Question about Disney DTD1363-CAR 13" TV/DVD
CARS DVD COMBI DVD STUCK
CANT FIGURE OUT HOW TO GET OPEN THE DVD PLAYER DO YOU OPEN BOTTOM OF DVD AND TV COMBI MY LITTLE BOY HAS STUCK THE DVD IN WRONG AND NOW ITS STUCK
  • 4 more comments
  • YAla Jun 07, 2008
    DVD stuck inside the unit and it doesn't open now...
  • teneester Sep 30, 2008
    dvd jammed closed...ugh have not even had it a year.
    dvd door jammed....ugh have only had it less than a year.
  • taffniball Nov 09, 2008
    i can not figure out how to open the dvd
  • apache69699 Mar 21, 2009
    ok my tv didn't come with remote. and also this will sound dumb. but where is the dvd player located? lisa
  • Anonymous Mar 22, 2014
    stuck on stand by since unpluging it 22inch hd ready dvd combi
    Problem Solver:
  • 6 Answers
Your son may have stuck something else in there too!!!--God knows mine did!!!!!! I have stated in here already how 2 access the insides of the unit.Check the questions asked by others and u will find it. If all else fails and you r forced to get it serviced by a professional, you might want 2 prevent this from happening again by removing the "smiley face mouth" piece that is attached to the tray when it opens so that little people or others don't pull it open:) It unsnaps, very easy to do
Posted on Jul 01, 2008
Dvd player in combi 19"
Dear Concern, Please open the disc and clean it with very soft cloth and put some cologne in it.. not too much that i wont get dry .. or not so little that it doesnt wets the surface for little while. Clean the small lens part also..make sure your hands are firm and gentle.
Feb 24, 2014 | Sanyo LCE19LD40DV-B 19-inch Widescreen LED...
Technika combi unit dvd player wont read discs anymore
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Regards.
Jan 12, 2012 | Televison & Video
My Technika TV/DVD Combi was playing a DVD but then made a noise like it was trying to skip tracks before going off. When I try to go back on to the DVD it says "no signal" and won't...
Hi.We can't help you here. Take it to a repairman. Inside you maybe able to check for a fuse but nothing else. If the cost is more than a new TV than you can decide for yourself. Good luck
Jun 28, 2011 | Televison & Video
THE dvd WON'T COME OUT OF THE dvd PLAYER AND THE
tere should be a little pin hole somewhere on or near the dvd player. take a paper clip straighten it out and put it in the hole you will have to push hard until the dvd holder pops out a little then pull it out until it stops. remove the dvd and push it back in then try to open the slot using the open button. it it doesn't work then you will need to take it in for repairs or replace the tv. though it would probably be cheaper to replace the tv.
hope this helped
please rate well.
Mar 06, 2009 | Emerson EWL20D6 Television
Lost instructions for bubble console pre school game
hi tim im having some problems with bubble at the moment its unreal i have some phillips codes dont know if they will work however ill give them to you anyway
0503 0539 0646 0671 0675 0854 0885 1158 1260 1267 1812 1813 1818 1911 1914 if you stick the set up dvd in n watch the first time set up bit it explains everythin you need to know i there hope this helps you out!
Dec 20, 2008 | Toys
Magnavox MDV560VR DVD/VCR combi
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP 9 for five seconds to restore the
picture to normal operation.
Aug 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Tv and dvd combi
There is no switch [TV\DVD] ?
Usually, when u turn off the TV, it should goto DEFAULT, which would be the TV. Do u have an antenna connected to the TV. Some TV go blank [deaf & dumb] when there is no signal to TV. If you cannot get the TV portion on, then I would suggest the u have an electronic switch [DVD is off, it will goto tv] that is shorted in DVD position. Is there a button that has no markings ?[you know, rubbed off by touching it so much]
touch EVERY button two times [one for on, and one for off] except the ON\OFF button !!
May 12, 2008 | Televison & Video
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Cannot get tv to switch to different source
You do not mention if you have unpluged the tv from the wall,is the easiest thing to try,if the set resets and still does not open the tray you can still force it open it manually but very carefully just to remove the dvd,if you can not force it open by pulling evenly in both extremes of the tray and you feel the dvd still is not coming out even with the tray open,dont go further and get help from a servicer,we do not want to break the mechanism.(set should be unplug )You can also remove the back cover and see if the main conector to the dvd player can be unplug,if it does you can leave it unplug and try turning the set on.This information might help you make a decision but the best solution will be to disassembly the dvd and remove the stuck dvd without forcing anything.The set is faily new and is worthed the repair.Let Us know how it goes.
Oct 26, 2006 | Samsung HC-P4363W 43 in. TV/DVD Combo
Disney DTD1363-CAR 13" TV/DVD Logo
357 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
