Question about GE (PSS26MSRSS) Side by Side Refrigerator
Compressor comes on still no cooling - GE (PSS26MSRSS) Side by Side Refrigerator
    President:
  • 1,932 Answers
Check the refrigerant level.If the level is less then there will be no cooling effect in the fridge.Always maintain the level to keep it efficient.
Thank You
Posted on Sep 06, 2010
Compressor on but wont freeze
You might be low on gas in your compressor. If compressor comes o b but doesn't cool chances are gas is too low. Make sure coils are clean and air gets to the back of the unit
Sep 13, 2014 | Grindmaster CTH-3311 Frozen Drink Machine...
Dear, I have a question that when turn on the air conditioner, it's blowed out the hot air. How can i fix this problem to get it cool again? Thank you
You will need a service call to check for a leak in the coolant or possible bad compressor or compressor starter. If the compressor is coming on and no cool air then the coolant has leaked out and can no longer cool the unit and will need replaced by a licensed technician. If the compressor is not coming on but gets very hot then the compressor is bad, and if it is not coming on and not hot then the starter condenser is bad.
Jun 25, 2011 | Heating & Cooling
Unit blows cool air out but doesn't cool room off. the compressor is not coming on. had freon checked ok
I have a question, how was the freon checked if the compressor is not coming on. If the compressor is not coming on, make sure it is received the proper voltage, if it has a capacitor make sure the capacitor is good. Also, how clean are the coils on the unit?
Apr 22, 2011 | Frigidaire FAS256R2A Thru-Wall/Window Air...
I have a kenmore s x s refridge and the freezer is cool by everthing is thawing out. I hear a clicking noise so I took the back cover off and it seems to be coming from the compressor.
the clicking noise may be coming from the start and oveer load relay on the compressor shut the unit down until the compressor is cool replace the over load and start relay on the compressor.
if you have a clamp type power metercheck the current draw on the compressor it should be between 1.2-1.6 amps during a running load.
May 19, 2010 | Kenmore Refrigerators
Compressor comes on but does not cool below 54
Good day,
The compressor is not starting. Either the compressor has failed, or the starting devices mounted on the side of the compressor are bad.
The parts mounted to the side of the compressor, are the overlaod protector, the starting relay, and on some models a start/run capacitor.
These items can be removed from the compressor, and taken to an appliance parts house for testing. You do not have to go to Sears. If the parts check O.K., then the compressor (a major cost item has failed).
P.S. If this machine is under 5 years of age. leave it alone. Call Sears for service. The compressor is under warranty for 5 years.
Jan 01, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Thermostat slow to turn AC compressor on. fan comes on but takes 5 min. before compressor comes on
Most a/c's have a 5 minute delay before the compressor turns on and they will do the same when changing from cooling or heating to cooling.
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
The fan is coming on but the compressor is not.Even after the unit has been off all night (long enough to cool down or ice to melt) the compressor does not come on.
All window unit compressor have a thermal breaker mounted on it. It is to protect it from overload. On a hot summer compressor work harder to keep us cool. Sometimes this thermal breaker fails for good. Unplug the ac. Open it, on the compressor there is a bulging thing sometimes cover with rubber. Thats the thermal breaker. Check its continuity. If you don't have an ohmeter, just byspass the two terminal of the thermal breaker with wire. Plug it in, but be carefull, turn on your ac. The compressor should come on.
Jun 27, 2009 | Fedders AED24E7F Wall/Window Air...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
