Question about Kitchen Ranges
Have a 8 yr old Arctic Spa hot tub. Filled it up and turned it on and the GFI tripped. By process of elimination, have determined that the heater circuit is the culprit. The heater plug has some evidence of heat damage at the control box. Any suggestions?
  • 4,336 Answers
Well, I suggest TURN OFF power, and pull the heating element. What happens is if there is power to the unit and not water around it, it burns out. Certainly, the plug must be clean and tight or resistance goes up and can cause the same condition.
Posted on Sep 06, 2010
My hot tub works for about 20 mins and clicks the GFI off. Then I reset the GFI and the spa comes on for about 7 mns and trips the GFI again. Is this my heater doing this?
Easy way to test for the heater issue is to disconnect the heater from the board. Disconnect both leads from board and let the spa call for heat. There is also a chance the GFI breaker is bad however most times the heater fails and the breaker is doing its job.
Apr 01, 2017 | Hot Tub Works Pool & Spa
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
To clarify my previous question it is a hot tub heater
Chad, check your GFI to see if it needs reset, there may be a reset on the limit switch tripped also. Check the attached links,instruction and guides, Good luck
Hot Tub Spa Heater Elements Troubleshooting Testing
How to Diagnose and Repair Your Hot Tub Heater Arctic Spas
Is there reset button somewhere around heater or motor Hot Tub
http://www.spacare.com/spawillnotheat.aspx
Apr 24, 2016 | Pool & Spa
Emerald Vantage Hot Tub Dead
if your GFI trips soon after the spa goes through the purge cycle then you need a new heater.
Yes the heater can develop a dead short and it causes the GFI to trip when power is sent to the heater.
Rod @ US Parts Center .com
Apr 30, 2013 | Rule 1800 H53SP-24 Swimming Pool Cover...
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Oct 02, 2012 | Electrical Supplies
2 yr old softub Hot tub with connected GFI wire was emptied and cleaned out and filled; now the GFI trips when pluged in, and will not turn on!
Either the GFI is bad or it is tripping because there is a short in the system (obviously, right). I would turn off your panel break, disconnect the GFI and using a meter test to see if there is a short in the system. You would check the hot lead coming from the GFI to the tub and see if it is shorting. If you can't find a short, you should try replacing the GFI. If there is a short then you need to search for the short. Hope this helps and good luck!
Mar 14, 2010 | Leviton 8599 GFCI Receptacle
My hot tub keeps tripping the breaker and will only stay on for a short period of time before tripping the breaker. What can I do?
Check for a water leak in the electrical areas of your spa... specifically look closely around the heater terminals, look for wet and corroded connections... If this spa is wired to a plug-in outlet, look at the GFCI plug assembly as well... You can also try disconnecting the blower, pump, heater, etc, from the control pack (one at a time) to determine which item is causing the tripping.
Dec 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
My hot tub just stpped working, its getting power to the cord, but then nothing, is there an easy way to tell if pump is bad
first check all GFCIs to make sure you do have power at the spa. The spa powerpack can have a gfi there as well.
The only way to tell if a pump is bad is by testing the voltage going from the spa pack to the pump, or you may be able to feel that the pump motor is heating up. It could be a bad motor, debris keeping the impeller from moving, or a power problem. You'll have to do process of elimination.
Oct 31, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Arctic Spa refill and a heater alarm ''HL''
HL is an error code. You will want to check out the link below to the mfg wesite. Balboa Water Group
Dec 28, 2008 | Arctic Above Ground Rugged Mesh Winter...
Kitchen Ranges Logo
171 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
