Question about Nokia 6300 Cellular Phone
Nokia 6300 Australia Vodafone requesting restriction code
Hey guys
Can't seem to track down unlocking restriction code for Nokia 6300 with Vodafone Australia IMEI # 353508029865248
Much appreciated if you can help
email jakelsamson@yahoo.com.au
  • 2 more comments
  • Anonymous Jun 01, 2008
    unlock phone restrict nokia 6300
  • gazdrapov Jan 30, 2009
    Hi i cant unlock my nokia 6300 ,it needs an access code? My phone is on o2 and i have an orange sim, my code is 359809018049271
    Yours garry.69@hotmail.co.uk.
    Many Thanks.
  • aguc01 Apr 11, 2009
    Nokia 6300 - Vodafone Australia Locked
    IMEI - 359544011998980
  • dmrm Dec 02, 2012
    Nokia 6300 Australia Vodafone requesting restriction code Hey guys Can't seem to track down unlocking restriction code for Nokia 6300 with Vodafone Australia IMEI # 353215033989119 Much appreciated if you can help email dmrm737@gmail.com
    Problem Solver:
  • 6 Answers
Handset Unlock - Instructions
Please find below the instructions to unlock your handset.
Handset Unlock Procedure for IMEI: 353508029865248
Your unlock code is: 426850229882845
Manufacturer/Model: Nokia_6300
Nokia 6300
PHONE UNLOCK PROCEDURE
PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY UNLOCK PROCESS
This procedure unlocks the handset from being network restricted from only using SIM cards from Vodafone Australia. In case of difficulties, please refer to the FAQ listed below
1. Take note of the unlocking code shown above
2. Insert a Non-Vodafone Australia working SIM card.
3. Ensure the phone is charged and then switch the phone on.
4. Optional Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below)
5. The phone will then display a message. The most common is Phone Restricted”. Select “undo” by pressing the middle soft-key button. (Different message? See FAQ below)
6. Carefully read step 6 before attempting to enter the unlock code. This step has the potential to PERMANENTLY BLOCK YOUR PHONE!
Enter into the phone #pw+ followed by the 15-digit unlocking code then +1# (Unlocking code is shown above). Do not enter the 15-digit IMEI number by mistake
To enter + press the * (star) key two times
To enter p press the * (star) key three times
To enter w press the * (star) key four times
For Example: If your 15-digit unlocking code is 123456789012345, enter the following in sequence: #pw+12456789012345+1#
(When entering the unlocking sequence it disappears? See the FAQ below)
7. Then press OK
8. The handset will display Phone restriction off unlocked after successful entry of the unlocking code. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
Posted on Jan 30, 2009
    Master:
  • Nokia Master
  • 875 Answers
You can get the restriction code for your Nokia 6300 from Wickedunlock.com and remove the network lock with Australia,Vodafone network.
Posted on Apr 25, 2013
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
A word of advice dont publish your imei somebody can mess it up like a pie for all seasons.
Before trying anything else, contact your service provider and ask for an unlock code.
Usually, if you've been a customer of theirs for some time, they will provide you with an unlock code for free. This is, by far, the best way to get your phone unlocked.
Download software to generate the unlocking code. Software is available on some websites for free and some pay websites that also offer support if things go wrong.
See external links below.
Find the Serial number of the cell phone, also known as your IMEI number.
Using the software you have downloaded, enter in your Manufacturer (which is in this case Nokia), your model number, and your IMEI number.
Also enter your country and the Network. Calculate the code, this may be different depending on which software you are using. If your phone is the Nokia 6300phone, select the model 6300, they are the same phone.
#pw+403927744443466+7#
Remove the SIM card from your Nokia phone.
This is typically done by removing the back cover of the phone and removing the battery and sliding the card out. Put the battery back in and power the phone on.
You will see a message "Insert SIM Card".
Enter all of the characters you see in your code, including the # symbols.
To get a 'p' press * 3 times, to get a '+' press the * key 2 times, to get a 'w' press the * key 4 times.
