Ethernet adapter jack is broken
How do you fix an HP zv5346us notebook ethernet jack? Is there an ethernet adapter that can plug into the usb port or do I need to get the internal realtek ethernet adapter replaced?
  • Carole Sommero Nov 13, 2008
    I have a presario s3100nx desktop. The ethernet port is broken and I can't set up a wireless adapter. What can I do?
    I have a Presario s3100nx desktop and the ethernet port is broken on the motherboard. What can I do?
    Brigadier General:
  • 6,966 Answers
There are Ethernet to USB adapter such the products shown here. Alternately, you can use a PCMCIA card with Ethernet such as shown here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 13, 2008
HP Desktop Modem broken ethernet port
Try to load the latest driver, you can get that from HP under your computer. If that does not fix it then go buy a cheap USB Ethernet adaptor from Amazon or BestBuy, plug it in to a spare USB port and follow the directions for the adaptor with your Ethernet cable plugged into the new adaptor.
That is it, you have bypassed the bad Ethernet power and can forget about it (they can't be fixed), you should be good to go.
If you don't want to try the driver, then just get a new adaptor and that will bypass the internal adaptor.
Good Luck
Mar 15, 2014 | HP Computers & Internet
Internet connectivity problems HP pavilion a6230n desktop pc
1.Unplug all phone, fax and satellite TV cables from the wall phone jacks.
2.Plug the double DSL filter into the wall phone jack where the 2701HG-B will be located.
3.Plug the phone wire (for phone, fax, etc.) into the jack on the filter labeled "Phone."
4.Plug the gray phone cable into the other jack on the filter labeled "DSL."
5.Add the single DSL filters on all remaining phone jacks in the same manner, plugging the device phone cables into the filter. The single filters only have one jack.
Ethernet Connection
6.Plug the power adapter into the power port on the back of the 2710HG-B router and then plug the other end into a power outlet. This will cause the power light on the front of the router to turn green.
7.Plug the free end of the gray phone cable into the port on the back of the router labeled "Phone Line."
8.Plug one end of the yellow Ethernet cable into one of the four ports on the back of the router labeled "Ethernet."
9.Plug the other end of the Ethernet cable into your computer's Ethernet port. The Ethernet light on the router should now be green.
Wireless Connection
10.Plug the power adapter into the back of the 2701HG-B and the wall power outlet.
11.Plug the gray phone cable into the jack on the back of the router labeled "Phone Line."
12.Open the Network and Sharing Center on your computer by right-clicking the Internet connection icon in your taskbar.
13.Click "Set up a new connection or network" and follow the instructions provided by the wizard to set up the wireless connection on your computer.
14.Enter the SSID and WEP key when prompted. The SSID is "2WIRE" followed by the last three digits of the router's serial number, which is located on the bottom side of your 2701HG-B router. You will also be prompted to enter a WEP encryption key, also found on the bottom side of the router. The WEP key is the 10 digit number that appears in brackets under the first bar code.
Sep 12, 2012 | HP PAVILION A6230N DESKTOP PC
Computer does not recognise speedstream 6300
you try form USB or LAN interface \\Ethernet connection (recommended)
  1. Plug one end of the RJ-11 telephone cable into an unfiltered telephone wall jack (enabled for Sympatico High Speed Internet service).
  2. Plug the other end of the RJ-11 telephone cable into the DSL port on the back of the modem.
  3. Plug one end of the RJ-45 Ethernet cable into your computer's Ethernet port.
  4. Plug the other end of the RJ-45 Ethernet cable into the Ethernet Port 1 on the back of the modem.
  5. Insert the rounded end of the power adapter into the Power port and the dual-pronged plug end into your power outlet.
  6. Press the power button to turn on the modem.
USB connection
  3. Plug the small, square end of the USB cable into your computer's USB port.
  4. Plug the wide, flat end of the USB cable into the USB port on the back of the modem.
May 28, 2012 | Efficient Networks Speedstream 6300...
My Ethernet Lan port is not in Hp model Compaq nx6115
If you ethernet port is broken or just not working and you are having no luck changing the settings then an easy fix is to get an adapter card. Some even have a couple USB ports on them also besides the Lan port so it is actually an upgrade.
Feb 24, 2010 | HP Compaq nx6115 Notebook
Cant find the ethernet port on my sony desktop
It should be located on the top right hand side, on the SIDE of the computer. It looks just like a phone jack hook up. Hope this helps. Also, if you don't have one or can't find it you can always plug in an adapter to the telephone line and then you can plug the ethernet cord into that.
Mar 07, 2009 | Sony VAIO PCV-RX470DS PC Desktop
Cannot connect to internet thru ethernet jack on computer
It could be. Check your Device Manager and make sure the device isn't disabled. Also each adapter has its own TCP/IP settings so make sure yours on your ethernet adapter are set the same as your USB adapter that is working. If it does turn out to be bad you can always add a new ethernet card for cheap.
Jan 05, 2009 | Dell Dimension E521 (D10E16) PC Desktop
Broken Ethernet Port
You say "your Ethernet Port" (= LAN port)
If unavailable try using any USB to rj45 adapter and you can use any USP port.
Check this device:Linksys - USB200M - Compact USB 2.0 10/100 Network Adapter (20 $?) or similar
Dec 28, 2008 | Linksys Wireless-G Broadband Router
Broken Ethernet Adapter
They sell USB to Ethernet adapters that you can use. If you want to replace the adapter yourself you will have to strip the laptop down to the mother board, then proceed to de-solder then solder the new one back onto the board. You can but the replacement piece from either http://sparepartswarehouse.com if they have your make and model, or you can get it from your laptop's distributer.
Feb 21, 2008 | Dell Inspiron 1000 Notebook
Actiontec gt701-wg Installation
You can use USB instead of Ethernet port but its not a common practise. Leave it empty then.
Dec 03, 2007 | Actiontec GT701WG Router (actiongt701wg)
Computers & Internet Logo
1,235 people viewed this question
David Payne
David Payne
