AC was running and suddenly E1 fault appeared on the screen . We switched off the AC power and again powered it on . The fault got ok . But wanted to know the reason why this fault came
  • 43,501 Answers
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Posted on Sep 06, 2010
My 2000 Ram 2500 AC blows cold until I step on the breaks. As soon as I break it starts blowing real hot. Starts cold again after I turn it off and turn it back on. Break again, it blows hot again...
check for a fault in the climate control module that is affected by a power surge/ depletion from the brake circuit. It would appear that the ac compressor is being switched off by the fault and switches on again when you recycle the switch( could be a relay to the ac compressor.)
Jan 20, 2015 | AC Cars & Trucks
My dishwasher stops annd displays E1 error message on panel
Hello there and welcome to fixya
The E1 error code is a fault code for the pump meaning that the pump may be clogged or it may have failed all together so you are going to want to first unplug the machine or disconnct the power to it the code will never go away if there is power going to the unit ok?
check to see if there is a little plug looking device that has a part that you can take out to clean if so great clean this screen and remove all of the debris then put it back together and try it again
If it comes back again you will have to get to the pump itself and remove it and visually look at it first to see if there is any cracks or obvious things here
Next dissassemble the entire thing to see if it has parts inside it that are bad if so replace them you can get parts from your local appliance dealer or the manufacture
And lastly simply replace the pump if all of the above does not work ok
Hope this is very helpful for you
Best regards mike
Sep 16, 2011 | Dishwashers
Oven gets a "fault" shortly after putting power back on.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^%#TR
May 30, 2010 | Whirlpool GBD307PDS Electric Double Oven
Replaced control panel on whirlpool electric double wall oven. e1 f5 code pops up,fault code says check door latch. checked switches on latch with meter check ok.what to check next
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$RED
Feb 28, 2010 | Whirlpool RBD275PD Electric Double Oven
E1 fault code Dishwasher runs for about 5 minutes. Water fills up at bottom of unit and then machine seems to pause then fault code E1 appears then water is pumped out from bottom of machine. There are...
I think both the heater and thermostat / trip switches need to be checked.
If water is going in and out ok, then it seems to be waiting to heat the water. It sees a fault - so just clears out.
Heating elements do fail after a few years.
Aug 05, 2009 | Dishwashers
I switched on and the welcome screen appear, and suddenly the mobile turn off again...
i dropped my phone down the loo. it driedin rice. i chagrd it and it wouldnt turn off. you'll find the power button is broken. everything else works fine. to get it on, i had to remove my pin code. - annoying. but i got it on. i had to do this by putting the sim in a diffferent phone. i then found it worked as mine wouldn't turn on. check if it works iwtout your sim in..
May 08, 2009 | Cell Phones
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Oven display problem
F5-E1 is a fault code denoting a failed door lock/latch mechanism. Before having it replaced, go outside to you main breaker box and turn the power off to it for a couple of minutes... try to reset the controller. If the fault code appears again, the door lock/latch mechanism needs to be replaced.
Jul 26, 2007 | Whirlpool RBD305PD Electric Double Oven
Heating & Cooling Logo
132 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
