Question about Kenmore Front Load Washer
I have a Kenmore HE 2 Plus front load washer, type 832. Serial Number. Part way through the wash cycle I get an error message code F-20. What is this and how do I fix it please.
SOURCE: Kenmore Elite HE3 front loading washer
Before you go crazy trying to solve the F2 code make sure the filter is clear. Disconnect the power cord, PLEASE. Remove the kick plate on the bottom front by removing the 3 screws below it. You will need a hex socket and extension or a torx screw driver. If there is water in the machine and it will not drain you will need a shop vac and some old towels to catch the water when you open the filter. Now, you will see the filter in front of you. Have the towels ready and vac turned on. Quickly unscrew the filter cap and stick the vac hose right in the filter to catch the water. Clean the filter cap. Did you find any socks, money or other debree ? If yes that may have been your problem. Put the filter back on and HAND tighten well. Test the machine. From now on empty all pockets before you do the laundry. You just saved yourself a big repair charge. Be proud of yourself.
Posted on Apr 17, 2008
SOURCE: Siemens Wash & Dry 6140 (Front loader Washer drier)
SUCCESS !!!! - WOT A RESULT.! - SO PLEASED I HAD A GO.
Dry joint found on PCB was BLACK & MELTED, specifically one on the relay terminals was not connecting to the pcb track anymore ;looked like poor original solder joint.
GOT THE OLD SOLDERING IRON OUT, FLUX PEN AND SOLDER AND VOILA!!!
SAVED £280+ (SIEMENS QUOTE: NEW PCB £200 PLUS LABOUR £40/HR)
Posted on Apr 26, 2008
SOURCE: Kenmore HE2 Plus Error Code: F-20
You probably have this solved by now but for others who read this as I did.............
F-20 means
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Hope this helps everyone else as it did me, thanks
Posted on Dec 02, 2008
SOURCE: Kenmore washer 24802, model 110.92480200,
This is normaly because your cold water inlet soliniode is faulty. If you want to test it set the wash temp to cold and start the machine, It should do nothing. then set it to warm or hot wash and see if it fills with water if so the cold inlet soliniode needs replacing
Posted on Jan 22, 2009
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
I have a model #110.47561601, Kenmore HE2t Front load washer Type 832. I am getting a code of F-24, when I try to start the cylce. What is the problem that prompts a F-24?
Hello
F-24 is a water temp snsor error.Try running the machine in spin and drain.Once empty unplug machine for 3 min.Then try load of wash again.This time use cold water until error clears.
Aug 27, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore fHE 2 plus front load washer does not drain and does not complete the spin and drain cycle. Error code f-21.
Means the drain is too long. Under the front lower panel is a sump filter. Remove the filter by turning ccw and clean.
Nov 04, 2010 | Kenmore HE2 Plus Front Load Washer
Error Code F-20
I have same machine and manual says, "F20" on display (water inlet problem - no water or insufficient water supply). Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following. Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re select cycle and press START. if the problem remains, call for service.
May 13, 2009 | Kenmore HE2 Plus Front Load Washer
F-20 means
“F20” on display
Oct 24, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore front load HE2 plus
I have a F01 error message on my Kenmore He2t washer. I tried to add clothes to a wash and restart and continue to get the message. Please help
Jun 14, 2008 | Kenmore 46462 Front Load Washer
Kenmore Front Load Washer Logo
312 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
