Question about Kenmore Elite 45986 Front Load Washer
My kenmore was stuck in an F position.. F1 I think but not too sure. So I unplugged the washer and now the door is on lock and will not open
  • 15,935 Answers
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%*&%
Posted on Sep 29, 2010
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Kenmore Elite front load washer 4110 door latch with safety lock is in lock position with door opened. How do I unlock
Solenoid prob stuck unplug machine and the plug it back in and see if it stays unlocked
Mar 01, 2015 | Kenmore Washing Machines
The door on my kenmore front loading washing machine is open but the lock is stuck in the on position
Turn off the electric to the dryer,the lock should open,close the door and turn electric back on, make sure the lock's not obstructed
Nov 13, 2014 | Kenmore Washing Machines
Kenmore elite he washer lock light. cannot open
You can manually Unlock the door Lock System
1. Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard.
6. The door may be opened.
Thank you !!
May 31, 2010 | Kenmore Elite 45986 Front Load Washer
Gallery washing machine door latch stuck in lock position
I have the same problem with my Gallery. I can not open it at all. I have tried unpluging it and putting it through another cycle to see if it will open. No such luck. Any suggestions?
May 19, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer won't drain and my clothes are stuck in the washer door won't open
unplug the unit this should release the door lock solenoid so you can remove wash
Oct 18, 2009 | Kenmore Elite 45986 Front Load Washer
Door won't open
the lock switch is probably stuck. make sure machine is off but plugged in still. Push in on the door while gently giving a couple of thumps around the lock area and the lock will probably "click" open.
Aug 16, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore model 44142400 door lock
Did you try to unplug the machine and plug it back in? that is how I reset the lock on mine.
Dec 28, 2008 | Kenmore 43142 Front Load Washer
Door Lock Problem
with panel off reach up to lock location pull down on small tab door latch will click (at this point door would pop open if it were closed ) retry operation to see if ok if code dl reappear may to replace door lock if f11 may need new control module under top rear..ck wires first ..good luck
Sep 09, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
fordexpert
Mike Squire
Robert Rankin
