Question about Dishwashers
Dish washer code e3 - Dishwashers
    Scholar:
  • 59 Answers
E3 means no water entering....check the tsp is on and then you will have to test the inlert valve. Some tech help will be necessary now. Unless you can use an ohm meter. The resistance of the valve should be about 1900 ohns. Cheers
Posted on Sep 07, 2010
4 Suggested Answers
  • 171 Answers
SOURCE: Dish washer is not working
Hi kssami9,
I'm Harvey the Master Plumber.
Your problem is: Your dish washer kenwood model kdw243a is not working and displaying the error code E3 please give you the solution.
First try to reset the d/w. Just turn it off at the circuit breaker for ten minutes.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 28, 2008
  • 423 Answers
SOURCE: My Kenwood Dish washer KDW243A has the Code E3
If you inspect the heating element at the bottom of the dishwasher, you will probably find damage. Replacing the element is the next step.
Good Luck!
Posted on Jul 15, 2009
SOURCE: Kelvinator Dish Washer Model KD14SS
mine is doing the same what can it be
Posted on Mar 05, 2011
My dish washer has e3 on display and does wash dishes properly
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 10, 2016 | Dishwashers
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
My Kenwood Dish washer KDW243A has the Code E3 showing, its working but not heating up the water
Good Luck!
Jul 07, 2009 | Dishwashers
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
E3 code showing sometimes on Neptune MAH-3
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Mar 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Hi kssami9,
Thank you,
Sep 27, 2008 | EuroTech Dishwashers
Dishwashers Logo
126 people viewed this question
Top Dishwashers Experts
