Base rw Model dw-2200 dvd player?
Can't set it up? I am going through set top box through dvd player to tv and can only get the time on the dvd player. Tv and set top work beautifully,alone ..what am I doing wrong that the dvd won't show on the tv? I think I have tried everything. Yellow white and red out STB to In DVD out dvd to in TV av 2 Same with RF aerial ..but nothing on the screen Please help! PS I am not savvy with the back of tv's etc thanks Sue
  • 1 more comment
  • shuszie May 13, 2008
    yes it does... without dvd connected!
    sorry top box only has one RWY connection .. so I was using that to go to dvd "in" ..then another RWY "out" of dvd to TV av2 scarp "in"
    Then Rf "in" aerial set box and 'out to' dvd 'in' and out to Rf 'in' on tv
    I am using 2 RWY cables and 2 aerial cables...do I need extra cables?
    sorry I took the av imput as what was on tv when set top was connected ie: A/V1 or A/V2....sorry Sue
  • check if you're top box have A/V input!
  • 25 Answers
Ok first connect the red/white/yellow output of the dvd to the top box red/white/yellow input. Get the extra a/v cable then connect to the red/white/yellow output of the top box to red/white/yellow of the tv a/v video input A/V1 or A/V2 and last connect the RF aerial to the top box antenna in.
Posted on May 13, 2008
Record tv to dvd on Funai recorder
The Funai ZV427FX4 doesn't have a tuner. You'll need a set-top box (either a digital tuner or a cable box) that has a composite A/V out. Make sure to use a compatible DVD-R or DVD-RW disc (see page 27 of the manual given below). For basic recording, insert a DVD and press DVD to make sure that the recorder is ready to record to disc instead of video tape. (You may need to format the disc for DVD-RW.) Press Rec Mode until the correct mode is chosen. Then press Input to select composite input 1 or 2 (L1/L2). Set this source to the desired channel. Then press Rec. (For scheduled recording, make sure that the unit is set to DVD. Then press Timer. Follow the on-screen cues to set the time to start and end the recording. Otherwise the steps are the same. Then press Timer Set.) See the manual for screen-shots of the procedure.
The manual for this model is available on the product page: http://www.funaiamerica.com/product/product.php?id=877 . Click on the Downloads tab. The direct link is currently http://www.funaiport.com/download/download.php?id=3361&brand=FUNAI . For older Funai units with an NTSC tuner, you will probably still need the set-top box. However, you can either connect the box to the composite video or RF input. (If you want to record a program from a low-power analog station, you would skip the set-top box.)
I hope this helps.
Aug 28, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
Canon DVD burner DW-100 and HG10 burn issue
You can not have any MXP Files in your play list or in memory. The DW-100 Can not burn these files. Once you delete/remove the MXP Scenes from the the Camera the Burner will work fine.
Dec 13, 2009 | Canon DW 100 DVD-RW Burner
Does not play DVD video or read CD RW or DVD RW. But does play audio CD.
Try on VLC player or GOM Player.
I hope that this has been very helpful for you
Nov 16, 2009 | Sony (DW-D22A/B2) DVD±RW Dual Layer...
Certain DVD disc can able to openSONY DVD RW DRU-810A, But I am unable to open with SONY DVD RW DW G521A. Kindly advise me to further course of action.
yes, most of the dvd recorders are like that. you must read the user guide to find the correct dvd brand to use. i have a toshiba (i can only use maxell, (best) tdk ,dynex (good) and memorex (Ok)) fuji sony pansonic will not record nor play.
http://www.supermediastore.com/dvdmedia.html blank dvds for sale
May 06, 2009 | Televison & Video
Did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
Hope this helps. Good luck.
Mar 19, 2009 | Canon DW 100 DVD-RW Burner
I recorded my movies on the dw 100 but now i can't grt them to play on my dvd player
The DW-100 records discs based on the format they were originally recorded.
If your camera is recording HiDef videos than the discs this unit creates will be viewable on a Blu-ray disc player.
If your camera is recording in Standard Definition (ie. NOT HD) then I believe that the discs will work in regular or upconverting DVD players.
My Canon camcorder does not record in Standard Def so can't quite vouch for that last comment though.
Jan 06, 2009 | Canon DW 100 DVD-RW Burner
Canon DW-100
Thanks, I think it works that way. gl
Dec 08, 2008 | Canon DW 100 DVD-RW Burner
Sony DW-G120A DVD RW Dual Layer Burner
U can use nero, first of all you must format de DVD-RW, so that it can be be rewritable. Then use it like a normar DVD-R disk. And every time you want to rewrite the DVD only make a quickformat and put your things on the DVD.
Nov 09, 2007 | Sony DW-G120A DVD RW Dual Layer Burner
DVD reading problem
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer Goodluck!
Jan 18, 2007 | Sony (DW-D22A/B2) DVD±RW Dual Layer...
Numerous errors when attempting to burn dvd's
Nov 11, 2006 | Sony DVD+/-RW |DW-Q30A BG w/o SW %...
Televison & Video Logo
267 people viewed this question
Top Televison & Video Experts