Disregard any spaces in the code.
In order to unlock your phone you generally need to enter only one code.
Start with the first one. If your phone is not unlocked by typing the first code (MCC+MNC), use code "7" (Multilock)
Once you have finished entering a code that works you should see a message that says "SIM is not restricted" or "Restriction off" message depending on your model.
If not, try entering another code. Message "Cannot undo restrictions" means the phone is "hard-locked" and cannot be unlocked by code.
Tips
Unlocking only applies to GSM phones, phones using other cellular technologies, cannot be unlocked without special software and hardware.
Switch off the phone. Hold the keys "3", "*" and "Call" and switch the phone on. Keep the buttons held down till you see the word "Formatting..." on the screen. Make sure that the battery is full charged before you attempt this. This should reset the phone lock code.
Warnings
Attempting to unlock your phone is done at your own risk.
Although unlocking your phone is legal, some cell phone operators might choose to void your warranty should you unlock your phone (then again, some cell phone operators won't mind).
Most phones only allow you to try a certain number of unlock tries, Nokia phones have a limit of 5 tries.
After that, the phone becomes "hard-locked", meaning it cannot be unlocked without using special equipment.
Most of the newer phones will not work with the codes generated by the free unlock programs.
You can get a free unlock code generatoe software free from here :
http://unlock.nokiafree.org/
You can also download from here :
http://unlock.nokiafree.org/NokiaFREE_v310_Nokia_unlock_codes_calculator.zip
You can check this :
http://www.wikihow.com/Unlock-Your-Nokia-Cell-Phone
Good Luck.
Live, Love, Laugh.
Posted on May 13, 2008
Unlock Nokia 6300 vodafone
You can get an unlock code from your service provider or else try to buy an unlock code from any one of the online unlocking service provider like SuperUnlockCodes.com Here you can unlock your Vodafone network lock at low cost.
May 22, 2014 | Nokia 6300 Cellular Phone
My Vodafone Nokia 2220s is asking for a restriction code when I put an Optus sim in
You can get the Restriction code for Nokia 2220 SLIDE (2220 S) at
Prounlocking.com/nokia-2220-slide/rs8wp9/ and Unlock it from Vodafone network Australia.
Sep 19, 2012 | Cell Phones
I have A nokia 6300 phone bought in australia and i would like to use my fiji vodafone sim
You can get the restriction code for your Nokia 6300 from any online site. But be wise in choosing a reliable source. For example i would suggest you to choose www.Prounlocking.com I have unlocked couple of my mobiles from here. This site provided me accurate unlock code at affordable cost. You too can have a try at here.
Before that you can visit www.Mobileunlockguide.com this site provides easy unlocking instructions for free. This would help you to understand unlocking process better.
May 04, 2012 | Nokia 6300 Cellular Phone
Hey an u help my nokia 6300 is restriction need
Is your phone from AT&T, T-Mobile or unlocked? If it from one of the carriers you need to request unlocking code from them, call customer service tell them you need unlocking code they'll will provide you one to unlock your phone.
Charlie S.
Jul 18, 2009 | Nokia 6300 Cellular Phone
`nokia 6500 s unlock code from vodafone australia
have download this software and then copied to my mobile memory card.when i start this web browser there r problem that”connection error try again”.so how can i access this browser i have nokia 6300
Mar 07, 2009 | Nokia 6300 Cellular Phone
Nokia 6300
u just type restriction code whn u r usin vodafone sim....
Sep 13, 2008 | Nokia 6300 Cellular Phone
Unlock Restriction Code Nokia 6300 with Vodafone Australia
You don't have any question or problem? Just ask here.
May 13, 2008 | Nokia 6300 Cellular Phone
Restriction code
enter this
#pw+ 30 51 16 52 43 13 51 6 +1#
Mar 01, 2008 | Nokia 6300 Cellular Phone
Unlocking Code
please try
#pw+948 012 470602113+1#
#pw+238405564616207+2#
#pw+344216076234616+5#
Jan 19, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
623 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
