances are, those are not "knobs" but caps. Remove the caps as you would remove the caps from a pill bottle. Underneath, you should find the adjustment dials for windage and elevation,
You can download a generic Simmons scope manual here:
http://www.simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Apr 04, 2010 | Simmons 511070 4x32 22 MAG Riflescope -...
Need a manual for a simmons rifle scope model # 1022
When you click on "customer service" on the simmonsoptics.com website, it takes you to the Bushnell customer service web page.
The number for customer service that is given is:
1-888-276-5945
The customer service rep. told me to "go to the Simmons web page".
Which, of course, takes me back to the Bushnell web page. It's a circular race track.......
In my opinion, Simmons/Bushnell has lousy customer service.
I bought a 2nd hand Simmons 3-9X50 scope (model #800479) that needed the screw on caps for the reticle adjustment screws. A small request, I thought.....one that should be easily remedied by calling Simmons/Bushnell customer support.
No dice. Customer support told me to spend $15 to send them the scope, and then they "will have to look around and find something that will fit."
Oh really??? Doesn't Simmons/Bushnell already KNOW the sizes of the parts they have?
Just send me the damn caps. They will cost Simmon/Bushnell no more than a buck apiece.
Then I asked for a user manual for said scope. No dice. The customer support lady told me to find the manual on the Simmons web page.
The Simmons web page doesn't provide user manuals online.
Their customer support needs a lot of improvement.
May 09, 2009 | MAG Simmons 22Mag Rifle Scope 4X 32...
Simmons 511070 4x32 22 MAG Riflescope - Glossy Black Logo
434 people viewed this question
Top Simmons Optics Experts
Mark Campeau
Level 1 Expert
John Hong
John Hong
Ted Maxwell
Are you a Simmons Optic Expert? Answer questions, earn points and help others
